Question about Neff B1451 Single circotherm plus Electric Oven
Once the seletor is on fan there is no heat in the oven and i have already changed the element.Is it possibly a faulty selector switch.
  • Neff Expert
  • 414 Answers
It's possibly the switch, I would first check your connections to the new element, check there is continuity in the new element (just because it's new doesn't mean that it's not the problem). Check that the clock is set and not on auto. It could also be the oven stat, does the indicator light come on above the temp knob (if it does this is a good indication that there is power to the element).
Use the link, look at page 4, check there is continuity across part 057895 (next to fan). page 2 make a visual check of parts 167546 and 183598 for blows on the board or scorching on the switch.
Hope this helps and that it is something simple, best of luck.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=B1451W2GB%2f01&ESHOPTYPE=S
Posted on Aug 24, 2010
I have a Zanussi ZHQ575 X Double oven, the main oven will not work when I select the Fan Oven setting. I have tried a new selector switch but it still will not work on this setting. The fan comes on but...
I have the same problem.... It's not the element gents, please read the question again... the oven heats up on the other settings it's just when you select fan oven (the most popular) I too have tried replacing the selector switch with no luck. Really need a wiring diagram.
Apr 14, 2012 | Zanussi ZHQ575 Electric Double Oven
My oven does not heat up when in fan oven mode, the inner element does not get hot, the outer element does, Both elements get hot when using the main oven full width grill. ...
From your descritpion and if you already replace elements there are two options.
One is that there is an open curcuit either by a loose contact from selector switch to the elements this can be check with a mutlimeter.
The second option the selector switch itself is mulfuction and this normal after long time use since it consist with power contacts they fail to conect after long and you will need to replace it. If your familiar with electric then you can check it with power on and multimeter to see if it conects the elements or not. This operation need extra extra safety and experience.
We have here one side just to see what part you need the cooker selector multifaction switch
Aug 25, 2011 | AEG D5701-4 Electric Double Oven
Oven fan not working
If you select the function on the selector switch which turns both the fan forced fan and the oven element on at the same time and the fan does not work, but the oven element does then the fan forced fan is faulty and requires replqcement.
Feb 25, 2011 | Stoves 720EF Electric Double Oven
Upper and lower elements in my bosch HBE 632 elec oven work well individually but only the lower element works in dual element mode.
Hi.
If it is a fan assisted oven, and it is the fan oven you are referring to, then I would suspect the fan element to be faulty.
Assuming you are in the U/K, this should be located at the rear of the oven compartment behind a removeable cover.
Alternatively, it is possible that the selector switch could be faulty, but I would check all elements first.
Feb 15, 2011 | Bosch Ovens
The main oven, fan assisted, blew the fan element. I replaced the element but the oven will not heat up. I have replaced the timer assy. & the thermostat assy. but it still will not heat up. When the...
You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
Aug 14, 2010 | Hotpoint Ovens
My bottom oven isn't working at all but top oven/grill and hob is working fine
If nothing is working in the bottom oven (no fan, no light, no heat) then it is most likely the oven selector switch is faulty.
If you have a light and or fan and they are working, it is a failed oven element.
Jan 15, 2010 | Ovens
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Plz rate my solution
Thanks.
Dec 26, 2008 | Ovens
My neff oven b1664 rear fan element stays on after switched off
I suspect that the fan oven thermostat is faulty,probably a contact welded inside the stat.or possibly a faulty function selector switch.
If the fan is not running, then it is still getting a supply from the thermostat. Fit new stat.
Dec 11, 2008 | Ovens
Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Nov 23, 2008 | Neff U1661 Double circotherm super...
Neff B1451 Single circotherm plus Electric Oven Logo
490 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
