Question about Maytag Neptune MDG5500AW Gas Dryer
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes thru the same process again.
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
The heater ignites well, but if it gets a clear blue flame (and it burns very quiet), the thermocouple will glow red and the heater stays on, but when it gets a opaque blue flame (it makes a sound when...
I would start by replacing the thermocouple. It is suppose to keep the gas valve open when in operation. If the mercury in the thermocouple dries out it won't keep the gas valve open and thus the flame goes out. If that does not work then you have a gas valve problem.
May 05, 2017 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Takes a long time to get to temperature
If it's a gas oven and has an electric element starter (glows orange to ignite the gas), the element can be taking a long time to heat up, which means the oven doesn't light for a while and so seems to lake a long time warming up. If you turn it on and then look at the area where the flame should be (broiler) and the flame takes a long time this could be the problem. This happened to me and replacing the element fixed it. Now the flames light within 30 second or so.
Nov 11, 2012 | Ovens
Gas dryer does not heat igniter glows red gas valve clicks but no flame
Since the igniter glows i am wondering if within 1 minutes does it go off??or does the igniter just stay on??
If the igniter just stays on and doesnt go off the problem is going to the FLAME SENSOR
if the igniter goes off but no flame the problem will be the GAS VALVE COILS
GENE
Oct 12, 2011 | Dryers
I have a neptune mdg5500aww dryer, goes on, glowing igniter... but does not turn on the gas... what is wrong
Their are 2 possible things wrong;
1) Does the igniter just stay on or does it glow and go off usually within 1 minute?..if the igniter just stays on and never goes off the FLAME SENSOR will be the problem
2) if the igniter does glow then go off but no flame..the coils that open the gas valve are bad
The part numbers are;
FALME SENSOR 338906
GAS VALVE COILS 279834
The parts could be ordered from your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwanger.com
repairclinic.com
GENE..OldTech2332
Aug 30, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Intermittant heating.It will begin to glow....sometimes the flames shoot out for a short time....but then go out. Then, it will continue to glow red without flames igniting,then goes dim....couple minutes...
This is usually caused by faulty coils on the heat valve. they can be purchased seperate from the gas valve and are relatively easy to install..
Oct 27, 2010 | Dryers
Dryer is tumbling properly,but not drying. there is absolutely no heat.
pop the cap on the front of the dryer an turn it on
if you see the igniter glow an the flame comes on wait an see if the flame stays on if it it shuts off like 10 sencds later,you have a block vent
if no glow or flame u got a bad thermal fuse
if it glows ,flame an shuts off like and then comes an goes u have bad coils...
good luck post some feed back thanks
Feb 01, 2010 | Kenmore Dryers
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
Mdg 4000aww turns on and heats when started. runs for 5 five minutes then flame goes out. ignitor glows but no flame. one minute later dryer still running ignitor glows, no flame. this repaets until turned...
Either the venting needs cleaned or the coils on the gas valve are bad. Unhook the venting from the back of the unit and run. If works ok then clean venting. If you still have the problem, replace the two coils on top of the gas valve.
Sep 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
169 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
