Question about Amana Refrigerators
Our 5 year old Amana Refrig has developed a new & strange noise in the last few days. Mod ARB2557CW, Mfg PARB2557CW0, S/N 10918811CV. Only happens when compressor is running. The noise is a faint sympathetic vibration which starts, continues awhile (say 17 seconds) then shuts off abruptly (like someone flipped a switch) all while the compressor is still running. It can repeat this cycle more than once during a compressor run. We never hooked up the ice maker. P.S. Killing power to the refrig also kills the vibration sound. Restoring power can restore the vibration sound. The refrig is the only load on this breaker.
  • eclester Aug 24, 2010
    The compressor and fan sound quite normal.
    As I explained the strange noise comes ON at random intervals for approximately 17 seconds, then shuts OFF like someone flipped a switch. I am not sure but the strange sound may occur even with the compressor not running. Since my original post we have discovered the freezer compartment is not holding cold temperature, i.e. the ice cubes have melted. Is there some kind of defroster that could be running applying heat to the freezer and other compartment in 17 second long bursts?
    I entered an extensive reply to ovoblow11 and it apparently got deleted by your system.
    Would ovoblow11 please advise me if he,she or it, received my reply to it's solution?
The noise you hear is most likely the self defrost cycle. Have the evaporator motor checked out. Deforst the refridgerator for twelve hours and then check to see if the noise goes away
Posted on Aug 24, 2010
    Genius:
  • 1,478 Answers
The problem may be caused due to a damaged noisy refrigerator compressor. A compressor is a single part, without any other moving part and is football sized. It is usually black in color and situated at the bottom with some tubes or wires attached to it. If this compressor is making noise, which will generally be loud enough, it needs to be repaired by a professional. The compressor might also be needed to be replaced and of course, it is quite expensive.
The next cause of noisy refrigerator can be the condenser fan. Dust and debris can jam the fan blades leading to improper functioning of the fan leading to a noisy refrigerator. Generally the fan is covered by a thin panel. In order to fix this fan and hence the noisy refrigerator, first of all unplug it. Now remove the panel and clean the blades using a small cloth or a toothbrush. If you find that there is no lint or debris collected over the fan blades, its motor needs to be replaced.
Take care.
Posted on Aug 23, 2010
  • Jimoh Adeleke Muyideen Aug 24, 2010
    Check the thermostat for temperature setting. Make sure your freezer is
    not too stuffed and that there is enough space for air flow. Check for
    the restriction of air flow in the vents. Clean the coils of the
    condenser if found clogged. Also look out for clogged drain tube and if
    there is a leakage of the refrigerant. Test various components such as
    temperature control knob, evaporator fan, defrost timer and the door
    switch.
I have acquired an Amana refrigerator, I want to know its date of manufacture. The Model is: TLI18G-W The MFG. no. is: P75535-11WW The Serial no. is: CF35126376-8 Can you identify the age of the...
Hello Tom,
I can not a defintive date based on the data you provided ( mod./ser.&and mfg#'s) but a seach of the parts breakdown tells me it uses R-12 refrigerant so based on that alone its older that 1995 since in 1995 all refrigerators switched to R-134 refrigerant.
For many applince 15 yrs plus they are on their last leg.AMANA was a quility built appliance and just in its infant stage. Just remove the kickplate and clean the coil under it every 6 months it should serve you for many years
Gene
Aug 20, 2011 | Refrigerators
Amana ABB222DE is the overload/capacitor the same thing as the compressor relay? I just had the compressor relay replaced in amana bottom mount. Frig cools fine but every 2 days or so buzzing noise...
I have been doing refrigeration for over 30 years and I have never seen a compressor with a chip inside of it. Have you tried cleaning the condensor coils? I almost sounds like you have a weak start capacitor. Let me know if i can help you any futher.
Apr 24, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
11 year old amana bottom freezer icemaker drips water when filling tray
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
Sep 26, 2008 | Amana ABB1927DE Bottom Freezer...
Have Amana refrig with bottom mounted freezer Model ARB2217CW. Noticed the last day or so it makes a buzzing noise--almost like an electric shaver then it shuts off with a click. Today items in freezer...
See the post by lola77 with the same complaint. We have an Amana top/bottom freezer and are having the same problem and we've only had it 4 1/2 years. First service call available that the 1-800 number gave me was 3 days from now, which is ridiculous.
Aug 27, 2008 | Amana Refrigerators
Kenmore Frig 59658692890
ok there's a handle in the ice maker 1 position turns it on another turns it off just do that and the ice should stop coming down if it dosent just remove the water connection to it
Apr 07, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Sub-Zero 550 Fan Vibration
you could try taking the fan assembly out and adjusting it or oiling it, sometimes it gets that back pressure when the door is closed because it has to work harder
Jan 20, 2008 | Refrigerators
Noises
Hi , small fan motor inside the infeller was touch to the build up of ice., it need to manual defrost to lesser the ice inside .
Jan 16, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Amana Side by Side Refrigerator not getting cold
amana is having some problems with their compressors locking up. if the compressor is manuactured by tecumseh then tthe compressor is mostlikely locked up and will need replacing. good news is your refrig is most likely less than years old and should be in warranty to amana..
Dec 15, 2007 | Amana ARSE66MB Side by Side Refrigerator
Refrigerators Logo
64 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
