Question about Car Audio & Video
2007 Vera Cruz xm radio was working fine this morning, when I got in the car at noon, xm was not working. Message said "xm not ready" and it beeped and went to FM station.
    Problem Solver:
  • 18 Answers
Hey did you pay the bill.lol I have had that problem before an my problem was a bad conection on the antenna or you might have a bad atenna .
Posted on Aug 24, 2010
2008 vera cruz. AM reception is poor. It is better when engine is off but is still poor. FM and XM are good reception. Radio is integral with the GPS system. Hyundai has given up on fixing the problem....
Most radio reception problems that occur only while the car is running are caused by damaged diodes in the alternator. It can be difficult to diagnose this since most dealers and repair shops will not disassemble the alternator to test the diodes. If you can find a shop that rebuilds alternators they can test for bad diodes and replace them if necessary. Hope this helps.
Mar 08, 2011 | 2008 Hyundai Veracruz
Radio will not turn on for 30 mins in the morning, then works fine for the rest of the day. Next morning 30 min wait again. I have reset to factory settings Why?
not knowing what kind of radio you have, it almost sounds like you may have bad solder connections inside the radio.
May 12, 2010 | XM Radio (XMP6000)
XM radio ''NOT READY'' message
I have had this problem at least a half-dozen times, and the simplest solution is to pull the 2 fuses labeled 'audio 1' and 'audio 2.' It resets the radio, but it will work for a while after that (until I have to do it again). Had the xm unit replaced 3 times, new antenna installed, replaced the antenna connection wire - it always dies within a month.
Sep 24, 2009 | 2008 Hyundai Veracruz
I have a Siriusconnect Home Tuner and an XM Ready Receiver. Will they work together? What do I need to make the connection from the 8-pin mini DIN on the Tuner to the XM connector on my Denon AVR-587?
Not gonna work, sorry to say. You need the little two-piece "XM Ready" tuner unit (with antenna) to plug into your XM Ready receiver. Sell the Sirius Connect Home Tuner and buy the XM unit. XM unit still available at some Best Buy stores.
Sep 19, 2009 | Sirius Satellite Radio Receiver
2008 Hyundai Azera XM radio "not ready"
I had the same problem. My 2008 Hyundai Azera had 37,800 and my wife went over a speed bump the XM radio went off and displayed "Not Ready". I raised the hood, pulled the negative battery cable for about a minute, replaced it and fixed the problem. Only issue is, this happens every couple of days. I'll probably continue to do this till my xm subscription runs out then to heck with it.
Sep 13, 2009 | XM Radio Dual XMP7000 Auto In-Dash CD...
"not ready" message on XM radio
Remove the Audio Fuse and then put it back in and the problem is solved. So frustrating that I had to find this solution on another site as both the dealer and XM had no idea how to fix it. Dealer tried to tell me it was a bad radio and I'd have to get a replacement from Hyundai.
Jul 02, 2009 | XM Radio Dual XMP7000 Auto In-Dash CD...
NOT READY error message
Try this:
On the fuse panel in the dash is a black jumer not described in the manual or panel cover. It's a quick power disconnect for radio and clock.
Pull it, wait for a brief time, replace it in the original orientation.
May 19, 2009 | XM Radio Dual XMP7000 Auto In-Dash CD...
XM Direct
Resetting the head unit will make it look for anything that is connected to it recently or even already is for a long time. Make sure your head unit's memory cable is constant power (direct to battery) to retain in its memory that the xmdirect2 unit is already connected. There must be a loose cable when it is not recognized as a source like the power cable from the adapter which should be on constant power. You should hear a click sound on the xmdirect2 module whenever you turn to xm source on the radio. The CC tech that was actually solved the problem by chance if he couldn't explain this to you. Loosing signal is different
Oct 07, 2008 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
