Question about Canon PIXMA iP6700D InkJet Photo Printer
How do I clean ink off of feed rollers? - Canon PIXMA iP6700D InkJet Photo Printer
    Champion:
  • 312 Answers
I use rubbing alcohol.
Posted on Jun 06, 2014
Black ink printing on back of paper
Your paper feed rollers have some black ink contamination: wipe the rollers, all around, with slightly moist tissue paper until there are no more ink evidence coming off the rollers. To moisten tissue, warm water with a very small amount of Windex, dish soap or rubbing alcohol does wonder.
Also clean gently around the bottom of the print head assembly to remove any obvious splatters.
Hope i helps.
Sep 26, 2011 | Canon PIXMA® MP530 All-In-One Printer
My pictures are coming out with pink or purple streaks. Every time I print a picture, the streaks are in different places, all going from bottom left to top right . I have changed the ink roll and the...
Try cleaning the paint roller.
6 Care and maintenance
Cleaning the paper feed roller To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the paper feed roller clean. Inspect the roller weekly for debris particles, and clean if necessary.
IMPORTANT: Unplug the power before cleaning the paper feed roller.
spacer.gif spacer.gif spacer.gif spacer.gif 1.Unplug the AC power cord from the power outlet.
2.Remove the paper tray from the photo printer, and leave the paper tray door open.
3.Lightly moisten a lint-free cloth with water.
IMPORTANT: Do not use cotton or cotton swabs to clean the paper feed roller.
autourg00462006id1604162.jpg 4.Use the moistened cloth to gently wipe clean the surface of the paper feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
5.Allow the paper feed roller to fully dry before reconnecting the power.
Click below for the complete manual:
Kodak EasyShare Photo Printer 500 Manual
Hope this helps.
Zeppelinx12
Mar 11, 2011 | Kodak EasyShare Photo Printer 500
Paper feed won't accept photo-quality paper - the paper feed action is not smooth - it will just about take 80gsm paper but not evenly and sometimes it feeds several sheets through at the same time. At the...
The paper pick up fingers and rollers get smooth and polished with use and then slide on the paper. Clean the rollers and pick mechanisms with isopropyl alcohol to rejuvenate them and restore their grip on the paper. Do this as far along the paper path as you can get, using Q Tips where necessary and turn the rollers to clean their whole surfaces.
Please rate this solution.
Mar 06, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Won't feed paper to printer
Its printer feed roller problem. Roller needs cleaning . Clean all the roller using cotton moist with cleaning liquid eg. Petrol , Spirit or even Nail polish remover. Clean all rollers properly . It will resolve your issue.
Sep 03, 2009 | Canon PIXMA MP470 All-in-One Printer
Splotching and spotting ink
The roller cleaning will require you to remove cover to clean the full roller with alcohol to remove ink build up. Have you tried to just run/feed a blank piece of paper through to see if you have roller ink roll off?
This also sounds like a bad cartridge with clogged jets...
Jun 15, 2009 | Canon i80 InkJet Printer
Epson CX7800 3 in one printer feeds mulltiple sheets.
This is usually caused by a dirty or dented feed roller.
The feed roller is the black wheel that has s flat side to it above the paper tray. Try using a Q-tip and some rubbing alcohol to clean it. Then give it another whirl.
As with the ink on the paper. This is usually caused by leaky printheads. Epson printers are notorious for having the printheads die on them, but usually from the ink drying out. Check and see if the bottom of the printhead can be reached and cleaned by Q-tip or cotton swab. Give it a good cleaning using rubbing alcohol. Don't go over board as the alcohol will dilute the ink.
Mar 28, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Paper jam, i have tryed every thing got new paper, didnt work...
Sounds like your machine needs new rollers.. pick up roller and feed rollers..
Or something is blocking the paper path?
Clean the machine
I would suggest removing the ink cartridge
get a lint free cloth, a can of air, some q-tips and flash light and a lint free cloth.
Open the machine and blow it out with a can of air,
Look in it with a flash ligth and clean with the cloth or q-tipw and a small drop of the alcohol.
Clean the rollers in there with the cloth a slight bit damp, you will probably see the cloth get dirty from this.
Blow with air, let it dry out a bit..
put the ink back in, start it up and try again.
I believe there is a button that will feed paper through. do that then go to your print driver and print a test page.
This is what I do with my ink jet printer and usually helps it. I have never replaced the rollers, but clean them once in a while..
I repair Laser Copiers and Printers.. I have no ideal where to get parts for an ink jet machine.. usually suggest to through them away as they as designed to be disposal..
I hope this helps..
Mike
Oct 25, 2008 | Lexmark Office Equipment & Supplies
Ink blots deposit onto feed rollers which in turn transfers to all new prints
Most likely you have a leaking print cartridge (toner cartridge). Does it have the same problem if you use the Manual Bypass tray?
It could also be a worn fuser sleeve that is causing the print defect...the fuser would need replaced in that case.
Sep 30, 2008 | HP LaserJet P2015n Printer
Paper feed skipping
You should be able to access most of the rollers that would need cleaning without dismantling the printer. Once you remove the paper, you should be able to see and clean the initial rollers. When you open the cover for the inkjet cartridge removal/installation, you should be able to clean the majority if not all of the remaining rollers.
Hope this helps you.
Jun 30, 2008 | Dell 922 All-In-One InkJet Printer
Paper feed
Keith,
You are going to need to change or try and clean the pick up roller and seperation pad.
Feb 15, 2008 | HP PSC 950 All-In-One InkJet Printer
Canon PIXMA  iP6700D InkJet Photo Printer Logo
old marine
old marine
