Question about Bose Wave Radio
Bose wave radio wont turn on
Wont turn on is ther a fuse or some part i can access
I have one that is doing the same thing. Will your radio make a POP sound when you unplug it? I was told by Bose Tech it is 15 yrs old and they will not work on it. He told me that if it makes a POP sound that it is not the fuse or power supply???
Posted on May 06, 2008
I copied some music to a disk with 4 different formats but the bose radio wont play any of them.
The Bose Wave Radio doesn't have a CD player. The Bose Wave Radio/CD does.
It will only play standard music CD's with standard CD Audio on them.
The manual is available at Bose.com.
Mar 15, 2011 | Bose Wave Radio
Bose radio will not turn on. I have a Bose Wave radio, model AWR1-1W, D.O.M. 980305, that will not turn on. I've verified that there is power to the radio (checked outlet plug of cord). I've looked...
I have the same issue with the same model. I found an open primary winding in the large transformer inside the unit. Now the problem is finding somewhere to buy the transformer...
Sep 19, 2010 | Bose Wave Radio
My bose wave radio won't turn on at all. replaced 9 volt battery.
open unit up and check A/C FUSE located near where the A/C plug/wire is connected to radio!
If fuse is bad it will measure an OPEN ]---- ----[
a GOOD FUSE will measure a SHORT ]-----------[
gl
May 19, 2010 | Bose Wave Radio
My Bose Wave CD Radio has no power. Will not turn on. dead. Checked the power cord and supply, it is good. Is there an internal fuse?
Yes - although Bose doesn't really publicize the fact, there is an internal line fuse in each Wave. Location varies by model and date of manufacture, but the fuse is easy to spot once you open the radio case.
Bill B
Apr 10, 2010 | Bose Wave Radio
My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Mar 26, 2009 | Bose Wave Radio
Power
There's a line fuse on a circuit board inside the radio. CAUTION: disconnect the set from its power source before you open it up or start poking around inside it. If you're lucky, all you will need is a simple fuse replacement. The sets are, however, notorious for "blowing" power transformers. If the fuse is not the problem, you will likely need to send the set to Bose for repair. On their web site, www.bose.com, they offer to repair most Wave sets for $100 or give $200 credit towards the purchase of a new Wave. Before you spend the big bucks though, you might want to check out the new HD radios. Better sound and MUCH lower prices than the Bose.
Sep 16, 2008 | Bose Wave Radio
Replace fuse Bose Wave Radio
For the AWR1-1W turn it over and there are 4 screws that you must remove. When your looking at the circuit board the fuse is just below the power supply and back of radio. If the radio makes a ‘POP’ sound when you unplug it may not be the fuse as power is getting past the fuse. I have the same trouble with mine. I called BOSE Tech and he said if it makes that ‘POP’ sound after unplugging it is not fuse or power supply. They will not even allow me to send it in for repairs as the radio is over 15 years old and considered unserviceable.
Maybe someone else can give us a quick fix.
Apr 09, 2008 | Bose Wave Radio
Bose Radio working in the Caribbean?
doi they use fm ther u may wann antenna booster
Jan 28, 2008 | Bose Wave Radio
Bose Wave Radio/CD Model AWRC1P
Yes There is a pigtail fuse in unit. It solders to main board. In order to replace you have to pull main p.c.b to get access to bottom of board.
Jan 18, 2008 | Bose Wave Radio
Boes wave radio
All Wave Radios have a Pigtail fuse on main board. May just be Fuse. I have seen alot of them that when dead have water damage as root cause. These radios are very reliable and water damage failure seems to be the most common. Bose has a flat rate repair service on these radios http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/contact/index.jsp&ck=0
kstahl65@att.net
Jan 14, 2008 | Bose Wave Radio
Bose Wave Radio Logo
671 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
