Question about Acer Aspire 4530-5889 Notebook PC
Is the disc drawer suppose to open and close fully or does it have to be pushed or pulled on to open or close
  • 320 Answers
Hi you need pull/push disc tray anytime you want use it
Posted on Aug 23, 2010
Bottom oven drawer stuck partially open. Cannot close or fully open. Model #316471000
Hello Dan, thank you for your post!
I understand that the bottom drawer of your Electrolux range will not close and it partially open. It is possible that your rail or drawer may be damaged or blocked. I would recommend pulling the drawer out to inspect it. If you pull the drawer out there should be tabs on the side to unlock in order to remove the drawer fully. The model number you have provided is invalid you can locate the model number on the serial tag. The serial tag can be found on the frame of the drawer. I look forward to assisting you. -Matt
Dec 25, 2015 | Electrolux 30" Self-Cleaning Freestanding...
The CD drawer on a JVC EL-E3 CD Player fails to open/close. The CD fails to play when I physically close the drawer. The drawer does not close completely and needs an extra push to close it.
Sounds like the alignment is off. By physically pushing the drawer.
There is a motor on the side of the drawer that should control the drawer by pushing a piece of plastic back and forth. This piece can shift if pressed to hard. In the back of the drawer are the rods that control the top to drop. These need to be aligned with the side motor.
Jan 07, 2015 | JVC Audio Players & Recorders
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Cpu repair
It could be "jammed".
Straighten one Norwegian paper-clip.
Put one end into the very-small hole in the face-plate of the optical drive, and firmly push it about 1 centimeter. This should "unlock" the drawer, and you can either push the 'open/close' button, or just gently pull the drawer to its fully-open position.
Aug 28, 2013 | Compaq Computers & Internet
Cd was still player and I found the player with drawer half open and jammed. I can't get it to sync with correct rotation, enough rotation or fully close or fully open. I can force it and hear the gears...
Rea alligning cds is not hard, but not too easy,the best way is to remove the whole cd changer mechanism and allign it to either one point,while totally disconnected, fully open or fully closed. I mean, the rubber or gear mechanism.
The main point of reference is the nearest part driven by the main motor. For example decide to do it when fully open, arrange everything so as to allow the tray to be fully open.If you get everything right, rotate the motor manually and see if it closes the tray without jamming..If it gets fully in keep rotating the motor and see if it loads the disc.if it does, return the assembkly, the sensors and the cd computer will take over from there ...
Apr 12, 2017 | Sony CDP-C445 5-Disc CD Changer
The radio with a 6 disc changer stock wont eject cds in my 2001 ford windstar van with double sliding auto open/close doors
Hi
Thanks for using FixYa. Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Use a stiff wire, a paper clip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open and remove the CD.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 04, 2009 | 2001 Ford Windstar
Disk eject Dellxps 16
If you look closely at the drawer where you put the disc in, there is a tiny hole. Use something which will fit, pin, paperclip etc and push firmly into the hole. This should force the drawer to open.
Hope this works for you
Jun 13, 2009 | Computers & Internet
SONY DVD Player refuses to load DVDs
What you might of done is pushed the dvd tray to close it, so its out slightly.Come across it a couple of times. all i did was, open the tray & before it started to close, switched off the power. pull the tray until it opens fully(dont yank it). when its fully open, try to pull it very slightly more. plug it back in & let it go back its self, if it doesn't. push it. all thats happened is its just out slightly. messing about with it like this will sort it im sure. let us know how you get on. martindean71@googlemail.com
Jan 21, 2009 | Televison & Video
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
Acer Aspire 4530-5889 Notebook PC Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
