I was using the computer and monitor was working fine. I came back later and monitor was black. I turned it off then back on and it says no signal.
    Problem Solver:
  • 15 Answers
It sounds like your computer may have went into "sleep" mode. Try turning your monitor off and on again as well as turning the computer off and on. This should "wake" it up again.
Posted on Aug 23, 2010
Asus crosshair socket am2 motherboard not booting
Sounds like your monitor is bad. Try another monitor because if the video card was bad and the monitor is working you would get a No Signal message on the screen. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original monitor is bad. If the Borrowed monitor does the same as your original monitor and does not display anything, then there is an issue with your video card.
May 13, 2012 | Computers & Internet
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
I hooked up the monitor and it says "no signal in
Your computer is set to a resolution too high for the display. You have to reduce the resolution to 1024x768, then plug the monitor back in.
Apr 25, 2011 | Gateway FPD 1540 (Black) 15 in. Flat Panel...
I have a problem with my monitor not coming back on after a power interruption or after a auto update and restart of the computer. I was having some small success with turning off computer and monitor and...
It could be a cable problem but more likely to be in the power saving settings on either the monitor setup or the computer. Remember when you plug in a different monitor windows knows about it and adjusts the settings to suit. It may be that windows is using the incorrect wakeup signal for that monitor. check you have the correct driver installed.
Oct 24, 2009 | Westinghouse L2046NV Monitor
I get "No Signal" shortly after the computer is turned.
there is a problem by the programming chip insifde of monitor. It can be faster fixed but only by an expert. If i've help you, please rate me! Thanks
Sep 15, 2009 | Acer AL1916W 19" LCD Monitor
Computer monitor screen stays black
please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
Jun 02, 2009 | LG Flatron L1710S 17" LCD Monitor
DVI won't work
WOW! I have that monitor too on one of my systems!
Strange thing is it HATES the SVGA connection ~ but works FINE with the DVI... wish I could tell you why?
I've tried a array of 'new drivers' but none help... STRANGE thing too is OTHER monitors work FINE (with the VGA port) so I'm fairly confident it's not that...
I CAREFULLY inspected the pins on the male connectors to assure none are pushed back into the connector body and tried new cables too... still NO GO?
PLEASE let US know if you found a solution!
Anthony
Dec 12, 2017 | Samsung SyncMaster 214T Monitor
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
No Signal when desktop wants to load
It does not hate that monitor. I believe the problem is in the settings on your video. Your monitor cannot display them. You will most likely need to start your computer in safe mode and change the display settings on your video card or, alternatively, download updated video drivers. Also, if you can't get Windows to start in normal or safe mode, one of the options you get when you press F8 on startup is to start in VGA mode. That will get you in so you can tweak your settings, which are probably set to a resolution too high for your monitor.
Sep 11, 2008 | ViewSonic VA1916w LCD Monitor
Computers & Internet Logo
David Payne
David Payne
