Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
My cap on the tank of my unit does not seal also I have difficulty getting the pads that came with it to stick to the mop.
  • Euro-Pro Master
  • 43,501 Answers
You can buy a new cap from the manuals link...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 24, 2010
I have the original H20 Mop. The light comes on, I feel the motor humming but no steam.
Hello, this is Ava with Think Crucial.
The are a number of reasons why your H20 mop doesn't steam. Ensure that the water tank has correct level of water. Check if the Steam Nozzle has a blockage and clean if it's necessary. Also, check for limescale deposit and removed it. You may refer to your unit's manual for procedures to remove limescale.
You can purchase a wide variety of high quality replacement microfiber mop pads for your H20 mop from ThinkCrucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=h20+mop
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 16, 2016 | H20 Vacuums
Do disposable pads stick to plastic mop head, or onto mop?
  • If you are taking about a dust mop it goes on the connection to the rod if its a wet mop like shark or quick brooms it goes on the mops head.You will see 4 holes on the corners of the mop.Place the corners there.If this answer doesnt help please tell me and also provide more info about the type of mop it is.
Dec 19, 2015 | Vacuums
Shark Euro Pro Steamer
Hi, you could try the following steps, if you have not done so already. Some of these steps may seem like common sense, but it's for people to forget about checking the least expensive part to replace first, so if some of the steps are those that you have already tried, then feel free just to skip through to the ones you have not tried already.
  1. 1
    Make sure the power cord is plugged firmly into the outlet. The steam mop will not start if it the power cord is loose.
  2. 2
    Check the fuse box or circuit breaker connected to the outlet the steam mop is plugged in to. Replace any blown fuses. Reset any tripped breakers.
  3. 3
    Check the water tank if the Shark steam mop will not produce steam. Add water to the tank if it is empty. The mop will not make steam without water in the tank. To fill the tank, turn the tank cap counterclockwise and lift it up to remove it. Set the filling funnel into the tank opening. Pour water through the funnel into the tank until the water level reaches the "Max" fill line on the tank. Replace the cap.
  4. 4
    Inspect the microfiber cleaning pad if the steam mop is leaving water on the floor. If the microfiber pad is too wet, it will leave water on the floor. Unplug the mop from the wall outlet. Replace the microfiber cleaning pad. To replace the pad, move the latch strips out of the hooks on the mop head. Pull the pad off. Set the new cleaning pad on the mop head. Hook the latch strips onto the hooks on the mop head.
  5. 5
    Use distilled water if the steam mop is leaving white spots on the floor. Hard water may cause white spots to be left.
If none of the above work, then is it something that you purchased recently, and is new? If you did, then it could still be fixed under the manufacturer's warranty regardless of whether or not the original length of the warranty has expired. This could be due to the fact that you have received a product that has some sort of manufacturing fault, rather than it stop working through misuse by the user.
If it's a common problem, then you will more then likely be able to return it to the manufacturer and have it replaced for a new one, let alone repaired :-) - This only applies to whether or not the item is New though :-).
Hope this info helps
Apr 29, 2013 | Vacuums
I got power, lite on, tank is warm, but No Steam to mop pad, just a little water to wet the pad. Whats wrong?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Dec 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My mop (purple) is not steaming the bad. The tank gets super-hot (burned my hand lifting the mop) but the steam won't go down into the pad. Very mad I paid over $100 for this thing.
heatman101
Nov 29, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Where can I purchase a cap for the water tank for Shark steam mop model S3101?
Click on the manuals link the caps are sold there...
heatman101
Aug 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Lost the cap to euro prox steam mop model s3101 water tank
News caps are on the manuals link..
heatman101
Mar 28, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam is forming and coming from the water tank of the mop not down below from the pad area. Is it clogged?
heatman101
iy
Oct 09, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Stopped steaming only releases water into pad
heatman101
ag
Mar 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
78 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
