Question about Toshiba Tosvert 130g2 Transistor Inverter
We need manual for toshiba tosvert-130G3 inverter. Is there one available for download. I don't have anything for this inverter to set it up to service at our plant. Help please. Thanks Orville
Toshiba website has PDF manual online.
Posted on Jan 18, 2011
Control will not run motor
Power is present where circuit board is at, but motor does not run.
Nov 06, 2013 | Toshiba Tosvert 130g2 Transistor Inverter
Toshiba Transistor 130G2 OCA error
Basically it is telling you that the inverter is bad. You can disconnect the output so there is only the power going to the inverter and see if it will come on with a no load situation but if it still fails, there is no fix other than to send it back to manufacturer.
Try this as your one and only "maybe":
Reset is press CLR and WRT at same time (I think).
Page 7-7 and 7-8
http://www.toshiba.com/ind/data/tag_files/G2%20Manual_559.pdf
Oct 25, 2012 | Toshiba Tosvert 130g2 Transistor Inverter
I turn the power on push the ctrl button and push start, The unit turns on ready to start but does not start
Try reset first, If that does not resolve it, suspect the start switch as the culprit. You might be able to clean the contact surfaces with contact cleaner and rapid cycling of the switch.
Dec 28, 2011 | Toshiba Tosvert 130g2 Transistor Inverter
When run comand is enable I get an error OC1. I disconnected the load and still get the same error. The inverter has been working fine for the last three years
Overcurrent on acceleration is what the code is supposed to be. There may be a capacitor failing in the finals of the output stage, or a resistor has shifted value..
Sep 04, 2011 | Toshiba Tosvert 130g2 Transistor Inverter
Toshiba tecra a2 screen backlight problem the is screen not lighting up at all but in bright daylight fully functioning screen can be seen could this be the lcd inverter and how difficult is it to replace
screen not lighting up is either the screen inverter or a broken tube inside the screen. Tubes don't break by themselves so a dim screen usually comes after a transport or a drop. I would replace the inverter first (just cause it's easy and cheap). eBay's a good source for inverters and screens and you ought not pay more than $5 for a used inverter and anything more than $30 for a used screeen would be considered tourist price. Tecra A2's are rare, but it's the same as the more popular Satellite A55's. Its screen should be a 15" XGA and would be the same screen as many other Toshiba Satellite models (A10, A15, A40, A45, A55) and Satellite Pro models (M10, M15), to name a few.
In my opinion, dim screens are 98% broken tubes and 2% inverters.
Jul 29, 2011 | Toshiba Tecra A2-S336 Notebook
I need a manual for a Toshiba DVD recorder DR570. Thanks
Download it from Toshiba's Support site. It is in standard adobe reader .pdf format. If not on Toshiba Support, google for it. It is available online.
Advantages of downloaded digital manuals are; it's free, you don't lose it, and you can more quickly find what you are looking for in it by searching words in adobe readers .pdf document 'search' window. Most all PCs have adobe reader already installed, if not, google it and download it for installation. Else, your browser will allow you to view it online without installation.
Feb 02, 2011 | Toshiba DR570 DVD Recorder
How can i troubleshoot a transistor?
A transistor is a switching device. You can connect it with a bulb using wires and a power suppy along. You also need to be more specific as to what type of transitor do u have. as most of them have different characteristics.
May 13, 2010 | Toshiba Tosvert 130g2 Transistor Inverter
TOSHIBA TECRA8000 MANUAL
Hey,
its available at toshiba downloads - user guide
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
  1. select your laptop from the listings - portable - toshiba. tecra .8000
Let me know if you need anything else.
Thanks,
Ekse
Feb 21, 2009 | Toshiba Computers & Internet
Toshiba Tosvert 130g2 Transistor Inverter Logo
600 people viewed this question
Top Toshiba Electronics - Others Experts
Willem.
Willem.
Andrew Wright
michael auza
Level 1 Expert
Are you a Toshiba Electronics - Other Expert? Answer questions, earn points and help others
