Question about Samsung CLX-3175FN Color Laser All-in-One Printer
It tells me to replace the imaging unit i did but it still is telling me to replace the imaging unit any tips on how to resolve this?
    Problem Solver:
  • 8 Answers
Sorry about my last reply. you have to replace the selenium DRUM, its a big drum inside the printer under the toner. It cost 150USD... kinda hate Samsung right?
you can also just take it out, shake it left to right several times and put it back and see if you still get the error.
"Pull down the front cover and you have access to the four toner cartridges, which are lined up, one above the other, inside. Unlike many recent colour laser designs, the drum unit is separate from each of these cartridges and has a different lifespan, as does the toner waste bottle, which also needs replacing periodically. "
Samsung has a chip that counts the number of prints you do. After X prints, it wil make you change the toner even if you do not need to. Also you have to replace the selenium drum and also the waste toner bin... I HATE SAMSUMG from now on... CHEATERS
Posted on Sep 07, 2010
There is a yellow edge on downside of paper when sent printing on the Lexmark x543. I have already tried changing the yellow ink cartridge. I have also printed the settings and the fuser, imaging ki
If it is pure yellow I would look at the yellow imaging unit (drum) to make sure that it is ok. That is likely the culprit if changing the toner did not resolve the problem.
Nov 07, 2014 | Lexmark X543dn All-In-One Laser Printer
I have replaced imaging unit 2 months ago and now printer is telling me to replace it.
I assume that you made some alternation to the printer the it sense the change and blow the resistor of the imaging unit.all you need to do is check the resistor by the side of the imaging unit if it is blown replace it with same value but a stronger one.
Oct 07, 2014 | Samsung CLX-3175FN Color Laser All-in-One...
HOW WE CAN RESOLVE Error message E1 CHG.WST.CTN
This tells you that the waste container is full and needs to be replaced. This LINK tells you the step by step process in resolving this issue.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Feb 19, 2011 | Canon Color ImageRunner LBP5970 Laser...
Lexmark C752 printer The printed image is blurred, looks like out of focus and the colors do not seem strong enough? any ideas ?
first check the toner level ? is it correct?
the blur can be caused by a dirty LASER UNIT remove all the cartridge clean properly the two laser unit.
if need another help i'm here and tell me me if your problem was resolved or not.
Oct 28, 2010 | Lexmark C752 Printer
My Bizhub C350 has locked due a imaging problem. There are solution without change the imaging unit?
once the machine locks you out for a imaeg unit you are done until the unit is replaced or reset chip is installed but there is new firmware that can be installed in the machine that wil not stop the machine from usage was the image unit has reached end of life so the next time a service tech comes out tell them you want the new firmwareand set image unit life to suspend
Dec 06, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
Mar 02, 2009 | Konica Minolta bizhub C450P Laser Printer
COF37 error code
C0F37: Abnormally high toner density detected by Black ATDC Sensor
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print1.gif cycle, ATVC, or image stabilization sequence.
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website1.gif for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
Imaging Unit Bk is installed correctly.
NO
Check and correct ATDC
drawer CN of imaging unit Bk.
Each of Imaging Unit Bk contacts makes
NO
Clean or correct.
good contact.
ATDC Sensor harness is open-circuited.
YES
Change Imaging Unit Bk.
Jan 20, 2008 | Minolta CF2001 Copier
Black Imaging Unit
If the machine calls for a new unit, a new not used cartridge must be installed to clear the message
Mar 27, 2007 | Xerox Phaser 7400DN Laser Printer
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
412 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
