Question about Samsung SF-330 Plain Paper Inkjet Fax
Fax machine problems
We ran out of paper during a fax. the moniter reads paper jammed. after paper has been replaced we still can't get the fax to print. I need the fax that is being stored in the memory of the machine! message reading paper jammed.
I have removed all the paper and it looks clear to me but it still comes up wit the message
  • 3,037 Answers
If you open up the cover, and put the paper in and press ok or resume, does this work?
Is it possible for the fax to be resent? If so, we should just reset the machine
Posted on May 04, 2008
  • Benjamin Patri
    Benjamin Patri May 07, 2008
    Please don't forget to respond about my solution.
    If your problem is fixed, please rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
  • 2,326 Answers
Unplug the device from the AC power for about 30 minutes to allow it to reset the circuity.
Hope this helps.
MESSAGE : RECORDING PAPER JAM
Dear
The paper jam is a common problem, you need not to replace to ink cart.
Check the plain paper inserted properly or there is no paper inside, Put power OFF and ON. Also some model needs to press OK or START key to remove the paper jam message after removing the jammed paper.
Thanks.
Mar 06, 2015 | Office Equipment & Supplies
Paper jam
Sir/Mam
The problem mite be dirty rollers that feed the paper, try cleaning with alcohol or worn out replace. Problem is the paper roller is miss feeding not taking up the paper instead of hitting something in the machine paper jam.
Apr 18, 2010 | HP 1010 Plain Paper Inkjet Fax
Brother Intellifax 2920 Error "Unable to Print"
Check the flux capacitor, those usually go out on brother faxes.
I just replaced mine last week, same problem.
Jan 05, 2010 | Brother IntelliFax-2920 Fax
A paper jammed during a fax. i removed it. now,
When you removed the paper jam did the paper tear? mit have left piece of the orgnial document. Also open document feeder where you place the orginal check to see fot any problem. As for the cover does it look like something on the the door is broke, The actuator on the door Slab of plastic , that goes into a slot on the machine to accurate the door close sensor, if the sensor is not activated then the copier thinks the door is open even if it closed
Aug 26, 2009 | Office Equipment & Supplies
Fax will shows a Paper jam but no paper found in machine.
Are the all sensor flappers whole?Or it may be an PCB problem
Jan 26, 2009 | Canon LaserClass 9000L Plain Paper Fax
Machine reads "document jammed"
its the problem of the rollers which pulls the papers they r worn out.I've seen this before repairing computers and asked about fax machines while I am there. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Jan 07, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
Jammed paper message
I get a Jammed paper message on the read out, I have cleaned out all the paper and pressed stop/cancel button but it still keeps saying that there is a paper jammed in it.
May 04, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
I need to know if it still reads "paper jam?" If so, there must either be some piece of paper that is triggering the paper sensor, or the paper sensor actuator has become misaligned.
Feb 22, 2008 | Office Equipment & Supplies
UX A460 Paper Jam during fax reception how do I prinmt from the memory
open the machine and clear the paper jam and then closed.The machine will start printing again.
Oct 17, 2007 | Sharp UX 108 Roll paper Thermal Fax
Samsung SF-330 Plain Paper Inkjet Fax Logo
167 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
