TV PROBLEMS My tv turns on for a minute then shuts off and both the power light and the lamp light are flashing but i do not hear the fan turn on?
Screen broken. where to get the replacement?
Posted on May 05, 2008
I have a philips tv model number is 60PL9200D/37. when i turn on my tv the blue power light flashes and the lights and fans cut on but not the actual screen. after a few seconds of blinking the lights and...
U hear alots of clinking too,when tv power on and the projection lamp tried to come on?Yes,tv have a problems with it board call the Ballast board also.This Ballast board only job is to help ignite the tv projection lamp.
Feb 03, 2011 | Philips 60PL9200D Projection Televisions
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
TV will not turn on. Red light flashes 4 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Mar 07, 2010 | Sony KDS-R60XBR2 Television
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
