Question about JVC GD-V4211PCE 42 in. Plasma Television
We have a jvc tv with built in freeview ; yesterday we got the message on the screen pr list empty and now are stuck with 5 channels and no freeview ; how do we sort
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • JVC Expert
  • 158 Answers
What service company do you have for your TV? Is it dish network or direct tv etc. You can do a channel scan once you verify the service company. A cable service provider will only provide 99 channel to scan/sort while a satellite service provider will provide you more channels to sort/scan.
Posted on Aug 14, 2015
4 Suggested Answers
SOURCE: Lost ITV channels and C4
I have the same problem, can anybody help?
Posted on Jul 08, 2008
I've got exaclty the same problem :-/
HELP!
Posted on Nov 21, 2008
SD Tech
  • 14553 Answers
SOURCE: JVC tv stuck one channe
I would either call JVC to see if known issue or to inquire if set has a lockout feature that kills remote and all button features----other possible reason in main board with all micro functions has a problem.
Posted on Aug 27, 2012
My panasonic TX37 lzd 80 tv has on screen message no signal on some freeview channels and the picture is fuzzy
Change your main board but before check if the power supply is ok. Good luck,
Serge.
Feb 26, 2016 | Panasonic Televison & Video
We have not had this tv on since went over to digital freeview built in hopwever just put it on and there are no channels stored how do we get channels?
Hello
Your TV has to be initilized. It should be retuned to get the channels memorized in its memory section. Then only you can get the channels stored. Hopes that you have its remote control hanset with you. Replace two new cells in it and proceed the folloing steps. Connect ariel to its back socket before doing these.
[1] Press power button on the front panel of your tv. The initial setup screen appears.
[2] Press Ch+ on the remote control handset or on the front panel of your TV to start auto program, or Ch_ button to exit.
The initial setup screen will appear each time you switch on the tv until you perform autoprogram.
To perform autoprogram again
[1] Press Menu button.
[2] Press to highlight Channel Menu
[3] Press Pr Dn button to hilight cable. Press [+] to select.
[4] Press Prog Up or Prog Dn to hilight On or Off according to how you connected your TV. Press [+] to select.
[5] Press Prg Dn to hilight autoprogram. Press [+] to search for channels.
[6] After autoprogram finishes, press "Menu" again to exit.
TO RESET THE TV TO FACTORY SETTINGS
[1] Turn TV on.
[2] Press and keep hold the "Reset' button on the remote control hanset.
[3] Press and release the "Power button" on the TV front panel. The TV will turn itsef off.
[4] Release "Reset Button" now from your hanset.
These are the processes to be done to either autoprogram or turn it to factory settings. Ok.
Oct 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Samsung LE32N7 - Analogue channels ok - Freeview set top box ok- Tv's own digital tuner stuck on one channel (BBC1) in freeze mode - and won't unfreeze. Cannot access DTV menu- does not reset on power...
This is very common to a number of Samsung models built at the same time as yours and using the same in-built Freeview receiver.
There is no fix, the built in receiver is simply incompatible with the most recent updates to Freeview (as happened to many external boxes) and cannot be modified, the only puzzle is the length of time that your receiver kept going for. If your tv has a warranty still then you may wish to see if the fault is covered.
Without a warranty, all you can do is continue to use an external Freeview receiver. They're usually better quality anyway, and are easy to replace when they go wrong or become out of date.
Sep 17, 2010 | Samsung Televison & Video
Built in freeview doesn't work but digibox does
Have you done a channel search on both tv sources(atv and dtv). most new tv's will automatically start will "New Install". If you havent had a digital installed recently then this could the problem. set top boxes and TV's will pick up the signal ok but others wont.
Sep 16, 2009 | Hitachi Televison & Video
No freeview bbc channels
just solved the problem
with the variable attenator fitted i did a rescan still didnt work
but when i did a rescan to the restore factory settings it now works
Nov 24, 2008 | Televison & Video
RECORDING PROBLEM
Connectivity problem. Without knowing your models and their available channels etc., it's very difficult to advise you exactly.
Broadly though ...... you need to get the input signal routing sorted.
Plug your aerial into the Freeview box. Make a connection from its RF out, (beside the aerial 'in' socket) to the aerial 'in' socket on the JVC. Run yet another co-axial connection from the JVC RF 'out' to the television.
Now - connect a scart lead between the JVC and the TV. Power off the freeview. Switch your TV to accept A/V - to show the JVC on screen. Read/go through the 'Set up' procedure on the JVC to scan in the available broadcast channels. When done - connect using a scart between the Freeview box and the JVC. This will be located on either the L1 or L2 channel selection.
IF as it seems you are using the freeview to watch all your programmes - and record in then you are simply watching and recording 'live' change the Freeview programme and the JVC gets that same one arriving in (and sending to the TV)
Unless you need to record Freeview only output - always record from the aerial input. You select via the television remote (and 'TV' selected) and the appropriate channel.
Complex to explain - hope it helps. The one thing to remember - is to make one set of changes at a time - check the result is okay, before moving to the next.
Jan 07, 2008 | JVC DRMH20 DVD Recorder
Samsung Digital TV and Sony DVD Recorder
hi, did you find a solution? i have in built freeview and have bought a recorder but i cant pick up any freeview channels on it. the dvd recorder is a Wharfedale DVDRHD400 cheers tom
Feb 11, 2007 | Samsung 4 CHANNEL DIGITAL VIDEO RECORDER...
JVC GD-V4211PCE 42 in. Plasma Television Logo
118 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
