Question about Microsoft Picture It! Publishing Platinum 2002 for PC
Tried to install picture it publishing plantinum on windows 7 and when i start the program it tells it stopped working, how can fix this problem
  • ruthtausz Aug 23, 2010
    what program would you suggest that does the same type of work picture it did
  • Microsoft Master
  • 4,924 Answers
If you need a simple and easy to use photo manager ..(editor) ..I suggest to use Photo-scape ...
it allows you to crop ...insert ..correct picture..and many more..like ..desktop capture..or region capture..
This program that you tried it has to be the edition for windows 7 to work ..and it needs to have word 2007 installed..
Her eis a link with the software I talking about and take a look to see if it is what you need..
http://www.mediafire.com/file/mzzjojmljjz/PhotoScapeSetup_V3.0.exe
Posted on Aug 24, 2010
    Genius:
  • 1,456 Answers
Microsoft picture it 2002 is not working on windows 7 operating system because the windows 7 operating system has not been balanced to work with older softwares such as the microsoft picture it 2002 that is why you keep getting the error message.this is because the software doesn't install properly
The best solution is to get a newer version of the software that is compatible with windows 7
Posted on Aug 23, 2010
I have an older version of Macmillan Publish It Deluxe which does not run on 64bit sys. any fixes?
I assume you have upgraded to Windows 7 or 8. You could try two things - firstly, make sure that the user installing the software has full admin rights. Second, there is an option to tell Windows to run the software in compatibility mode. That works with most software, but for very old ones, the option may well be to contact the publisher and see if they can help. Good luck.
Mar 23, 2014 | Macmillan Publish It Deluxe
When I try downloading my picture from my camera to my pc it says it can't. It has just started this. It has always work until now. What could be the problem.
Looks like Picture It! Premium 10 is not compatible with windows 7, for more information check the windows 7 compatibility link.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Search.aspx?type=Software&s=Picture%20It%21%20Premium%2010
Windows 7 Compatibility Center
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
You can still install Picture It! Premium 10 on windows 7 in a compatibility mode.
Run the Program Compatibility Wizard 1. Open the Program Compatibility Wizard by clicking the Start button , clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
2. Follow the instructions in the wizard.
Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Mar 14, 2011 | Microsoft Picture It Premium 10 for PC
Unable to use Micrografx Picture Publisher 10.0 with Win 7
Make sure that Micrografx Picture Publisher 10 pro installs into the X66 Program files folder.By default it will always install into the 64 bit program file if you have a 64bit installed.
If you have the 32 bit Windows 7 installed then right click with your mouse on the program before opening it up and select compatibility mode.Select XP SP3 compatibility mode.This works fine on my Windows 7 32bit. Use the first paragraph method if you have the 64bit Windows 7.
Regards Brian
Feb 14, 2011 | Micrografx Picture Publisher 10
Just installed Micrografx Picture Publisher 10 from the original disc. When I try to run it, I get the following error Micrografx Picture Publisher Digital Camera Edition has stopped working It says...
I had the same message trying vista. Windows 7 offers running older programs in XP or even Win 98 SE mode. That fixed the problem for me. Further I recommend running it as administrator. Hope it helps.
Walter
Feb 04, 2011 | Micrografx Picture Publisher Digital...
I installed arcsoft photoimpression 5 on a vista and 7 computer. Everytime I load a picture an I get an error message. It reads, "Photoimpression has stopped working. A problem caused the program to stop...
Funny I was using PhotoImpression 3 with no problem on the same machine for 3 years...until today {24-8-2010}. Now when I try to start the program a message appears saying "PhotoImpression has stopped working" with a bit saying that Windows will close the program and notify if a solution is available. I'm using Visa Home Premium. I use it alot and I need it back.
Aug 17, 2010 | Arcsoft PhotoImpression 5
I have picture publish 7 cd but it will not load on windows 7
right click>properties>compatibility>change to another version of windows and run as admin. or rightclick the setup file on the disk and hit run as admin.
Dec 10, 2009 | Micrografx Webtricity 2.0 Full Version for...
I have Micrographx Picture pubisher 8 and just changed to new PC Windows 7. Now I am being told that Win7 is not compatible! Can you help please? Regards Peter
yes can be, just follow these steps:
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Dec 05, 2009 | Micrografx Picture Publisher 8.0 for PC
My Vista laptop will install MS Picture It Publishing Platinum 2002 but stops working when I try to run the program. I was told any PC software newer than 2000 will work on Vista.
Its not just the same that everything will work in vista. Do this procedure to work with the software. Go to the executable file (.exe ) of MS Picture Publishing and then go to its properties , u can find Compatibility Tab , in that select the Program to run in Windows XP Mode. So when u set the compatibility mode you can run the program in Windows Vista.
Nov 04, 2009 | Microsoft Picture It! Publishing Platinum...
I installed my picture it platinum 2002 i my new
Hi!
That means that the program isent compatible with vista, its only compatible and works with Windows 98 / 95 / 2000 / Me / XP / NT
I dont know if there is any pacthes out there to make it work with vista, i couldent find any.
Good luck
Nic
Aug 11, 2009 | Microsoft Picture It! Publishing Platinum...
Micrografx Picture Publisher 8 not working with my Vista
I solved it!
The software installs OK.
After installation, reboot.
When you need to open the program, right-click on the Micrografx icon and select Run as Administrator. A yellow window pops up saying "An unidentified program want access to your computer," with pp80.exe as "Unidentified program" - that is actually Micrografx Pictures. Click "Allow." The program runs normally. The only caviat is that you will have to perform this routine every time you have to run Micrografx Pictures. But again, it takes 5 seconds to do it, and I love the program, having used it for over 10 years. Photoshop is far more advanced but it takes time to master it, and I do with Micrografx the same quality work as many with Photoshop.
Of course, Janet, you and I have to come to grips with the fact that Micrografx is pretty much dead, and Photoshop is alive and blooming. Maybe this Vista incident is a sign for us to learn Photoshop?
Apr 18, 2009 | Micrografx Webtricity 2.0 Full Version for...
Microsoft Picture It! Publishing Platinum 2002 for PC Logo
223 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
