Question about Car Audio & Video
Cd changer is reading cd's as BAD
I put my cd's in changer and I hear it working, but on the control panel it says Disc 1 trac 1 then says BAD. It then switches to the next cd and does the same thing all the way through.
It is in a 2002 Mercury Sable LS Premium.
  • HAAi
    HAAi May 11, 2010
    Hi there!
    I'll try and help you.
    1. Is it reading the cd before?
    2. Have you tried different cds?
Check the conection interface for bad contact.
Posted on May 05, 2008
Have a jvc kd-sc401 connected 10 disc multichanger but won,t load cd,s although you can hear multi changer trying to work pls help.stereo working as should don,t have manual for stereo so don,t know how to...
You need to reset the CD player. Remove the front panel and you will see a tiny hole in the middle of the panel of the unit mounted in the dash (i.e. without front panel). Gently push a ball point pen or pin in to press the reset switch.
About the User Manual, visit the next link to download: kdsc401-402e_get0410-001c_fr (pdf)
Hope this helps.
Sep 27, 2011 | JVC AM FM CD DET FACE CAR STEREO
No power at the 6 disc cd changer? Cable has power.
Have you checked to see if the there is a blown fuse? Check to make sure of that first. If it is good then the only reason for it not working is the CD changer motor is fried. Do you ever smell anything burnt or hear any noises when you connect it? If you do hear anything but it wont power on, then its bad. hope this helps
Aug 03, 2009 | Panasonic CX-DP610 6-Disc CD Changer
I can not hear any audio
If you have the correct head unit, and assuming the cable is in good condition, the it should work. Although I do remember some Pioneers needed Permanent 12V+ and ground hooked up in order to work. If this is one of those, on the changer side there should be another white plug next to the changer cable with two or three wires in it. This should be the power feed wirs for the changer. I need more info to confirm.
Jun 14, 2009 | Pioneer CDXP1280 Multi-Disc CD Player...
2004 GRAND CHEROKEE 10 DISC C/D CHANGER MALFUNCTION.
It fixed it's self,the next day the changer was working normal.the battery is weak and going to be replaced.so maybe the problem was low system voltage." IT'S A JEEP THING " ???
Feb 04, 2009 | Cherokee Jeep Grand CD Changers - 10-Disc
Changer does not work
Had the same problem!! Found the solution here under "Wont Play" question. Push that cd chngr magazine (holder) all the way into the unit and tap with a blunt object( Dont tap too hard,it's plastic!!) screw driver worked for me! Push the eject button and you'll hear the unit working! Pop it in and out and it seemed to unfreeze whatever was frozen!! It finally loaded a cd and started playing again. I checked all 6 and they were okay!!
Thanks support guys for your help!!
I'm now a member!!
Jan 15, 2009 | Alpine CHM-S620 6-Disc CD Changer
I have a kenwwod ddx 6027 double din head unit in my car, what cd interchangers will work with my head unit?
Any kenwood changer will work. That head unit also supports DUAL changers
Any FM Modulated changer wil also work.
Changer Control Features
  • Dual Disc Changer Control Capability (CH1/CH2 & AUX)
  • DNPS (Disc Name Presets) with Compatible CD Changers
  • DNPP (Disc Name Preset Play) by Remote
  • CD Text Ready with Compatible CD Changers
  • Direct Access with Remote
  • Random/Repeat/Scan Play (Disc/Track)
Jan 09, 2009 | Car Audio & Video
I believe thats an fm modulated changer. Need to make sure you put it on the correct freq. The one I had needed to be on fm 89.1 or 89.5 to work. Hope this helps.
Nov 21, 2008 | Pioneer CDX-FM673 6-Disc CD Changer
Problem with 6 disc changer
Hi I believe it is tellinng you that you do not have a disc Jacket. The case that holds the 6 discs. If you have this the switch inside the CD changerneeds some investigation.
Oct 09, 2007 | Audiovox SP6CDP 6-Disc CD Changer
Jumping Tracks when using "Next" control
find the "reset" button (this button usual is very small) find it in front of the control panel, if the control panel is removable find "reset" button after removed
Feb 02, 2007 | Sony CDX-T69 6-Disc CD Changer
Car Audio & Video Logo
166 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
