Question about LeapFrog Tag Reading System w/ Bundle
Volume does not work... you can only hear it if you hold it right to your ear. What can we do to fix this problem... pen is not a year old.
  • keeseyj Aug 23, 2010
    Batteries were changed and are new. Is there warrenty on the pens.. if so, I'll see about exchanging it.
    Can you buy just the pen alone? If so, where? should I have to replace it.
    Brigadier General:
  • 5,158 Answers
First thing to try is removing the battery for about ten minutes to reset the device
Posted on Aug 24, 2010
  • 3,083 Answers
Has the volume been good before? Here is an excerpt from a review on Amazon.com:
CONS: The TAG EATS batteries. Be sure to have a supply of AAA batteries on hand. The volume could use a boost; my daughters are sometimes holding the pen to their ears in order to hear the narrative (they're not too fond of earphones, so that's not an option for us).
If the volume was higher before, chances are that the volume control is bad. Not sure if you could get replacement parts, but you could try to contact them. Here is their support page:
http://www.leapfrog.com/en/pages/support.html
Wish there was a simpler answer for you. Good luck, thanks for using FixYa, and good luck.
Posted on Aug 23, 2010
My right hearing aid is 4 momths old and it stopped working
The Bolero model requires clear passage of sound through the tube that connects it to the dome/tip that fits into your ear. To determine if the tube is blocked, with a good battery inserted and the battery door closed, unscrew the top of the tube where it connects to the hearing aid. If you cup the hearing aid in your hand, it should whistle/feedback. If not, there is something wrong with the hearing aid. If it does whistle, your audiologist should have provided you with a thin, flexible plastic piece (often green) and instructed you how to unscrew the tube at the top of the hearing aid to run the plastic piece through the tube, all the way out the other end of the dome/tip. If that piece can travel the entire tube easily, then sound should be able to. In any case, a Phonak hearing aid has at least a one year manufacturer warranty (a Q90 likely has a three year) and they will pay for shipping both ways to fix it. You need to send it via an audiologist, though.
Jun 08, 2014 | Phonak Bolero Q90 BTE behind the ear...
Turned up full volume u can only just hear sound if ear right to it was working fine then the volume just ******** out
It could be the mic plug. uniden is known for the issue where the wires inside the mix plug break at the solder joints.
When the RX wire breaks, you will loose receive because the radio will not go into receive mode. But you can usually hear it ever so slightly if you crank the volume.
Other issue that may cause this. No radio activity, (unless you hear radio activity low and not static)
poor feed line or antenna.
I would try a different mic that is known to work.
Aug 11, 2012 | Radio Communications
Philips DCB146 NO SOUND!!
The answer is straightforward. The main power amp has gone. If you are lucky it's a single IC unit which you will find on a big heat sink. It might look like the one shown below.
You will of course need to de-solder it and resolder a new one. The type needed to replace it will be shown by the letters and number on the IC itself.
May 02, 2017 | Audio Players & Recorders
NR26WLB520HD Volume has just stopped working??
Its a Beko-----check for feature in Menu to turn speakers off and if speakers are NOT switched off you have a audio circuit problem.
I would also put my ear right to the speaker and see if hear ANYTHING.
Mar 12, 2012 | Beko Televison & Video
Cant hear when others call neither i can hear when i call but they can hear
Hello,the problem you are experiencing could be caused by two things,
1.Bad ear piece:this could be fixed by replacing the bad ear piece,you can get it fixed either by getting the ear piece parts from any phone accessories stores and fix it your self,or you visit a mobile phone engineer to fix it for you and your phone would work perfectly.
2.ear piece volume low:this could be fixed by dialling a number on your phone screen,then tap on the botton on the right side of your phone,ensure you tap the upper arrow to your desired volume level.
wish you good luck,
take care.
Aug 01, 2011 | Nokia X3 Cell Phone
My mother in law is very deaf in one ear and has poor hearing in the other. How can I tell if her own hearing is at fault or her hearing aid battery needs changing or there is some other fault causing her...
I have a similar issue with my 86 year old mother-in-law and her hearing aids. Depending on how long they are worn/turned ON, determines how long the battery in each one will last. In my mother-in-laws case, she waits to long to change the batteries or doesn't keep the volume turned up high enough. So, in her case, the battery(s) get weak, before she realizes it. The other thing that is most important is when we age our body (ears in this case) physically change and the hearing aid(s) that were originally fitted several years before, don't fit as well as they should. I am also convinced that their hearing continues to deteriorate and they should be tested and fitted with a new hearing appliance, as needed.
The down side to this, is that hearing aids are not inexpensive. So, if Medicare, Medicaid or their own private insurance want cover at least part of the cost, most people don't want to pay for new ones. Or as my mother-in-law says, "Oh, they're working alright." When in fact, they're not. My wife and I can tell by the volume on her TV. When you can hear it from one floor to another, her hearing aids aren't working right.
Apr 11, 2011 | Health & Beauty
Ear piece is really low, can hardly hear the caller
You can increase the ear piece volume when on call.When you are on call push the joy stick to right to increase the volume and left to reduce volume.
Thanx
Jul 21, 2010 | Sony Ericsson K320i Cellular Phone
Missing 2-Ear Gels
We only provide tech user support, we do not intervene with a supplier.
Oct 22, 2009 | Jabra Bluetooth Headset with Adjustable...
Turtle beach x1-other people can't hear me
check if any of the wires are loose inside the thing that turns up the volume. the left and right ear wires are inside of that. i had the same problem with the right ear, all i had to do was solder the wire back on the chip.
Jul 25, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
I can't hear out of my earphone's right ear?
get ather pair of earphones, check if ipod is the source of problem or simply the cable of your old phones is broke, to fix that you'll havebe familiar with fusing
Jul 23, 2009 | Audio Players & Recorders
LeapFrog Tag Reading System w/ Bundle Logo
210 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
relojmesa
thegtw
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
