Question about Nintendo Wii Console
I want wire less internet - Nintendo Wii Console
  • 864 Answers
I can assist you with this. Just follow the steps i have provided and if they do not help or you have trouble with certian steps let me know and i will be glad to assist you from there. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Posted on Aug 27, 2010
I have a Sony bluray with built-in WiFi and I show I have internet connection, but when I try to watch Netflix I get a message stating not connected and invalid information and data. Is there a step or...
Are you using wifi connection, or hard wire? If you are using wireless, there is a possibility that, while you can connect to the router, the router it's self is not connected to the internet. Please check if your router has internet access, then, if you are using wifi, I would suggest hard wiring directly to your isp's modem using a "cat5" or Ethernet wire. Less lag streaming movies, and while playing games. And wired connection will always be faster than wifi.
Jul 02, 2014 | Video Game Consoles & Games
I could not connect to internet with my sony bravia kdl 32ex520 I am using the ethernet cable( no modem) when i check the status it is showing as cable is connected and internet is failed error 1106 i...
Ethernet connections between the tv and the computer into one signal frequencies are not compatible signals.Ur main home computer have internet service connection go through a wire or wire less Router for a internet signal through out the house.Connect the tv internet signal through the Router.Internet signal will work fine.
Aug 18, 2011 | Sony KDL46HX800 46 in. 3D LCD TV
Can not sing in the first time ! I have internet , is my 360 wirless internet connection or do i have to wire it to my modem ?
Best bet is to wire it directly to your modem, as this has less signal problems then a wireless modem. Also, make sure you troubleshoot your Xbox if it fails to alter any settings you need to. It should auto detect settings. Make sure that your modem's firewall is not blocking your Xbox from accessing the internet.
Oct 28, 2010 | Microsoft Xbox 360 Console
Error code 52030 Unable to connect to the internet. Nintendo wi-fi usb connector
the Wii may not allow the usb since you may not have a wire-less internet so the usb may work fluently but a router is required
Sep 30, 2010 | Nintendo Video Game Consoles & Games
Wii internet
If you have a wireless router and there is no security, you just go to wii settings, then internet, and search for a access point. If you do have security it will ask you for the security id of your router, if you don't know it contact whoever setup your wireless router.
May 10, 2010 | Nintendo Wii Console
Wii internet
1- activate connect24 from the wii settings then add a new connection either wireless or another type.
2- make sure its connected by going to the wii shop channel.
Apr 17, 2010 | Nintendo Wii Console
I had ACER ZG5 note book. How can I set up a wire less internet connection on it?
you need a wireless router to connect via router. just put your internet/broadband/modem cable in WAN port. and then you'll be able to connect via wireless.
regards
Best of Luck
Nov 03, 2009 | Acer Aspire One A150-1006 Notebook
It's possible to use the web cam in the lap top toshiba satellite 210cs and how?And it's possible to get acces to the wireles net and how?
hi...the answer the web cam is yes...u can do try input the USB web cam and install the CD drivers...the answer about of wifi/wire less internet Yes..if u have wire less LAN u can do it try to access find the switch button on side the body of unit..if u have no wire less LAN u need to buy wi fi/wire less LAN for laptop..thanks abd good luck..have a nice day..^_^
May 17, 2009 | Computers & Internet
I cant get my internet on me vista laptop to work. i have two wire computers and one wireless and the second wire computer makes the laptops internet shut down and when the laptops internet works the wire...
Ok here is the big question what make and model is your router. Anything less than an "n" class router is going to gang up on itself. Also depending on your internet service provider or "isp" and the speed that they provide makes a difference. I find that it is the lower grade g-class routers that have the most trouble. Take care...Be mucho blessed...Mark
Jun 28, 2008 | Computers & Internet
Wired and wireless computers
First get your router works with the internet on the wired connection before considering the wireless connection simplying the initial problem.
Once the router works wired is time to try the wireless.
Once the wireless works unsecured you may want to change the router and wireless adapter to secure the wireless network.
So this can be a three step process.
If you internet service is provided by a cable(tv) there is a reasonable chance your router will work out of the box no configuration changes. However, if your internet service is supplied on the phone line chances your router will work as it comes out of the box are much less. Who is your Internet Service Provider and if possible can you supply a link to their help/support website so I can see if they supply configuration instructions?
Jan 03, 2008 | Linksys Wireless-G WRT54G Router
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
