Question about Canon PIXMA MX700 All-In-One InkJet Printer
My MX700 is displaying Error Code 6A80 and the printer is in-op. The owner's manual and the Canon web site have not been helpful. Any suggestions? Thanks. Al Chesser (520) 327-8071 cdresort@cox.net
    Genius:
  • 1,478 Answers
The problem is from the print head. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference.
Take care.
Posted on Aug 23, 2010
Error code 6A80, won't print after changing ink cartridge. printhead is all the way to left. Tried moving it manually and turning off and unplugging printer.
@font-face { font-family: "Times New Roman"; }@font-face { font-family: "Verdana"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; font-size: 14pt; font-family: Verdana; }table.MsoNormalTable { font-size: 10pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
Issue: ERROR LCD: Error Code 6A80
Solution #1: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Solution #2: Removing paper jams MX700
See very detailed description at this link:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx700#ServiceAndSupport
Jun 30, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I have a Canon MP550 and after pressing ON button in few seconfs appeares message: ERROR CODE 6A80
[6A80] & Light Blinking 12 times = APP Position Error. An error occurred in the APP motor. Maybe foreign material or paper debris around the PURGE UNIT (at the printer most right hand side) or Auto Sheet Feed area.
May 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I have a canon mx700 & have an error code 6A80 -need help
That error says there might be paper scraps stopping the purge assembly on the right where the printhead parks, or something fallen into the slot where paper goes stopping the paper feed assembly. You just have to inspect closely with a flashlight before taking to the shop.
Jan 05, 2010 | Canon MX700 Office All-In-One InkJet...
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
How do I re-set error 6A80? on my Canon PIXMA MX700 lcd display?
6A80 is APP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.Check the sheet feeder.If this not help your printer need service.
Nov 01, 2009 | Canon PIXMA MX700 All-In-One InkJet...
MX700 ERROR 6A80
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Error 6A80 – means “AP position error”- indicates that "an error occurred in the APP motor during purging operation". Either the sheet feed unit, purge unit, or logic board could be at fault.
I'd recommend bringing the unit into your local canon authorized service facility for complete diagnostic and repair.
Hope this helps
Aug 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error 6A80
Error 6A80 indicates that "an error occurred in the APP motor
May 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error code 6A80
It is because of Purge unit can be damaged or stuck. Probably you have to pulled apart the printer and check the purge unit.
Jan 26, 2008 | Canon MX700 Office All-In-One InkJet...
Canon PIXMA MX700 All-In-One InkJet Printer Logo
88 people viewed this question
old marine
old marine
