Question about Cuisinart KUA-17 Cordless Electric Kettle
I mistakenly pu the cuisinart kua-17 on the stove and damaged the bottom. Can one buy a new bottom and unscrew the old plastic one?
  • swhite707 Aug 23, 2010
    this is a generic answer. I need to know where I can really find it and whether it is easy to replace.
  • 4,102 Answers
Hi im sorry i can only give you bad news these are not made to be repaired and you cant get the parts that you need, they are made to be thrown away after use which is bad i know but the cost of making them is low so they dont offer any spares as the cost of a new one would cost less than getting yours repaired,
so im sorry i cant offer you good news but with something like this its just not possible.
let me know if i can do anything else for you
Posted on Aug 23, 2010
    Genius:
  • 1,478 Answers
You can get a replacement for it, i will suggest you check online or any electric store to get the bottom plastic. You can check ebay.com to search for the part.
Take care.
Electric tea kettle by Cuisinart Model KUA 17.
the bi-metal strip heats up with the steam, moves and shuts the power switch off. In the old days there was a screw adjustment, now it is just throw away and replace.
Mar 01, 2018 | Cuisinart Kitchen Appliances - Others
My cuisinart electric cordless kettle does not heat the water. It is trying turning on and off, but light goes on and off and as a result no heated tea. Model KUA 17 CE
Probably a defective thermostat. It is mounted to to the bottom of the heating surface and are mostly round in size. The thermostats are temperature specific so make sure you get the right one. A part number on the bad part is very helpful in locating an exact replacement.
Sep 06, 2017 | Cuisinart Kitchen Appliances - Others
I have a model RK 17 Cordless electric jug kettle from cuisinart that I just love because of the old fashioned design. I need a new base because a mouse decided to chew the cord and was incinerated.
i HAVE THE BASE IT WORKED FINE, MY DAUGHTER COOKED THE KETTLE WHEN SHE TRIED TO HEAT IT ON THE ELEMENT, now I need to find a new kettle! ONSCHMITT@SHAW.CA
Jul 18, 2012 | Cuisinart RK-17 Cordless Electric Kettle
How to remove bean hopper?
Yes it unscrews, just turn it counter clockwise and it will come out. Don't be surprised if the plastic neck and burr head is broken because this is an inferior design and needs to be trashed. I will never buy another Cuisinart product.
Apr 05, 2012 | Cuisinart Supreme Grind CCM-16PC Grinder
Can I get a replacemnet base for the the cuisinart kua-17 tea kettle?
Yes, I opened the base (v-shape screws) and saw that the contact switch was burnt out. Where can I find the round contact switch?
Thanks.
Jul 02, 2009 | Cuisinart KUA-17 Cordless Electric Kettle
Damage to the bottom of Cuisinart cordless tea pot mod KUA-17
Even though there are no parts listed at the cuisinart.com website, the company does a few base pieces left in stock if you call them directly - 1-800-726-0190
Apr 11, 2009 | Cuisinart KUA-17 Cordless Electric Kettle
Cuisinart Food processor
Go to the cuisinart website and you can buy replacement parts. You will have to buy the entire shaft not just the top but it is still good!
Mar 25, 2008 | Cuisinart DLC-10S Pro Classic Food...
How do I clean the contact points between kettle and platform?
PROBLEM:
My problem was similar for the Cuisinart KUA-17.  I clicked down the on switch and it stayed down.  However, the light and power together seemed finicky.  That is, the light came on if I positioned the kettle in the base correctly, but then it sometimes went off without triggering the switch to pop up.  When the light went off while the switch remained down the water never boiled, but when I was lucky to position it such that the light remained on, the water did boil and the switch popped up ... as it should have.  It seemed to be getting more and more finicky and difficult to position correctly ... so I took it apart.
SOLUTION:
First of all, the base has screws that take a triangle screwdriver which I don't have.  So I found a small flat-headed screwdriver (like one you'd use for glasses) that just fit along one side of the triangle.  I was able to get three base screws out this way and since I expected to need to do this again in the future, I used my dremel to grind a larger flat-headed screwdriver slot in each.  It's been about a year and a half since I fixed it last time and this time I was glad I had the slots.
Once you get the plastic base off, you'll see the mechanics of the switch.  There are two wires that both turn on the light and power the heater element.  Where the wires connect to the switch mechanism, there are two metal tabs that stick out in opposite directions from the center.  When the switch is pushed down, you can see these two tabs move.  They are each moving to touch a contact and complete the electrical circuit.  My problem was they were not making a good contact.  The contacts are hidden behind the tabs.  All I had to do was bend the contacts one millimeter closer (i.e. as little as possible) so that they would make a good contact.  The only other trick was I had to remove the switch mechanism from the bottom of the kettle to do this.  Then I just used the same small flat-headed screwdriver to bend the contact as in the picture below.
Nov 11, 2006 | Cuisinart KUA-17 Cordless Electric Kettle
Cuisinart KUA-17 Cordless Electric Kettle Logo
478 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
