Question about Western Digital Computers & Internet
I was using my external hard drive to organize my music files into folders. Everything was working fine, then I left for dinner and I came back, and in my itunes music folder, it won't let me create folders for the different artists anymore. It won't let me move any files into any existing folders, and it gives me trouble when I try to safely remove the hardware. Sometimes it shows up twice on my desk top even though there is only one HD. Every time I try to do something in that folder, it says an error has occurred [such as creating a new folder in the itunes music folder]. How do I fix this? I was only gone for 10 minutes!!!
thassall4295
  • 91 Answers
SOURCE: not synching correctly with itunes music folder
I know another way you could try formatting which may fix this problem. Restoreing just restores all the setting to your iPod yes it shoudl format as well but it may not due to an error or something.
To do try it another way follow these steps, first click on "Start" - "My Computer" look for you iPod when it's connect usually called "Removable Disk" once you've found it "Right-click" on it then click on "Format", once format is complete disconnect, then connect it again then run "Update" for your iPod and for iTunes, once you've done that have another attempt.
Good luck. Hope my solution was helpful in some way. Further problems leave a comment and i will get back to you.
Posted on Nov 12, 2007
SOURCE: Can't access my share folders
Drive management show only safely remove usb drive.
When u use mionet software it map the share to a drive letter. If u create folder or files on that drive u dont have permission to chance those files or folders on \\mybookworld.
Solution, dont use mionet software.
Posted on Dec 18, 2007
mastersaintx
  • 928 Answers
SOURCE: making new folder and copy folder from harddrive to flash
On most flash drives there are locks that are called write protect locks. Its a switch on the drive itself that prevets you from saving on it.
Posted on Jul 27, 2008
SOURCE: Keep getting an error saying "The iPOD cannot be synced. An unknown error occurred [-50]."
How To Fix The "Cannot Be Synced" -42 Error For 2nd Generation Nano?
Follow these simple steps (cannot be easier):
1.Plug in the ipod
2.Go to My Computer
3.Right Click the Ipod (F:)
4.Go to Properties
5.Click the "Tools" Tab
6.Click "Check Now" under Error Checking
7.After it's finished start itunes
8.Update Ipod once it shows up on itunes
9.It Works!
You're Welcome =]
Posted on Jul 28, 2008
lsteward68
  • 331 Answers
SOURCE: Can't get itunes to work
The error message “The folder iTunes cannot be found or created”. It was referring to the My Music directory that is usually located in the My Documents folder on the partition containing the operating system. The iTunes software creates an iTunes folder in the My Music directory on first start and if that directory is not accessible it will throw the error message and fail to load.
Since this error is related to the My Music folder it is important to check the directory path of that folder in the Windows Registry. This is best done by using the shortcut [Windows R], typing [regedit] and hitting the [enter] key.
The fastest way of location the two locations that contain path information for the My Music folder is to use the search by pressing [F3] and entering [My Music] in the search box. A click on [Find Next] will start the search and reveal the two locations.
The test computer system did not have path information listed at all. This can be changed by double-clicking the My Music key in the Registry and changing the path to an valid path manually.
The two Registry locations that list the My Music path are the following two:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
Make sure both point to a valid path on the system. Once the path has been changed iTunes will create the iTunes folder in that location and start up without this error message.
Please back up your registry before doing this. messing in the registry can make your computer stop functioning.
Make sure you follow the correct registry entry.
Posted on Apr 27, 2009
How do I backup itunes file on external harddrive
It's a good idea to regularly back up all important files on your computer to an external source to prevent data loss. Your iTunes music, videos and other digital downloads are stored in separate files within the iTunes folder. However, if you consolidate them into a single folder, it's easier to back them up to an external hard drive.
Launch iTunes. Go to the program's Preferences menu. Click the "Advanced" tab. Check the box next to "Copy files to iTunes Media folder when adding to library" and click "OK." Click "File." Select "Library" and then "Organize Library." Check the box next to "Consolidate Files" and click "OK." Close iTunes. Connect your external hard drive to your computer. Find the iTunes media folder on your computer's hard drive. Drag the folder to the icon for your external drive to copy your iTunes media.
