SOURCE: i need the instructions
Download the rules from Hasbro:
http://www.hasbro.com/common/instruct/Monopoly_Jr_Disney_Princess.pdf
Testimonial: "thanks"
SOURCE: i need instructions for a monopoly game
You can download the instructions from the Hasbro website:
http://www.hasbro.com/common/instruct/Monopoly_Here_&_Now_2006.pdf
SOURCE: I need instructions to Junior
Hello there,
You are in luck. Here is a link from the company for instructions.
http://www.hasbro.com/common/instruct/monojr.pdf
Thanks for using Fixya.
Please take a moment to rate this solution. Thanks.
SOURCE: i need assembly instructions for disney princess
Use the hardware that comes with
the Disney Princess canopy package to install the main canopy hook in
your ceiling. Center the steel ceiling hook above the center of the twin
bed and screw it into the ceiling by hand or with pliers. 2 Follow the included instructions
and insert the four poles into the sleeves of the canopy. The two
longer poles will run lengthwise above the bed, while the two shorter
pieces will run widthwise above the bed. 3 Attach the canopy to the ceiling
hook by slipping the plastic ring of the canopy onto the hook. The four
polyester sides of the canopy should now hang over the twin bed. 4 Use the customer support form through the Exxel Outdoors website if you have questions regarding your Disney Princess canopy.
