Question about Tools & Hardware - Others
I can't figure out how my synco sfn1 trigger assembles!
  • 885 Answers
Go to www.senco.com, click on the 'Nailers, Staplers and Collated Screwdrivers' picture and it will take you to an information page. Your gun is under the discontinued models drop down menu. Select your gun and hit GO any you'll be on a page with a Parts Chart. That should give you a better idea of how it's assembled.
Posted on Aug 23, 2010
My senco sfn1 finish nail gun is leaking air
The SFN1 is a great nailgun, built for professionals, and is pretty much indestructible. It's air leak is most likely an O ring that is worn out. While it is theoretically possible to figure out which one it is, and replace it, the smart move is to have the gun rebuilt by an approved service tech. I usually pay about $60 to have my SFNs gone through. My oldest SFN1 is 18 years old, and it has only been rebuilt once.
Jan 25, 2014 | Senco Tools & Hardware - Others
When I cut with my ms362 the trigger assembly fill with wood chips
figure out where its getting in snd put some duct tape on as a deflector! works great with mine and I just change the out the duct tape in the morning each day I use it.... takes about 20 seconds...
Dec 08, 2013 | Stihl Garden
My senco sfn1 will not fire a nail not enough air?
Sfn1 is an oilless nailer. It needs about 100psi for full power. If oil has been used in the gun or if oil is leaking out of compessor and making its way into the gun, the rubber firing valve could swell preventing it from working correctly. The firing valve sits on top of cylinder (black plastic). If the driver is bent or piston fits too tight in the cylinder you will have similar problem. The piston/driver should move easily down cylinder (but not slip down under its own weight). Finally, the nail will not be driven all the way in if the tip if the driver has broken off. Good luck with your repair.
Mar 17, 2013 | Senco Air Tools & Compressors
Bostitch N79WW Leaking air from the trigger. Can't figure out how to remove trigger assembly. I removed two pins, one at the trigger hinge and one lower pin for what appears to be for the valve assembly,...
See the link below for a parts breakdown of the gun. Usually this problem is a defective trigger assembly and requires that the trigger be replaced. You can also check the Orings. If there is an air leak this can also occur.
Dan
Link: http://www.fixya.com/support/r5812776-bostitch_nailgun_dis_assembly_assembly
Oct 29, 2010 | Bosch Air Tools & Compressors
My Senco SFN1 finish nailer will not shoot a nail. When the trigger is pulled air comes out but no nail is shot. Thanks,Steve L
Not sure about Senco but most have latch you can open to expose firing mechanism. Nail sometimes gets jammed and will not allow driver to fire or if not nail push driver ****** all the way back into gun then see if gun will fire.
Oct 25, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
Finger trigger has come apart. Diagram needed to reassemble.
go to this site .and you will be able to get a break down . http://www.toolpartsdirect.com/portercable/portercable-4.html
Apr 11, 2009 | Porter Cable-Cable FN250C 1-inch...
Kawasaki 19.2 cordless drill
Hi Tim, Sounds like you got it figured out! The only question I see is if there is a quick fix, and it looks like you answered your own question. You can certainly pursue requesting that it be fixed as a manufacturing defect/ faulty part, or even a safety hazard as that is your right. While I can not suggest you take that route, the old metaphor of the sparking trigger that melted in my hand always seemed to get a lot of attention. Good Luck to you, hope this Fixsya!
Mar 13, 2009 | kawasaki 19.2V 4 Piece Cordless Tool Kit
POULAN TRIGGER PROBLEM
Remove the air cleaner which usually exposes the carburetor--operate the throttle (engine off) and watch what moves--likely wood chips blocking the action--less likely, a wire linkage got bent somehow, or there is sawdust in the trigger mechanism. From your description, this saw starts full-throttle at the get-go. Sort of dangerous!
Jan 19, 2009 | Garden
Kirby sentra
Remove the bag assembly from the machine.Install the hose to the machine.The upholstery shampooer is simply a trigger assembly with a jar attached.Simply connect the back of the trigger ***'y to the end of the hose.On the attachment case is a cloth covered cap that goes on the other end of the trigger assembly.This is what creates the foam.Fill the jar with shampoo solution.Use the trigger to deposit the foam onto surface.Work the foam into fabric using soft cloth or brush.When it's dry,vacuum the foam and dirt out using the hose attachment on the suction side(front) of the machine
Nov 07, 2008 | Vacuums
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
