Question about Philips Televison & Video
Trying to hook up dvd player to a philips 27ps55-s121. I cant get it to show up on the tv screen. I dont know what channel the tv needs to be on to show the dvd. and i am unsure where what plug (cable) goes where. Please help.
    Guru:
  • 276 Answers
Connect one end of the VIDEO
(yellow) CABLE to the AV1 in VIDEO
jack on the back of the TV. Then connect
one end the AUDIO (red and
white) CABLES to the AV1 in AUDIO
L and R(left and right) jacks on the rear
of the TV. Connect the other end of the cables to the appropriate color on the DVD player (yellow to yellow etc.)
Press the CH + or – buttons on the
remote to scroll the channels until AV1
appears in the upper left corner of the
TV screen.
Slide the TV/VCR/ACC switch to
the VCR position.
Insert DVD into player and press PLAY.
Posted on Aug 23, 2010
I had DVD player hooked up to watch movies, I was trying to set a universal remote because I do not have one already. When I couldn't get the remote to work I pushed Menu on the front of the tv, chose...
Perhaps your dvd player output is set for channel 3 so you have to select that channel for the dvd player to play on your tv. Some older analog tvs have a separate input for dvd on the back or front. In that case you have to select that setting from the tv menu
Sep 17, 2013 | Televison & Video
Hooking up older Curtis-Mathes TV to a newer DVD player.
It is hopeless if the television will not stop cycling through its channels. That is an unattended operation and may point to there being something really wrong with this television OR it may be one of the televisions that has to be fed a signal of some type in order to stop cycling through its channels.
First, how would you connect a dvd player to this television: You would have to buy a part that has yellow red and white holes on one side and a coax output on the other side. I bought one from my local drugstore a little while back. It is Philips brand, and it says connect any dvd player to any television right on the package. I don't know if they are sold anymore, but I imagine that some store would still have them. Then you would disconnect the vcr and connect that part there with the dvd player connected to it (the part I described).
Next, if your television is the sort that needs at least one channel to be programmed into it so it won't keep cycling them, you would have to connect a converter box where you have the vcr connected right now. I know, this troubleshooting takes work, and there is no way to tell if this will work.
Dec 02, 2012 | Televison & Video
How to connect dvp3266 with tv?
If you dont have the user manual you can get one on-line at http://www.p4c.philips.com/files/d/dvp3266_94/dvp3266_94_dfu_eng.pdf and it will show you how to hook it up to most TVs. Would have to know what TV your hooking it up to, for further assistance.
Sep 06, 2009 | Philips DVP5990 DVD Player
Can't get dvd player to work on this tv!!!
im guessing that you cant go to av mode because you dont have a remote, am I right? if thats the case you need to go to walmart and buy an RF converter. You can plug you dvd into the converter, then run a coax cable from the converter to your tv coax inout aka anteanna input, then depending on your converter switch your tv to either channel 3 or 4 and presto. it will hook up just like vcr's and onld nintendos use to. You can pick up an RF converter cheap at walmart or check e-bay, couple bucks and your watching dvds.
Jun 23, 2009 | RCA F36649 36" TV
Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Oct 22, 2008 | Prima C2012 TV
Dvd/vcr player is hooked up but not playing...
Yes. You definitely need to set your TV on a specific channel - GAME, in your case. Check your TV manual how to get to that GAME channel.
Jan 12, 2008 | Philips DVP3340V
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
        OR
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
        OR
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Dec 25, 2007 | Philips DVP3340V
Connecting to a DVD/VCR player/recorder
In the menu of the Philips dual unit,select set-up then look for channel auto-program instructions. Be sure to hook-up a tv channel signal source before beginning auto-search.Hope this helps.
Oct 03, 2007 | Mitsubishi CS-27205 TV
Televison & Video Logo
313 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
