Question about Ruud Central System Air Conditioner
Who should I contact--Raleigh, NC
I have a Ruud Achiever 10 seer..Warranty 5 years. Contractor states out of warranty. I travel and out of my condo 3 mos. at a time. The last time the a/c was turned on was last summer and my son stated while staying over night that It was not cooling and needed Refrigerant. I forgot all about it. Cam home in April turned on A/c-not cooling. Called contractor- compressor frozen. I called on April 25, He cancelled appt. on April 28 and came on the 30th. I had the electricity turned on April 30, 2005. He says it's out of warranty. What should I do? It's so hard to trust people these days especially when they know you don't know about these things.
    Scholar:
  • 149 Answers
Huummm... i'd pull out the invoices to equipment there's always a 5 year warranty on compressor. sometimes contractors says it's out of warranty to sell you a new unit, (they usually hate repairing.) If your invoice says it's less than 5 years old well technically your under warranty. If contractor doesn't want to honor warranty you should contact any local consumer affairs office and file a claim, sometimes if the equipment is less than 5 and more than 2 you might have to pay a small fee to get the replacement compressor. And you might have to pay some fees, at least installation of it. and the only time it needs refrigerant if's there's a leak. I'd on on that line for now hope to be of assistance today.
Posted on May 05, 2008
Need to check warranty booklet. It will state how long the warranty is or confirm on line or from the manufacturer or Dealer. Most A/c units have 2 to 5 year warranty.
Aug 26, 2014 | Amana GSC130361 Air Conditioner 13 SEER 3...
"I have a 13 year old 10 SEER Achiever RUUD UPKA-049JAZ heat pump when you turn the AC on the ouside unit makes surging sound about every 3 min after about 45 min the ac will kick on."
sounds like compressor is going bad .. first try a hard start kit.. have staved off replacing compressor many times.. may last a long time may last 1 day
also check charge
May 20, 2014 | Ruud Heating & Cooling
Ruud achiever series "10 seer"
You should see no ice. Turn it off for a while like and hour or so.. Do you feel air coming out of the vents?
Jun 26, 2011 | Heating & Cooling
A/C Compressor Problem 3 Ton
IF the compressor is under warranty they should not charge you anything. it is according to what type of warranty you purchased, If the business is gone, i don't know much of what you can do other than calling ruud directly. Most likely the unit is past the warranty. Call ruud to be sure.
Jul 12, 2009 | Heating & Cooling
Need to replace 3 ton compressor
Depending on age of the unit. The compressor amy under warranty. The replacement is something that should be done by a service tech. You have 3,5 ton unit Rus
Jun 14, 2009 | Ruud UAKA042 Air Conditioner
RUUD 13 SEER HEAT PUMP MALFUNCTION 2009 MODEL
I sell Rudd equipment. You have air in the system or faulty TXV. Replace TXV and evauate system. No more problem. Rusty
May 27, 2009 | Heating & Cooling
Does my 10-seer have a 10 year compressor warranty?
If you take all the numbers off the compressor and condesning unit and call an authorized RUUD parts dealer in your area, they should be able to verify your inquiry.
Unless there was a special circumstance, most compressor warranties are 5 years, unless the compressor was replaced during the 5 year period, in which case you should get 5 more years assuming the service was performed by an authorized service company.
May 19, 2009 | Ruud Matching Split Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Ruud Central System Air Conditioner Logo
102 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
