Question about HP Compaq nc6220 Notebook
Keyboard problem If I press more than 2 keys simultaneous my keyboard stop working, meaning.. she does't respond to next keys pressed. Is a real problem especially when I play games.. when more keys need to be pressed simultaneous.
In my HP laptop new one keyboard keys A S D F & J K L& enterkey are not responding but G & H in this line are working properly. how can i solve this problem?
Posted on May 06, 2008
Keyboard won't work
When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model.
Jan 15, 2013 | Lenovo b560 Notebook
The.spacebar.stopped..working.
If your space bar isn't responding when you press it, or if it responds sluggishly, it's possible that you have inadvertently enabled the "Sticky Keys" or "Filter Keys" accessibility option in Windows.
When these options are enabled, your keyboard response time will be dramatically slowed and may require more than one tap to register a keystroke.
Fortunately, it's easy to disable these functions and return your keyboard to normal working order.
Click "Start" and select "All Programs."
Click "Accessories" and select "Ease of Access."
Click "Ease of Access Center."
Click "Make Keyboard Easier to Use."
Click "Set Up Sticky Keys." Deselect the checkbox that says "Turn on Sticky Keys When Shift is Pressed Five Times." Make sure the box that says "Turn on Sticky Keys" is not checked. Click "OK" to save your changes.
Click "Set Up Filter Keys." Uncheck the box that says "Turn on Filter Keys."
Click on the checkbox next to "Turn On Filter Keys When Right Shift Is Pressed For 8 Seconds" to deselect it. Click "OK" to save your changes.
Click "OK" again to save all of the keyboard accessibility changes you have made.
Hope this helps
Oct 29, 2012 | Gateway LT2021u Netbook
My HP Pavilion dv7-3080us is having a keyboard problem. Pressing F8, or Backspace does nothing. The problem occured soon after purchasing the computer and simultaneously for both keys. The keys doesn't...
The keyboard got busted. If it has warranty send it back else you can shop for a replacement keyboard online. They are easy to install and doesn't require much work.
Jan 17, 2011 | HP Pavilion dv7-1130us laptop
I have GA-8I848P-G and it was working good until ,somehow, something happened that i don't know that made my keyboard stops responding while in windows and games,so i had to get a ps/2 -to- usb converter...
If you have same problem when you loaded at BIOS, may be 2 variants: 1. keyboard broken(need to be replaced) 2. MB broken (need to be replaced) Trying use other keyboard on for tests helps locate problem. But if at BIOS all works good, that means trouble in the Windows(need reinstall)
Oct 15, 2010 | Gigabyte GA-8I848P-G Motherboard
Certain keys on the Gyration GC15CK keyboard have stopped working
If this is hardware problem, it'd be hard to repair. I don't mean it's not repairable, but what i mean is i don't recommend since repairing a keyboard and purchasing a new item will cost you more or less the same.
Well try this, Press Fn + Numlock (simultaneously on both the keys) on the keyboard and check if it helps or not [press once and then type the malfunction keys, if not press twice or thrice]. Most keyboard with Fn key's functions can be deactivated or activated with this key combination.
Good luck.
Thanks for using FixYa.
Jul 03, 2010 | Gyration GP9110-001 Wireless Keyboard
Has new battery and wont turn on
Hello, You can try to perform the self-test. Procedure is as follows. To perform the self test on units with two batteries:
  1. Turn the calculator off.
  2. Press and hold the c01788482.jpg and c01774569.jpg keys; keep both keys held down for the next step.
  3. Press the c01788481.jpg key so the c01788483.jpg and c01788481.jpg keys are held down simultaneously.
  4. Release the c01788481.jpg key.
  5. Release the c01788482.jpg key, followed by the c01774569.jpg key. The main test screen displays the following: '1.L 2.C 3.H'.
    • Press c01788484.jpg to perform the LCD test (all LCD segments will be turned on). Press any key to exit.
    • Press c01788485.jpg to perform the checksum test and see the copyright messages. Press any key to go from one screen to the next until the main test screen, '1.L 2.C 3.H', is displayed again.
    • Press c01788486.jpg to perform the keyboard test. Press EVERY key on the keyboard until all the keys have been pressed at least once. The screen will progressively turn off with each key press. Once all the keys have been pressed and the screen is clear, press any key to return to the test screen.
Press c01788481.jpg to exit the test system. This will also turn the calculator off. If the calculator detects an error at any point, it will display an error message. For the HP 12c financial calculators with one battery, to perform the LCD self test:
  2. Press and hold the c01788480.jpg key, and simultaneously press and hold the c01788481.jpg key.
  3. Release c01788481.jpg then c01788480.jpg .
  4. After a few moments, all elements of the screen should be displayed. Press any key to exit.
Nov 02, 2009 | HP 12c Calculator
Mx3000 stopped working, read forums, reset receiver now dashes only when pressing any key. rebooted computer ... now keyboard not responding agian
I got a used MX3200, got the mouse working right off, but no keyboard. This solved my problem: with the wireless mouse working took out the keyboard batteries, pressed connect button on the receiver, replaced the keyboard batteries, pressed connect button on the keyboard. Voila!
Feb 03, 2009 | Logitech Cordless Desktop MX 3000...
Keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
Installing Win XP, F8 key to agree to EULA wont respond
Check for an F Lock key on your keyboard.
By pressing it, it should activate your F Keys and F8 should work as advertised.
Nov 18, 2007 | Computers & Internet
HP Compaq nc6220 Notebook Logo
219 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
