Question about Garden
I have an old Yard Pro lawn tractor - LT 12.5. that doesn't start. With the battery on the charger it still doesn't start. I turn the key and nothing happens. I'm sitting on the seat. It's in netural and the blade is disengaged. Suggestions?
    New Friend:
  • 24 Answers
Underneath the starter switch console there are 2 connectors
1-- fuse holder -- not sure of the amp of fuse , make sure it is not blown.
2-- there is a 4 pin connector that houses a relay , make sure that the connectors are not dis-coloured , if they are - the relay is bad
replace it
there is a small red or orange relay on the bottom near a side panel , the connector that is attached to it , should have 2 white wires connected to it .
dis-connect the connector and bridge the 2 crimp connectors
you should now be able to crank the engine over
i have done the same thing to mine , crank but no start issue, have to check for spark at the spark plugs tomorrow .
other wise it is a ignition control module failure
Posted on Oct 24, 2010
LT 1045. Why no start, no crank?
you need to replace your battery with a brand new one. because you old battery can not handle anymore the power it needs to crank your engine.
Sep 03, 2015 | Cub Cadet Garden
My poulan pro lawn tractor won't start. when i turn the key it click's 1 time can you help ?
Have you checked the battery terminal connections? Is the battery charged fully? Are you sitting on the seat when you try to crank the mower? Could be any of the above but most likely battery connection or the battery is discharged or old.
Aug 20, 2012 | Poulan Pro Lawn Tractor 2006 and Newer...
My Yard Riding Lawn Mower won't start when I turn the key on it just clicks
Click means solenoid has enough battery power but maybe not enough battery power for the armature of the starter to spin, it may be low battery or bad solenoid contact - inside it, (copper washer and pin), or thirdly it may be the engine is stuck so try to turn it a bit by hand to rule this out. Turning the engine a bit by hand may also free a starter gear that has jammed on the flywheel teeth.
Jun 30, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
My yard machine tractor does nothing when I turn the key. The battery is new. However the tractor is 12 years old. Could this be the alternator?
If it does nothing when you turn the key then replacing an alternator will not help. Numerous things could be causing this condition. I will try to cover a few. Make sure your PTO for the blades is disengaged and the clutch pedal is depressed. Make sure your battery voltage and all connections are good. Also make sure it is hooked up correctly. There is a fuse, usually near the solenoid, you need to check that. If all the above is good check to see if you have voltage going to the solenoid: There is a small wire that hooks to a spade terminal, you need to have 12 volts on this wire when the key is in the start position. If you do not, then you need to troubleshoot your safety switched. If you have 12 volts, then you may have a bad solenoid. Good luck, hope this gets you in the right direction.
Feb 17, 2011 | Yard Machines 155 Torque Briggs Stratton...
I charged the battery on my yard machines 12.5 riding mower but when I tried to start it I get nothing. The lights don't even come on in the accesory position
Did you charge the battery while stick conected to the mower? you may have blown the fuse that comes of the solanoid that will cut all power off usually founf under steering compartment
Dec 17, 2010 | Yard Man Yardman Riding Lawn Mower 38in...
Craftsman 54 in lawn tractor W/ 26 hp Kohler engine
Could be, but test each item with your tester. Test key switch (12V in and 12 V out when turned to start., operator present switch 12V in 12V out (seat) Clutch switch, etc. till finally you test for 12V on the small terminal on the starter solonoid. Happy testing!
Jul 19, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Will not start
there is usually a 20 amp fuse next to battery check to see if that is blown
Jun 28, 2010 | Husqvarna 24HP 54" Yard Tractor ()
Tractor wont start unless I jump it
How old is the battery? When you get it started put a digital volt meter across the battery terminals and with the throttle about 1/2 open check the voltage. If should be over 13 volts DC if your charging system is working ok. If it is over 13 volts your battery has probably just given up. Lawn mower batteries are only good for 2-3 years. A trickle charger can extend the life if used.
I hope this helps.
Jun 17, 2010 | Yard Machines 155 Torque Briggs Stratton...
I have a craftsman electric key start lawn mower. I used the key start twice and have charged it after each mowing, but now the key start won't turn it over.
the battery probably got over charge & shorted the cells the tractor should charge the battery as it runs if it was equiped with electric start the battery charger more than likely over charged it killing the battery
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro lawn tractor
There is a switch on the seat and one on the brake pedal
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
181 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
