Question about Miller Electric Manufacturing Electric Syncrowave 250 DX TIG 907194032 Welder
What is the pin out for the maxstar 200 cannon plug?
My pinterest board has over 1000 pins. But it tells me I have only 200 pins. How can I fix this?
The 200 number may be referring to the number of pins you have pinned personally vs the 1000 pins pinned by others.
Nov 09, 2014 | Pinterest.com
Blinking ready light
Its telling you theres an error in your system possibly a wire jam
Oct 30, 2014 | Miller Maxstar 150 STL TIG/Stick Welder -...
Need owners manual for miller maxstar 140 tig/stick welder
Contact Miller Electric on their website. If you want a Technical Manual, Miller doesn't sell those to the public. They're only available to authorized repair facilities. If you're interested in purchasing one, contact me with the serial & model numbers. I may have it in PDF format.
ToBIGWillie@aol.com
Aug 25, 2014 | Welding Tools
Hel -10 on max star 200
The Help 10 code on a Miller Maxstar 200 indicates a depressed trigger. If it still doesn't clear, replace the trigger control.
Jul 29, 2014 | Miller Welding Tools
Have a Ikelite ( Octopus) housing that I bought for my Cannon 20D in 2006. Now I have a Cannon 60D. The housing works for still photos, but not for video. Can it be modified to work with my new cam
Yes, this may be possible, send it to Ikelite, if there is room they are able to add another control/knob or push-pin to the existing housing. Also if you have knobs you don't use and find them in the way they have a special plug that replaces an in the way knob. Goo-luck!
Jan 03, 2014 | Ikelite Housing For Canon 60d 6870.60...
I'm trying to wire a galaxy desk mic to a cobra 200 10 meter mobile
  • The Galaxy desk mic (power mic) is already wired four pin and the Cobra 200 is a 4 pin already as well. So unless someone has messed with them the mic will plug right up to the radio as is.
  • But if someone has repined the mic then follow the pinout I listed below to get it rewired for the Cobra 200
  1. Pin #1 on mic connector - Black wire.
  2. Pin #2 on mic connector - White wire.
  3. Pin #3 on the mic connector - Blue wire.
  4. Pin #4 on the mic connector - Red wire.
  • If you look on the end of the mic connector it will have the imprint of the number for each pin on the mic.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 02, 2011 | Cobra Radio Communications
Wires in the microphone at the point where you connect to the lead have come appart and i need to solder them back on, Black, red and white wires. Which in which order do i solder them onto the connecter...
There are many standards of microphone connectivity with 3 pin XLR (cannon) style plugs. It depends on where in the world you are as to the favoured standard,
Your microphone usesthe following::
Pin
1 ground (white) 2 +ve or hot (red) 3 -ve or return (black)
Another way to work out what wires connect to what, is to remove the cover of one of your XLR-XLR microphone cables exposing the connections it favours, plug the connector into the mics scoket , and use the connections to the cable guide you in resoldering the connections back on.
The same connections can be veiwed in the user manual here
Please rate this solution. Cheers
regards robotek
Jul 15, 2009 | Behringer XM1800S Professional Microphone
Miller Electric Manufacturing  Electric Syncrowave  250 DX TIG 907194032 Welder Logo
51 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
