Question about Bionaire BSF1731RC Stand (Pedestal) Fan
Well, we loved our fan for a couple years, then it seemed to be starting slower and slower. Finally it wouldn't switch on at all. My husband found that spinning the blades, kinda "getting them going" like you would a propeller made it go, but then that worked less and less often and we're bummed and hot. :( Any suggestions how to make our fan "go" again???
  • 4,102 Answers
Hi this is a very common problem with fans, now what has happened is that over time dust has got into the part that the fan blades spin on and this has dried up the grease that prevents the fan from stopping like it has done, using it like this will cause it to over heat and this will then cause the motor to short out and stop working all together.
now if it hasnt all ready shorted out then their is one thing you can try, make sure its not plugged in then you need to remove the cover that stops you touching the fan once this is removed you will be able to see how the fan comes off its drive, you need to take the fan off and give the part its spins on a good clean then get some grease or vaseline and give it a coating with this then put it back together this should then make your fan work unless the motor has all ready over heated.
you need to grease all the moving parts and then this will get the fan working again dont try switching it on whilst you have it in pieces make sure you put it all back together before switching it on, also check the fuse in the plug as this will blow if it has over heated.
let me know how you get on or if you need further assistance ok
Posted on Aug 23, 2010
Remove seat back hilux 205 ex cab
I had been all over the internet trying to find someone who could help me out with my situation, I loved my my husband so much but he never loved me rather he goes out with other females then one day I found prophetharry@ymail.com in the internet where he had helped many women who had the same issue with me, when i contacted him he said he will help me and just as he said. my husband concetred fully on me and he stopped all his bad habit I was astounded because so many say they are the best but can't back it. but prof really surprised me till today, his love spell not only brought my husband back but also the spell made my husband to change to a good man CandyPierre
Dec 20, 2012 | Toyota Cars & Trucks
2000 grand jeep cherokee limited 4.7 liter, v8, at first wouldn't start rplaced battery because dead and then replaced starter. ran ok for a couple days. last night started it and hard time with it...
Hi
Pop into to your local garage and have a diagnostic test carried out.
Listen to the advise given. It may save you lots of money, especially if you start the "guessing" game.
It does sound like a part may be blocked or failed though, but the sytem needs to be tested thoroughly first.
Good luck
Roger
Apr 24, 2017 | 2000 Jeep Grand Cherokee
2001 chevy cavilier, 180,000 miles on it. Drive the car for days and it's fine, then it looses power. Let it set for a while, and you might go another couple of miles. Let it set a week, and right know it...
My husbands 2000 model would stall while driving it. He said it made an electrical noise near the steering column. He had it to a chevy garage 3 times for the same problem. It would quit for a year and start again. They changed a sensor,and even a fuel pump which they charged $8oo for. Finally after several attemps my husband changed the ignion switch and it seemed to fix the problem. When he tore it apart he found what looked like melted wiring cover that had drained onto the wiring.When he first bought the car he a recall fixed ,some kind of pigtail in there and we wondered about that.Try this , The ignition switch:I think this might be your solution. It was fairly cheap and pretty simple to do yourself.
Aug 30, 2010 | 2001 Chevrolet Cavalier
06 silverado blower fan won`t shut off finally killed battery
The connection at the blower resistor on these model years had problems with poor connections.
The increased resistance on the terminals caused them to heat up and burn. Some would go open circuit and not work at all and some would short to ground and run all the time, like yours.
As you have already discovered, you will need to replace the pieces.
Nov 01, 2009 | 2006 Chevrolet Silverado 1500 2WD
HB ceiling fan is getting slower and slower bi the day
Solid-state controls change the level of power in the fan motor to control the speed of the fan. For instance, when you switch from medium to high on a solid-state fan, the speed control mechanism increases the power of the motor. Solid-state controls are generally equipped in fans with controls that have predetermined settings, such as low, medium and high.
The solid state device in or around the fan motor could be defective and in need of replacement.
https://www.hunker.com/12003281/how-does-a-ceiling-fan-speed-control-work
Dec 07, 2017 | Hampton Bay 52 In. White Redington...
Does the altura 68 in turn slower than other fans? I was thinking that there was a problem at first, however the air flow seems better than smaller fans...
yes some fans turn slower. usually the larger ones have slower speeds. If you are happy with the speed you have then just enjoy it.
Just curious about one thing. Do u have the fan on a dimmer switch?
Jun 15, 2009 | Hampton Bay 24002 Ceiling Fan
Quorum fan model 350605-2 is slowing down
you say you control with remote? could someone have pulled the pull chain speed adjuster, and the two fans are not in sync? beyond that the motor is windings are getting weak.
Apr 02, 2009 | Dryers
My husband had a fall today and broke his foot and he had the camera in his hand. It now shows system error S0042 and the lens will not close. Can you help? Many thanks Angela
Okay, the same happened to my camera. The lens stayed open and showed system error on a blue screen when I tried to close it. I checked if this had happened to others and found that it had, and took note of their comments.
I tried first of all pushing the lens back in whilst trying to close the door: seems to work for some but not for me.
I then tried pulling the lens out even further in case it hadn't come out all the way in the first place: didn't work either.
I tried slapping it on the palm of my hand three times quite hard and trying again to close the lens door, then repeating this a few times: seems to work for some, but again not for me.
Finally what did work: I rocked the lens back and forth gently a few times which suddenly brought it back to life - it sprang open a fraction, made the 'taadaa' noise to show it was ready and was delightfully back to normal.
Seems the lens had been stuck somehow and needed a bit of gentle persuasion to return to its normal positon. It may be the combination of all the above that finally did the trick, or just the end one. I will never know. I do know that I love this little gizmo and that it has given me five years of brilliant service. There are cheaper and better spec' camers around now, but I wouldn't trade it for any of them, so its really lovely to have it back up and running.
Hope this works for you and anyone else it may happen to.
Les.
ps: Angela, hope your husband's foot has got better by now. Shame you can't do the same with limbs when they go wrong!
Mar 11, 2009 | Konica Revio KD-400Z Digital Camera
Alarm
reprogramme key on computer ,engine immobiliser playing up
Oct 16, 2008 | 2000 Volkswagen Beetle
Samsung washing machine reset code
i have samsung
6 kg WA80HAG silver nano
dear'
plz help me to reset washing
machine
thanks
Mar 18, 2008 | Samsung WF337AA Front Load Washer
Bionaire BSF1731RC Stand (Pedestal) Fan Logo
243 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
