Question about Sears Refrigerators
I have a Kenmore Refrig model# 25368832791, serial # BA80711881, purchased 3/98. It has begun to vibrate excessively and makes a lot of noise. I tried leveling it several times but it didn't fix the problem. Please advise
    New Friend:
Model #25368832791 KENMORE Top-Mount Refrigerator - what was the cubic size of this fridge?
Posted on Feb 21, 2017
  • 641 Answers
SOURCE: Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Posted on Sep 04, 2007
  • 62 Answers
SOURCE: Freezer is fine. Fridgerator portion does not cool .
The most likely cause is a bad evaperator fan motor. It is mounted in the freezer section. It blows the air up to the ref section. Open the freezer door and listen to see if you hear any fan noise.
Posted on Dec 06, 2008
  • 410 Answers
SOURCE: Model 78182891 Coldspot with excessive water Collecting in Refrig
Most likely whats happening is you have a frozen drain for the defrost cycle. here are step by step instrutions for repair:
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
Post bak if you have any questions and I'll gladly help you out Thanks Peyton
Posted on Mar 15, 2009
  • 93 Answers
SOURCE: Kenmore Top...Brand new, loud icemaker & door vibrating
you may think its comming from the door but check the back of the frige it could be your cooling fin radiater if we can say when you here the noise listen closly then touch the tubings or the radiater in the back you will find where its coming from it may be a loose scew causing vibration
  • 8619 Answers
SOURCE: making lots of noise when running help?
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Please revert for further assistance and Do accept the solution if found useful.
Posted on Mar 18, 2009
After compressor on,Sears/Kenmore ac makes a loud vibration noise
sounds like head pressure problem it is most likely clogged on condenser try washing out really good then try again
Sep 10, 2009 | Heating & Cooling
I have a maytag washier and it is working but it makes a lot of noise -it sounds like jam Model number is MAV2755AWW Serial number is 27422854JT
Your Maytag washer may vibrate or make some noise during normal operation. If vibration and noise are excessive, however, you'll need to troubleshoot the problem. The two main reasons for such an issue are overloading and nonlevel installation. Overloading can be corrected by putting less clothing into the washer before you run a cycle. It can be corrected mid-cycle by removing clothing articles from the washer mid-cycle. It's also very important that you make sure that your washer is located on a firm, completely level surface. Otherwise it may create severe vibration and noise, possibly even enough to damage the machine or nearby items.
Sep 01, 2009 | Maytag Washing Machines
Vibrates during spin cycle
front loaders are made to sit on concrete they probably didnt tell you when you purchased it if its on wood floor not much you can do
Jul 05, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
the noise is most probably compressor tubing vibrating while the unit is running. when you press against the doors your changing the position of the tubing causing it to quiet down. what you can do to fix it is pull refrig from wall remove unit cover on the bottom and move the tubing around alittle bit then put it back together and see what happens. in some cases unless it makes the noise while your working on it, it may take 2 or 3 attempts to finally get it to stop. additionally if you have copper tubing for the icemaker water line be sure it is isolated as well to help quiet it down.
DO BE CAREFUL when moving the tubing not to cause it to leak refrigerant by bending or moving too much. the noise is an annoyance and not a sign the refrig is about to break down. Thanks Peyton
Mar 16, 2009 | Kenmore Refrigerators
JTP15 GE Oven - vibration noise
We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
Jan 14, 2009 | GE JTP15 Electric Single Oven
Sep 26, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Kenmore progressive upright canister vacuum
I had the same problem and so my husband took our vacuum apart. I cleaned what I could and discovered that there is a foam filter that sits below a dark gray cover immediately beneath the bag (on the floor of the inside of the vacuum). This is different from the HEPA filter. I cleaned this off (ours had a lot of dog hair on it) and placed it back in the slot. The vacuum is not making the noise anymore and the suction is even improved. I had not noticed the suction had deteriorated as the vacuum still worked well in my opinion. I hope that this helps and that you have the same problem. It was very easy to fix. I believe the noise was due to the impairment to the suction. Good Luck!
Sep 12, 2008 | Kenmore Progressive Bagless Upright with...
80 Series top loader excessive vibration and noise on spin
check the screw feet, on the front corners, one may be not screwed down far enough to be 'tight' to the floor allowing a small movement that makes a lot of noise, halting under pressure suggests this is the case
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
Refrigerators Logo
109 people viewed this question
Top Sears Refrigerators Experts
Are you a Sears Refrigerator Expert? Answer questions, earn points and help others
