Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have Briggs & Stratton lawn mover with model 120000, 650 Series engine. Last time I used it (about 2 weeks ago) every thing was OK. But this time engine starts and immediately stops. I push primer for 3-4 times (as instructed near it in front of engine), I press 'operator presence control bar' and rapidly pull the starter rope. Engine starts for 1 sec. or so and immediately stops. What is the problem? Thanks in advance.
SOURCE: Briggs and Stratton 6.5 hp
i have 6.5 hp br-str engine [troy build] try to repair seems to sucking and pushing air in to carb and exhaust
will not start[timing dots touch each other
Posted on Aug 14, 2011
  • 582 Answers
SOURCE: Engine worked fine last week and for 3 minutes
IF THE ENGINE STILL TURNS OVER YOU MAY BE ONE OF THE LUCKY ONES ON THE OHV ENGINES PULL THE VALVE COVERS AND SEE IF ALL THE TAPPET RODS ARE THERE IF NOT THIS COULD BE WHAT IS BOUNCING AROUND INSIDE
WORST CASE IF ENGINE WILL NOT TURN OVER THE CONNECTING ROD TO THE PISTON COULD BE BROKEN
Posted on Aug 10, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
  • 24 Answers
SOURCE: Lawn mower won't start
to check for firing remove the spark plug insert it in the plug boot and pull the rope while watching to see if the plug sparks be carefull not to touch the plug electrode while pulling the rope or it will shock you. If you don't have a spark, try a different plug. If still no spark the coil could be bad.
Posted on Jun 30, 2010
  • 3 Answers
The crankshaft should have a marked "tooth" either with a "dot" or a "-"mark, the camshaft will also have a corresponding dot or dash. By rotating the crankshaft, align the marks on the crankshaft & the camshaft so that they are directly opposite each other. Drop the camshaft into place and the engine is now "timed"--if the marks are not exactly opposite one another, lift the camshaft (just enough to disengage the gear teeth) and try again, being "one tooth" out can make a huge difference--so take your time and make sure the "marks" are directly opposite each other.
Posted on Aug 10, 2010
Brand new Briggs & Stratton lawn mower Model 90000 E series won't start.
trry a shot of starting fliud see if it wont start then make sure your getting a spark to
Jun 13, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
I bought an Ariens, model #921031 Deluxe 24 with a Briggs & Stratton engine brand new online and haven't used it yet. It's been sitting and now I have a puddle of oil under it. The place t
Some times, the seals not sealed yet not being run. Check all your oil and gear oil levels and run it. Hope everything will be ok then.
Feb 10, 2012 | Briggs & Stratton Garden
Briggs and Stratton Troy Built 21inch 190cc 650 series Gas Powered self propelled Lawn Mower. I moved to new house and the movers lost the manual. I bought it last year so only one seasons use. How do I...
If how you described you unit is true you do not have an electric mower you have a gas powered mower, you DO NOT have a battery!!!??? Place the throttle lever to choke position and prime carb with primer bulb 3-5 times then pull cord. Wala!!!! It's running rite. That guy at Loews must have been smokin somthin. Good Luck...
Apr 22, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
Lawnmower very difficult to start
Hello. Get a can of starter fluid. A couple of good squirts into the air cleaner and it will take right off for you. J.
Jul 03, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
I have a Briggs & stratton 18hp ohv riding lawn mover. Model # 31D777 type: 0233 E1. Do you know where I can find an Owner's manual that can be downloaded on the computer? Went to briggs & Stratton...
I also have this same engine and am also looking for the owners/workshop manual . Also went to Briggs & Stratton with no satisfaction. If you find anything please drop me an email aswell. Thank you. harmsen2@bigpond.com
Mar 27, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Want a repair manual for a 17 hp briggs & stratton engine
A range of strip-down manuals for all Briggs & Stratton engines is avalable - I got mine from Amazon, but you can get them directly from Briggs & Stratton via their web site. They have a look-up system by model series, which ensures you end up with the manual that covers your engine.
Oct 01, 2009 | Garden
WE NEED A MANUAL FOR BRIGGS & STRATTON ENGINE FOR A ARIENS SELF PROPELED LAWN MOVER
ok here is a link to get you to search for the correct model. should find it here. if not do a google and put 'Briggs and Stratton model XXXX manual' search.
http://lawnandgarden.manualsonline.com/manuals/mfg/briggs_stratton/190477gs.html
AndystUK
Sep 02, 2009 | Garden
My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
May 31, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
140 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
