Question about Samsung RS2630SH Side by Side Refrigerator
Fridge freezing over causig problems for motor
  • Samsung Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 23, 2010
I have a westinghouse frdge freezer bj 385 motor constantly running with the door close motor stops intermidently open door motor stops recently moved fridge
Hi Peter, It it's not freezing the fridge up then it needs regassing but it it's freezing the fridge up then could be the thermostat, Good luck mate..... CHEERS..
Apr 04, 2016 | Westinghouse Refrigerators
Very noisy fridge, back wall freezing up
Possible bad freezer fan motor. I need more information such as brand and model number
Mar 10, 2014 | Samsung RS2630WW Side by Side Refrigerator
Fridge partly freezing at top and bottom , middle staying neutral, why?
Check your evaporator fan motor also make sure there is no obstructions such as plastic bags blocking air flow.
Aug 02, 2017 | LG Refrigerators
I HAVE WHIRLPOOL ET4WSKXKQ05. FREEZER STARTING TO GET FROST AND FREEZES, BUT NOT COMPLETLY. THE FRIDGE PART IS GETTING WARMER DAY BY DAY.
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this will help to solve then problem..
Aug 14, 2011 | Refrigerators
The Whirlpool fridge part of the fridge /freezer is freezing up it should be an auto defrost and the only solution at moment is to switch it on and off.please help Allan
Hoping that this will help to solve the problem of the refrigerator...
Aug 08, 2011 | Whirlpool Refrigerators
Kenmore 596 - temp control panel not responding when up or down buttons selected. Fridge too cold. Freezing items in fridge after power outage last night.
Okay, hope this will help in solving problem
Aug 07, 2011 | Kenmore 26.0 cu. ft. Side-By-Side...
My amerian fridge freeze the fridge is frezzing everything
Good luck in solving the problem as you read the above information to get your fridge freezer back again...
Jun 23, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge monogram refer/freezer not freezing or cooling
could be 3 things 1,the thermostat could to faulty ,2,the system might need gas pull the fridge out and check the motor at the back if its red hot gas would seem to be the problem 3, also with the fridge pulled out if the motor is stoppping and starting the motor windings are gone ,replace the fridge , no quick fix with this problem sorry
Mar 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezing frosting fridge
i had the same problem recently with all my fridge food freezing up, this all seemed to start when i discovered the interior bulb blown i replaced it still nothing also noticed warning lights on front out,i could hear the motor going so i knew it was on i removed back cover and found the heater covered in ice it turned out it was the failure of the control board causing these problems had it replaced and working fine now hope this is of help dmb23
Jan 10, 2009 | Candy CPCA240FFK Bottom Freezer...
Fridge is not cooling or freezing
can you tell me the model # on the fridge please? the motor is running continuously because it's trying to cool the fridge. it may be a few things, the defrost thermostat, the fan motor itself or the compressor.
Sep 13, 2008 | Magic Chef Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
55 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