Back up your iTunes library by copying to an external hard drive http://support.apple.com/kb/HT1751
Mar 19, 2013 | Computers & Internet
Tip
Moving the iTunes Music Files to a Different Hard Disk/Folder If you are low on...
If you are low on disk space in your iTunes folder then you can move these music files to another hard drive and keep your music library in tact without the need to create your music library again.
If you want to transfer your iTunes to an external USB hard drive, make sure that it is powered up and connected to your computer before opening iTunes.
Opened iTunes, click Edit and then Preferences. Click the Advanced tab.
Make sure the Keep iTunes Media folder organized checkbox is checked, and click Change.
Then select the location where you would like to move your files to. Click Select the Hard Drive and Folder or OK once you’re done.
The files will not move into their new positions by themselves –To do this – click File, Library and Organize Library. Check Consolidate Files.
When this process has been completed, go to the new location of your iTunes media and check the music files to see if they have migrated across correctly. Also play one or more tunes to test the music files.
The redundant iTunes music files can now be deleted from the original iTune location (C:\Documents and Settings\…..…\My Documents\My Music\iTunes). Delete everything from iTunes there except files titled iTunes Library.itl and iTunes Music Library.xml. These are still needed.
on Jun 05, 2010 | Computers & Internet
MY USB port says reading when i connect a USB drive. WHy?
ANSWER: The USB is not going to work with your iPod. It is intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files.
REASON: The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
SOLUTION: You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
Good Luck! - Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Jul 15, 2011 | Dual Electronics XDM6350 Car CD/ MP3...
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
When I connect my usb to my ipod it just says "reading"..
ANSWER:
SOLUTION:
Good Luck!
- Chris Proia
Apr 09, 2011 | Dual Electronics XDM6350 Car CD/ MP3...
When connecting iphone in usb port, display stays reading and nothing happens on dual xdm6350
ANSWER:
REASON:
SOLUTION:
Good Luck!
- Chris Proia
Mar 23, 2011 | Dual Electronics XDM6350 Car CD/ MP3...
My dual xdm6350 won't read or charge itouch... It just says reading. Any suggestions?? Thx
ANSWER:
REASON:
SOLUTION:
Good Luck!
- Chris Proia
Oct 13, 2010 | Dual Electronics XDM6350 Car CD/ MP3...
Itunes messed up my external hardrive
I doubt that iTunes really moved/reorganized files on your computer.
iTunest may have created its own "Table Of Contents", presenting a "view" of all your files.
Open "My Computer" and open your external hard-drive.
The files should be in "your" order.
Open "My Documents". Open "My Music".
If iTunes really did "reorganize" your files, there's no way to "go back", because "Windows System Restore" does not automatically created time-stamped backups of your 'My Documents' folder (nor of any external disk-drive -- where would it put that much data???).
Jan 02, 2010 | Seagate Free Agent Go Small 12 GB USB...
When I plug my iPhone into the USB it doesn't
ANSWER: The headphone jack will not charge your iPod. Only the USB will charge your iPod. However, the headphone jack will play music, but the USB will not play music from your iPod.
REASON: The headphone jack does not provide any power to charge your iPod. It isnly has enough power to recieve a music signal.
REASON WHY YOU CANNOT PLAY IPOD THROUGH THE USB: The USB is only intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files. The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
TO PLAY MUSIC FROM USB (NOT IPOD): You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
SOLUTION: To charge your iPod, you need to plug it into USB. However, to play music, you need to plug your iPod into the headphone jack.
Aug 13, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
315 GB space available but can't add more data
Are the files that are on the drive all on the root C:\(or whatever letter it's using) or are they organized into folders such as Pictures/music/documents?
Second, what file format is the drive FAT32/NTFS(to find out right click on the drive in My Computer, left-click properties and in the window that pops up near the top you will see file system: _____
Answer back with that info and I will see what I can do to help you.
Chris
May 08, 2009 | Vantec NexStar-3 External 3.5inch...
Computers & Internet Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
