Question about Standard Horizon Radio Communications
WHAT ANTENNA FITS A HX240V - Standard Horizon Radio Communications
Am/fm does not work on 2007 dodge nitro
Being that it works when real close to a station i would focus on the antenna. It could have fallen out of the back of the radio or broken. Either way the signal, unless very close to a transmitter, just isn't strong enough with "no" antenna. Try pulling the radio out slightly from the dash (special tool needed to unlatch it) and checking that the antenna cable is plugged in. If not then there's your problem. Otherwise you could stick a length of wire in the antenna hole to see if this improves reception. If it does then replace the antenna. If not then there is something wrong with the antenna socket on the radio itself.
Aug 13, 2014 | TPMS fits Dodge Nitro SXT 2007 OEM Tire...
Replacement Telescopic Antenna
See if this fits the bill. Otherwise stop in at a radio shack store. They sometimes have these n stock.
BuyTraxxas
Mar 01, 2014 | Radio Communications
Gs300 radio
You will have to special order the antenna for the Gs300. You can try the Lexus Gs300. I don't know if they do car installations as well but you can look into http://www.citywideantennas.com.au/antenna-installations-brisbane/.
Dec 30, 2013 | GPS
My stereo antenna wad stolen from my 2005 jeep liberty and I would like to get a replacement from the junk yard is there a vehicle that has an interchangeable antenna
Most Jeep models use the same antenna. As long as it wasn't a powered extending antenna, any Jeep antenna (and most other Chrysler) should work.
Best of luck.
Nov 05, 2013 | Cars & Trucks
Yes i order an antenna adapter for a 2005 dodge dakota.. The end that goes into the radio fits perfectly but the end that attaches to the antenna itself will not fit.. the antenna has a round black plastic...
The adapter is not exactly the same which is required.but yes you can get the external connection for adapter which will fit in adapter and also get connected to the antenna.You will have to get this external connection from
www.walmart.com or from
www.radioshack.com
check out.thanks.
Jun 05, 2010 | Car Audio & Video
I have a scanner and want to use another source for the same antenna is this possible
Antenna splitters are available to let you use more than one receiver on a single antenna with minimal signal loss. Grove Enterprises (http://grove-ent.com/) is one source, and a Google search should bring up others. Unless you're tapping into a fantastic outdoor antenna though, you might want to consider a low-cost indoor antenna such as this one that I found on eBay:
http://cgi.ebay.com/SNOOP-SCANNER-ANTENNA-FITS-UNIDEN-BEARCAT-police-radio-/150442224106?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item23070e29ea
Bill B
May 16, 2010 | Radio Communications
Standard Horizon HX 471. Antenna is to long to fit in Dive Canister. Can I removed antenna or replace with more flexable antenna?
Yes, as long as it is the right length and impedance, you can use a piece of wire! ... If you can get a smaller "antenna" and it fits, it will work fine. You could try disassembling the "Old" antenna, inside, you will find that a it can then be bent or such, use heat shrink to seal it, when modified.
Feb 26, 2010 | Standard Horizon HX471S (824 Channels)...
Hi antenna has low and very low signal. not able to connconnect as before. Unit is warm to touch. Q.do they wareout. it's about 2 years old thanks Peter
I think it's ok if there warm. They can handle the heat. You can however get a larger antenna in some cases if that bracket that the antenna fits on is a standard fitting. Most computer carry them.
Aug 02, 2008 | Computers & Internet
Radio Communications Logo
74 people viewed this question
Top Standard Horizon Radio Communications Experts
AnyMHz.com
AnyMHz.com
Norm Pearl
Clint Millett
Are you a Standard Horizon Radio Communication Expert? Answer questions, earn points and help others
