Question about Maytag Neptune FAV6800AW Top Load Washer
What does "dc" flashing mean on a top loading Maytag Neptune?
  • 15,935 Answers
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Maytag neptune top load washer will not spin out with small loads, large loads are fine. I get the DC error at about 10 mins left in spin cycle. No amount of shifting load will solve problem
This is a Clutch issue could be a easy fix if the Tub Seal is not the root cause.
If you get no help at this forum Google This ""Neptune TL Washer FAV6800AWW""
5th post down you will find the SM and support for the "DC and UC" unbalance error codes. Good luck..............DH1200s
Aug 20, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune toploader won't finish cycle code dc. What does dc mean?
Replace the clutch.
Jun 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune FAV6800AW Top Load Washer: My Neptune washer is showing error code dc..Once i...
See this post Clutch Fix if you want to DIY I will help you.
Post back if you have questions……..Rich
May 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune TL when it gets down to 12 minutes left it starts flashing dc and wont finish the cycle, what is wrong?
You could have a Clutch malfunction if the machine is a FAV6800A or FAV9800A. If that is you r machine type see this post. Clutch Fix
Post back of you have questions.....Rich
Apr 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Wont Finish Spinning stops and Flashed DC
If the machine type is a FAV6800A/FAV9800A see this Clutch repair post if you want to DIY. You will find links to the Service Manual and parts info if needed.
You can check out the TDS but I would go right to the Clutch repair post if the machine shuts down in with a error code dC or uC.
That means the TDS is producing analog voltage swings +3.5VDC to 0VDC to the input of the Control Board Conn_P3 pins 10 and 11. Those DC voltage swings are at the design limit of max Wash Tub movement and the Control Board shuts the Spin Cycle down……..so thebTDS is working as designed.
The machine will make several attempts to redistribute the load before error code generation failing with dC or uC error codes.
Post back if you have questions any DIY'er with basic skill sets can do the Cluch maintenance/repair.....Rich
Jan 04, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Error code of "dc" on my TL Maytag Neptune
If your machine is FAV6800AW or FAV9800AW the dc/UC errors are caused by a clutch malfunction. Your machine is shutting down with those errors so your Tub Displacement Sensor is working as designed.
Fix the Clutch malfunction and you can wash a single sock or a load of blue jeans and you will not take the dc or UC unbalance errors. See this post for the fix.
Post back if you have questions or need help.
Rich
Oct 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune wash machine does not drain and spin clothes it
its ok dc means the clothes are unbalanced..even the load open lid and restart..onthejob
Jan 31, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl washer
A dc error means that the clothing is not being distributed properly in the basket. This usually happens when the machine is lightly loaded. If the load seems o.k. then the problem is probably with the sensor at the side of the basket.
Apr 26, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
144 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
