Question about Refrigerators
Frig not cold compressor not running - Refrigerators
  • 4,059 Answers
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. It may appear burnt or distorted or rattle when you shake it if it's bad. It's the little black squarish thing near or on the compressor.
Posted on Aug 23, 2010
dutchman05
  • 487 Answers
SOURCE: Compressor buzzes loud & frig does not get cold
That can also mean that the starter is broken.which will be a cheaper fix than a new compressor.Also the capacitor can be broken and that will give the same results.
Please click HERE for drawing and parts( #30 is starter #55 capacitor)
Posted on Jul 28, 2008
tborn6
  • 700 Answers
SOURCE: Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Posted on Mar 28, 2009
joecoolvette
  • 5660 Answers
SOURCE: Upright frig/freezer not getting cold, compressor running
1.My first suggestion, is to clean out the compressor area located at the bottom of the refrigerator. Refrigerator unplugged from power. Remove the cardboard panel from the bottom, (Watch the water line), and use a vacuum. I also bring the refrigerator towards an open door, and use compressed air to blow it out, afterward. You'd be surprised how much gunk builds up here, and how cleaning it out will help your fridge tremendously! (Good tip for air conditioners also. Power unplugged, case cover removed. Use a garden hose to flush the fins out. Let it dry, reinstall the cover) 2.Your refrigerator may be low on Freon. This requires a professional to purge the system, and reinstall Freon and lubricant. (Oil)
Posted on Jun 15, 2009
  • 69 Answers
SOURCE: H0tpoint HSS25GFPHWW frig not getting cold
needs regassing
Posted on Mar 27, 2010
CaptainHawk1
  • 345 Answers
SOURCE: Temp indicator in both frig
The answer to this question lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1.The timing device that runs the defrost cycle of the refrigerator is defective.
2.The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it's own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Posted on May 07, 2011
Avanti 308ywt compressor keeps running but frig will not get cold
Nataly if there is not any cold air anywhere and compressor is running that indicates a Freon leak and worth very little due to repair cost. You must be sure that compressor is running not the fan noise
Appliance 911 Sea Breeze
Nov 12, 2015 | Avanti Refrigerators
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Refrigerator freezes
Sounds like might be the Temperature Control Thermostat or some sensor in the circuitry telling the compressor and cooling parts to keep running because it thinks it isn't cold enough. There is probably a circulation fan to blow the cold air through the damper and it may not shut off either, conveying too much cold thermal conduction through ducting and all frig parts, regardless of damper being closed or open. With the temperature set on low, do the compressor and fans ever shut off once cold temperatures are attained? Freezer should be 0 or lower, frig 35-40.
check this video at RepairClinic.comhttp://www.youtube.com/watch?v=5vA8Ksv5kVY&feature=player_embedded
Apr 07, 2013 | Electrolux Refrigerators
Freezer/Frig will not get Cold
Check the compressor to make sure it is running. If not then check to make sure you are getting the proper electrical supply to the compressor.
Jan 21, 2013 | GE GSH22JFR Side by Side Refrigerator
Warm air in frig and freezer
have you tried cleaning the condensor coils?
Apr 25, 2011 | Refrigerators
Refrigerator is stuck in defrost mode.
If the compressor is running and not getting cold I would say that you have burnt out your compressor.
If it was stuck in defrost you wouldn't hear the frig running. When in defrost the compressor stops while the frig defrosts.
Dec 29, 2009 | Refrigerators
Refrigerator is blowing air but no longer cold.
It is possible that if the compressor is running that it is either low on freon and not cooling or in some instances low on freon and evaporator is froze up - in which case frig will cool again once all the ice has melted on your floor,) Or maybe your compressor is not running - in which case its cheaper to get a new frig for sure. Listen to tell if the compressor is running. If it is, then your frig probably is low on freon. (I don't know if yours is new enough for a timer) Hope this helps you, Rick
May 05, 2009 | Refrigerators
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Freezer not freezing frig not cold
the compressor with a picture of an Indian, its a techumseh. Is the compressor running? If not, could be stuck in defrost mode. Since you have looked at the compressor, there is two lines that go to it. If there is an oil cooler, then 4. Follow the line, smaller of the two that goes to the condensor, rad. With the fridge running, use your hand to feel how hot it is, if you find it hot enough that you can't leave you hand on that line, then its an inneficient compressor.
Feb 09, 2009 | Frigidaire FRS3R4E Side by Side...
Everything in frig is frozen and it won't turn off.
If the compressor is running non-stop then the temp. control is not telling it that it's "cold enough". If the compressor isn't running non-stop then you should look at the air damper (little window) that lets the freezer air into the refer compartment... if it's stuck open then you will always get cold air pushed into the fridge eventually becoming a freezer in itself.
Jan 17, 2007 | Kenmore 74844 / 74842 Top Freezer...
Refrigerators Logo
136 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
