Question about GE Nautilus 24" Built-in Dishwasher
Will not engage in cycles, fills with water but will not drain
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Aug 23, 2010
My Simpson Eziset 550 will not drain after a (normal) wash cycle. When the drain hose is lowered to the floor drain water flows heavily from the hose (gravity). When the hose is returned to the sink d
Hi Erin just read your post,I have worked on these machines alot.Now I need you to manually drain the machine of all the water. Once drained i want you to select drain and spin cycle. Now push the start button,do you hear the pump working?If you do stop the machine and select normal cycle on small water level and push the start button.The machine will then fill.Once it stops filling stop the machine and select drain an spin cycle.Does the machine pump out? Now if you do not hear the pump, could be the pump is faulty or jammed.Does the water flow very fast when you lower it to the floor? Please reply with answers to these questions and I will try my best to help you.
Jan 25, 2014 | Washing Machines
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Samsung Dishwasher (DMR57LFS): Error code oE. Fills...fills some more...then drains.
Samsung Dishwasher 0E Error - We had other appliances on that circuit. We believe when those appliances were turned on it created an undervoltage condition in the dishwasher, causing another sensor to send the high level error code 0E. We believe this is the problem because it only started after we added the new hot water dispenser on the same circuit. The problem went away when we leave it off for the whole dishwasher cycle. I'm guessing it could also be caused by brown-outs and other large electrical loads cycling in the same household. That's the theory anyway. The folks who sold us the dishwasher suggested turning off the breaker, to reset the computer. Good idea, but not for our particular case.
Nov 14, 2011 | Samsung DMR57LFS Stainless Steel Builtin...
My washer fills and runs tru the washing cycle then stops. It won't go thru any other cycles, won't spin and does not make any noise. Is it the timer?
Does it drain?? If not then you need to replace the pump. The pump drains the water hence allowing the spin cycle to engage. Sorry for the bad news.
Oct 17, 2009 | Washing Machines
Washer is draining as it's filling -up. Checked all hose there on and no leaks coming from them. Could it be the plastic pump?
This could be a simple matter of drain hose placement. What it sounds like you are experiencing is known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Double check your drain hose placement and the size/height of the standpipe. If you don't have a sufficient air gap, your washer will begin to siphon water from the tub as it fills. The drain pump cannot cause this problem on the fill cycle as it is driven by the drive motor. The drive motor will not engage until the washer is filled and the wash cycle starts.
If you have questions, please let me know. I hope this is helpful.
Aug 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
WASHER FILLS WITH WATER,MOTOR ENGAGES AND RUNS SMOOTHLY,BUT NO AGITATOR ACTION. WILL GO THRU TIME CYCLES AND FILL WITH AND DRAIN OUT WATER BETWEEN CYCLES. JUST NO AGITATOR. iT WILL SPIN DURING THE SPIN...
Sounds like you motor coupling has broken. The water pumps out so that tells me the lid switch is fime and motor is fine. The drive coupling mounted between the tranny and motor is probably broken
8a0970d.jpgI have a page with pics and movies to give ya some ideas what to do. HERE
Mar 11, 2009 | Washing Machines
Will not fill with water and the tablet does not drop it starts up and then just stays on that same cycle position
yakers hope you can read this too the first thing dish washers do when you turn them to start is drain to get any left over water in the sump out then they fill then start wash cycle bazamoza id say you have a bad timer motor you can advance it manually one click at a time if you hear the water valve kick in then replace the timer if not reply to this post for further action
yakers check the float in the tub to make sure its engaging the safety micro switch pull the kick plate off at the bottom and find the rod from the dome in the tub and see if its engaging the micro safety switch that keep it from over filling
if all that's good then reply to post
Sep 11, 2008 | Dishwashers
GE Nautilus 24" Built-in Dishwasher Logo
59 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
