Question about Bosch Tassimo TAS4511UC Coffee Maker
Trying to repair the machine and need to know where the electrical hook ups go if looking at it from left to right...ie red wire small fitting, then black wire ect can you please help
    Problem Solver:
  • 5 Answers
Do you have the side panel off? mine is off. when i turn the coffee maker on its side (where you put the disks, is in my left hand) the only red and black wires i see are then on the right side, red firsdt then black. they plug in to two metal clips. while you are in there, where does the bronze tape go? it is used for the bar code eye. mine is off., that's why i'm on this site to begin with. hope this helps.
Posted on Mar 28, 2011
Im in a apartment just moved In and the honeywell thermostate im replacing with a hunter brand, non-programmable thermostate, there was only 3 wires hooked up, out of the electrical wiring theres a red...
Need to know if you have central air as well. If you don't, then hook up the Red to R, White to W. you @ least have heat. any other wires you hook up will be dependent on what type of system you have ie boiler, forced air, etc.
Oct 26, 2013 | Heating & Cooling
What's color code for wires in back of dryer
Yes, here you go.
You should have 3 or 4 wires on/in the electric wire from the socket to the back of the dryer.
Open the plate and look at where the wires go to be hooked on.
You will see 3 screws or nuts in a row, left to right.
Carefully loosen these nuts or screws, be SUPER careful not the get them too loose, or they will fall off, sometimes down inside the machine.
Your electric cord has 2 hot wires, they are black and red.
These hot wires go on the right and the left screws, or nuts, but absolutely NOT in the middle!
The hot wires are interchangeable, the can go to the right or to the left.
You should also have a white wire in the cord, and that one, which should be in the middle of a 3 wire cord, attaches in the middle.
It is a ground.
If you have a 4 wire cord, you will have another wire, maybe blue or green.
That attaches to the case or the body of the dryer.
If your dryer has an extra green wire that comes from the inside and is fastened under a screw, that is where the 4th wire goes.
Be blessed.
Mar 03, 2013 | Maytag Neptune MDE5500AY Electric Dryer
I have a jvc kdavx1 trying to hook up to a 2000 buick reagal need to know how the wires hook up
Please let me know if you have questions, and thanks for using FixYa.
2000 Buick Regal Car Stereo Install Diagram jvc kdavx1
Radio Constant 12V+ Wire: Orange yellow
Radio Ignition Switched 12V+ Wire: Yellow red
Radio Ground Wire: Black/White black
Radio Illumination Wire: Gray/Black orange/white
Left Front Speaker Wire (+): Tan white
Left Front Speaker Wire (-): Gray white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Dark Green gray/black
Left Rear Speaker Wire (+): Brown green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Dark Blue purple
Right Rear Speaker Wire (-): Light Blue purple/black
parking brake: blue light green
For this last wire, access the back of the parking brake to find a switch with a blue wire. Peel some insulation from the wire and wrap the stripped end of a 3 foot piece of 16 or 18 gauge wire around the stripped section. Solder and wrap the connection with electrical tape, route the wire to the jvc, then strip and solder the other end to the pigtail of the head unit.
If you are also installing a camera seeing behind you when backing, you will need to run a wire to the back-up light on the driver side reverse light (light green) wire along with your video cable.
May 30, 2011 | JVC Car Audio & Video
I need to know how to hook up an alpine CDA-9833 stereo into a 1993 dodge dakota without a wiring harness i just want to hook the wires together and i dont know which wire goes to the other all the colors...
Please let me know if you have any questions, and thanks for using FixYa.
1993 Dodge Dakota CDA-9833
Car Radio Battery Constant 12v+ Wire: Red yellow
Car Radio Accessory Switched 12v+ Wire: Red/White red
Car Radio Ground Wire: Black black
Car Stereo Dimmer Wire: Orange (tape this wire off) none
Left Front Speaker Positive Wire (+): Blue/White white
Left Front Speaker Negative Wire (-): Black white/black
Right Front Speaker Positive Wire (+): Purple gray
Right Front Speaker Negative Wire (-): Green gray/black
Left Rear Speaker Positive Wire (+): Black/Yellow green
Left Rear Speaker Negative Wire (-): Gray green/black
Right Rear Speaker Positive Wire (+): Blue/White purple
Right Rear Speaker Negative Wire (-): Blue/Orange purple/black
May 09, 2011 | Alpine Car Audio & Video
Looking for wiring diagram for 1988 escort 1.8 tdi. need to fit cd/radio existing wiribng just on chp block..
you need a volt meter and 9v battery. earth black contact from meter & then
  1. with ign off probe wire to find a live , thats the memory feed goes to yellow on radio
  2. with ign on probe wires that the constent live goes to red on radio
  3. when lights on probe wires thats the illumination feed (if fitted to car, but not used on many new radios
  4. then get 9v battery and with remaining wires pair and connect to battery, when speaker buzz's mark pair as they are ( ie front right rear left etc ) the speaker wires from the new radio are paired by colour ( one with black stripe with is the negative of the pair)
  5. there should be a ground/earth which if you cant find just hook one to the body/chassis
Jan 03, 2010 | Car Audio & Video
What wires on the blower are power need to know what colors to hook up to run 120w
The wires to your blower are connected at the control board. To hook up a 120V to the furnace, on this model, is located on the left hand side of the burner section. There is a black and white wire in a small 2"x 3" box. The control board selects which wire to power the motor depending on what mode you are in.
Oct 03, 2009 | Goodman GMS90703BXA Heater
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Jul 15, 2009 | Video Game Consoles & Games
Electric cord hook-up
White wire connects to the neutral (probably the center terminal), red and black to the most available terminal after the neutral lead is connected. Green wire is for ground... There should be a ground screw in the connector panel, but if not, be sure to securely attach the Green wire (ground) somewhere on the frame of the dryer. Be sure it makes connection with the metal (i.e. scrap off any paint, etc., where the terminal will be attached).
Jun 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I need to know how wires on the power cord connect
Red on the left.
White in the middle.
Black on the right.
Green on the case/chassis ground or green screw with the small dashes on it.
If you don't have a white wire but the the green in the middle position.
White/red = far left
Green = middle
Black = right
Jan 29, 2009 | Roper REX4634KQ Electric Dryer
How to hook up my stereo
I hqave taken the time to look this up, please take a few seconds rate the solution, thanks.
1995 Honda Civic Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Jan 06, 2009 | 1995 Honda Civic
Bosch Tassimo TAS4511UC Coffee Maker Logo
339 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Kolbrun...
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
