Liebherr 7082 312-01 - temp of freezer overnight dropped to -9 from -18. Fridge temp is also floating around 9 to 5. They should be -18 and 5. Is this the thermostat? Fridge/freezer is nearly 5 years old.
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
  • 1462 Answers
SOURCE: Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Posted on Jul 25, 2007
SOURCE: Indesit fridge freezer not getting cold (2 years old)
how to fix my indesit light inside the fridge reply asap
Posted on Sep 19, 2008
SOURCE: liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Posted on Jan 04, 2009
SOURCE: How to find part number of Liebherr fridge freezer
Normally if you remove the LHS salad drawer in the fridge you will see a sticker on the wall of the unit with the relevant information.
Hope this helps.
Posted on Jun 08, 2010
We recently had a power outage, now the interior light is flashing and the fridge is not cooling
Try resetting the fridge and freezer temp, fridge 4 deg C freezer -18 deg C turn the unit off at the power socket leave for a minute then turn on be fore resetting.
Mar 03, 2016 | Liebherr Refrigerators
I have a Liebherr CUPsl 3221 freestanding fridge/freezer. Does any one know what are the approximate temperatures in the freezer area at different settings? (1-7, manual button in the refrigerator are
Their are no direct connections between the number and the temperatures on refrigerators and freezers. Is is based on surrounding temperature, in the room. That is the reason they used numbers and do not mark teperatures.
May 23, 2014 | Liebherr Refrigerators
Hope this helps.
Jun 08, 2010 | Liebherr Refrigerators
My fridge freezer is omitting cheesy smells from
Im still looking for the same problem and how to solve. Ive established it stagnant water in the drip pan at the rear. I keep cleaning it and intermitantley it comes back with water that looks like cheese curd in it........ Im going to call Liebherr as the fridge has been doing this since last year and is now getting worse but is only 2 years old.......
Feb 04, 2010 | Liebherr KES4260 Refrigerator
Freezer is working but refrigerator is not
My Maytag (side by side) had a similar problem, turns out to be the damper door. The freezer does the cooling, there's a damper door between the fridge and freezer that opens and closes to control fridge temp. Find the damper door and prop it open. If the fridge temp drops overnight, you'll need a new damper ***'y.
Oct 01, 2009 | Frigidaire Refrigerators
Fridge will not turn down
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 21, 2009 | Liebherr KES3660 Stainless Steel...
Liebherr frost free fridge/freezer
Sep 07, 2008 | Liebherr KGBN 3846 Premium BioFresh Bottom...
The freezer on my Liebherr fridge keeps filling too much with ice. The ice grows around the door and seal which makes it impossible to close properly. I inherited the f/freezer so I don't have the...
This sounds like moisture in being sucked in past the door seals. Remember, cold-- sucks temperature, (like a vacuum) and HEAT--- pumps away temperatures..So the warmer temp. are always being drawn in.. Thus, bad door seals, and need to be replaced --- cleanned---or repaired, but for now turn your thermostat or temperature up or the control knob back lower, (like from 7--to 5--ect. ect 4-to 2..)!
Sep 06, 2008 | Heating & Cooling
124 people viewed this question
jasbo
jasbo
