Question about Epson Stylus CX6000 All-In-One InkJet Printer
Paper Out or Not Loaded Correctly (E-03) - BUT have paper in it!
I am having problems with my printer telling me I'm out of paper, but I'm not. It seemed to start with the feeder grabbing multiple pages, then a few minutes later stopped grabbing any paper at all.  Wondering if something has gone out of alignment or something, but not sure how to proceed.  I have tried using less paper, slightly more paper, holding the paper as it tries to feed...but nothing is working.
Any help would be greatly appreciated!
    Scholar:
  • 94 Answers
Hi, please check if there is any foreign objects that was stuck when it try to grabs mulitple pages. Then power cycle your printer. Make sure also that the left edge guide or platen lever is seated correctly as the paper is loaded perfectly in the feeder and try printing. If issue still present it only means that the sensor that responsible in grabing papers in the paper feeding section is damage or the mechanism that holds the paper was get damage when the printer feed multiple paper at the same time. You may need to call the printer manufacturer and ask for service.
Tirzo
Posted on Jun 12, 2008
    New Friend:
  • 39 Answers
Try to clean your roller first and see if it works. Also check for loose gear or jams while at it. If nothing improved, you might need to check it with a technician or visit here for more troubleshooting basics.
http://www.printerquickfix.blogspot.com/
Posted on Dec 19, 2012
Epson stylus c48 paper not loaded correctly error
@Linzi_mackie
"c48 not loading..."
Check that paper is not curled at leading edge.
Some printers are finicky about exact straightness.
Otherwise check:
Paper not glossy - roller-gripper may be doing a 'wheelie' on the edge.
Rubber gripper not worn down - the pickup roller usually has one or more rubber 'rings' around the roller to grab & feed paper by friction.
If all else fails, open cover and inspect gearing to roller, broken brackets which can cause misalignment.
Try running 'open' and see what happens.
Regards,
Clive.
Oct 25, 2017 | Epson Stylus C48 InkJet Printer
We loaded new pack of paper now printer tells me to load tray 1 as if it does not know that tray 2 is in place and loaded with paper.
This is due to paper handling either the guides in the tray are off (Example: Adjusting the tray from Letter to Legal) Or the paper handling settings in the machine are miss-configured. I don't know that machine type so I can't inform you correctly how to change but on most HP printers go into the menu from the control panel and arrow down to paper handling go to tray 2 size and type and make sure they are set to the same paper size and type as you have loaded into the machine.
Oct 20, 2010 | Office Equipment & Supplies
Why does the paper light keep blinking even though paper is loaded correctly in the tray?
Check the microswitch inside the printer paper tray. Turn off the printer first and unplug it. There is a sensor switch that may need cleaning from paper dust, or the microswitch that tells the printer there is paper there may be bent, good luck
Jul 11, 2010 | Brother HL-2040 Laser Printer
My printer (Epson R800) keeps on giving me the error 'Media not loaded correctly'. Even before it's even tried grabbing the paper, it starts blinking red on the paper/trash button. I've never had this
Please make sure that the paper that you are using is included under the printer's paper compatibility list.
Make sure that you are selecting the correct paper type on printer settings.
Trash and re-install the drivers.
Apr 29, 2009 | Epson Stylus Photo® R800 InkJet Printer
E-03 Error "Paper Out" - but there is plenty of paper
It sounds that the sensor that responsible in detecting papers to be feed in the printer is malfunctioning. I can suggest some work around if this thing won't work then you need to send your printer to service.
Please check for any obstruction inside the printer like paper, plastic, tapes. Turn on and turn off the printer and make sure that you load the paper correctly.
If the issue still present then its a hardware failure. If your printer is under warranty I suggest to call your
printer's manufacturer and have them replaced or if you think buying new printer is more cost effective then buy new printer.
Sep 22, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Paper wont feed
It's just one of four things............
1. The paper is not loaded correctly on the correct path.
2. The paper is loaded correctly on the correct path but the "PAPER PATH" selected in the printer driver box or printer preference or application used is not set correctly to grab the paper from the correct path.
3. The paper path sensor is defective which means that the printer needs to be taken to a servicer or you need to contact epson for warranty options
4. The paper being used is too thick for the printer to feed it
Aug 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Printer will not feed/accept paper.
Front LCD reads error "Check Paper & Retry" When paper is inserted and loaded correctly and machine is reclosed the printer then initializes then reverses the feed of the paper and is ejected and error continues to reappear.
May 25, 2008 | Epson Stylus C48 InkJet Printer
Paper not loading (but it is)
If it's an older machine, try cleaning the Multi-sensor (next to the printhead with the scissors icon on it).
Mar 12, 2008 | Epson Stylus Pro 4800 InkJet Printer
Epson R300 printer
ok " if you look in where the paper is loaded on top there is a small switch with a finger , may be bent. tells printer when paper is low
rubber wheels that pull paper threw may be glazed , take sand paper and go over wheels to ruff up
Jan 22, 2008 | Epson (C31C411016) Printer
EPSON RX500 PRINTER
Hi Dean; It sounds like it's a simple case of the miss-alignment of the paper sensors used to check the alignment of the paper in the tray. Many of the printers today use some type of sensor to detect the paper. Even thought the paper is loaded correctly the sensor could be missaligned. I would check the printer by first loading a page in the tray then turn the power off. Open the cover and examen the tray parpiculary around the edge of the paper. There should be a slot on both sides that sense that the paper is loaded. If either one is not contacting the paper it sends a measage to the processor that the paper is jamed. which will shut down the printer. Most sensors have a way to align them. Some are alligned using a screwdriver and some sensors are mounted on a metal bracket that can be adjusted by bending it into position. Another thing to look for is an accumulation of dust in the tray. If the sensor is a mico-switch it could porvent it from working freely. Cleaning the tray with some computer wipes will alimnate the dust problem. Sometimes a can of compressed air can be used for cleaning areas that are hard to reach any other way. Hope this helps Bruce
Mar 10, 2007 | Epson Stylus Photo RX500 Printer
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
674 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
