Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
The power button will not click on and power is not evident. The remote as well will not urn on the power..
  • 1,606 Answers
That could be a failure of the power section or some of its components causing this. You may have smelled hot electronics, or heard a whistleing noise or a pop just befor it went out.
Unfortunetly this is a shop job. you will need to take it into either tv repair shop or the Sony repair depot. As a word of caution get an estimate on the repair cost. Do not just get it fixed. You may get a bit of a shock at the bill if it isn't covered under some warrenty. You want to know what the replacement cost is worth so check out a few stores and sales. Use that price as your guide to see if this is worth fixing. Depending on what and how it gets fixed, the repair cost can be more than buying a new replacement tv.
Posted on Aug 23, 2010
How to Downgrade my AVG Subscription on Windows?
urn on your computer. Press the Power button on your computer to turn it on.
  • The location of the Power button will depend on your PC. If you're using a desktop computer, the Power button should be at the front of the CPU; if you're using a laptop, the Power button should be near the keyboard area.
Click the Start menu or the Windows Orb. This is located in the bottom-left corner of the desktop screen.
Select "Control Panel." This is located at the right menu selection of the Start menu.
Choose "Uninstall or Change Programs" under the Programs category. You will be taken to a list of all the installed programs on your computer.
Scroll down until you see "AVG Anti-virus" and right-click on it. A menu will appear that will let you choose either "Uninstall" or "Change."
Select "Change." An AVG window will appear with some options for you to select.
Oct 19, 2016 | Computers & Internet
How to use hp remote controler
Certain HP entertainment PCs come with a remote controller. It can be used to power up the computer (Windows icon)., or power up the computer and launch the Media Center. Other buttons should be self-evident.
Oct 30, 2013 | HP Computers & Internet
MP750 Printer does not power on. There were no evident problems, was printing well one day and the next would not urn on.
1-check the power cable if it is twisted from both sides. or buy new power be sure it is inserted nicely into the printer socke.t
2- check the plug if there is any fuse! if it is blown up., change the fuse with the same amp rate.
3-check power source socket...try another power source wall socket.
4-keep long press on the power on.
I hope will do....otherwise something went wrong with your internal power supply good luck.
Aug 14, 2013 | Canon PIXMA MP750 All-In-One InkJet...
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
I need the codes for a Sharp Tv for my Big Matters Jumbo Universal Remote. Can you help me?
here's the codes to your sharp tv for that remote
Sharp TV:
013, 028, 035, 073, 075, 078, 092, 093, 120, 131, 132, 134, 139, 141
1. T urn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device. (just try one of the codes I listed above) if one doesn't work just try the next one,
3. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds. The POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press the POWER button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Feb 28, 2011 | Televison & Video
Tv wont urn on
Please try these preliminary steps....
1. Check wall socket by plugging any other appliances
2. If it is ok, check whether power LED of TV is working
3. If power light is there, the problem will be with remote
4. For checking remote - Point the remote towards the Camera of a Camera Mobile with camera on. While pressing remote keys, we can find the remote LED blinking, which means working.
Mar 10, 2009 | RCA 27V514T 27" TV
Need code for Brookstone remote to work W/ Direct TV TIVO receiv
Sense you do not know the make of the receiver I would do a code search. This is how you do it.
Automatic Programming
With automatic programming, the remote control tests all the codes available
on the Code List and assigns the correct code for the selected device.
Although this method can be more time-consuming, it eliminates the need to
look up codes and enter them manually.
1. T urn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. The
remote control is in programming mode.
3. Press and release . The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
4. Press CHANNEL + or CHANNEL - repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• The unit will search for the next code or the previous code if you press
CHANNEL + or CHANNEL - after the device turns on.
6. Press any other button. If the device responds, the remote control has been
programmed. If the device does not respond, repeat steps 2-5.
Good Luck and Please Rate FixYa!
Dec 31, 2008 | Brookstone 538744 Remote Control
I have rcu300 remote control need code sv2000 tv
hit the code search button, hold dpwn until light remains lite, then press and release the componet key that you want the remote to operate, then aim remote at the compont, and press the on off key once, keep remote aimed at the tv until it turns off, may take awile, as soon as it urns off, hit the enter button, within 3 seconds, and it will store the code to remote, goodluck
Dec 28, 2008 | RCA RCU300WBL Remote Control
Correct code for Magnavox TV modelMMC24T5A not on code list
If code is not on list do auto search for the code.
Note:
Dec 27, 2008 | Brookstone 538744 Remote Control
Magnavox TV Model # PS1980 B121
I solved the problem by unpluging the main power sourse and repluging. Evidently recyclining the unit! Thanks for your answer even though you were trying to get me to purchase a program! ds
Feb 09, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
19 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
