Question about LG Washing Machines
I have VM2455H LG Washing machine. The problem is when the wash load is finished their is water in the soap, softner, bleach dispenser.
  • 10,865 Answers
Hi. Here is a link to a free download of the manual for your machine. IT is possible that the dispensers are clogged up with soap, softener, etc. Bring a pan of water to a boil and then pour it into the dispensers to clear them. Once you have poured the water in, add 2 cups of white vinegar to the laundry tub itself and then run your hot water cycle to clean the entire machine. http://www.retrevo.com/support/LG-WM2455H-Washers-manual/id/14017bh732/t/2/
J.
Posted on Aug 23, 2010
Soap dispenser overflowing with water
You will have to pull the dispenser tray out and clear any debris. I've seen a sock in one (who knows how that got there,) toys and even a glob of laundry detergent pods leavings.
Dec 21, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Soap, bleach, softner dispenser not working
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Dec 28, 2010 | Frigidaire ATF6000ES Front Load Washer
My LG WM2487H has water in the detergent cup at the end of the wash. It has happened twice now.
This is normal.
All LG washers use a siphon system to dispense soap, bleach and fabric softner.
Some times water will remain in the cups depending on the cycle used.
Jan 20, 2010 | LG WM2487H Front Load Washer
Bleach not always being emptied, bleach marks on clothes, bleach sometimes runs right out when you fill it.
The dispenser works on a siphon principal. If you over fill the cup it will start the siphon and empty before it should. If that's happening you're using way too much. You only need about a tablespoon of soap, softner and bleach for a full load.
Aug 11, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROM STEAM WASHER-WM2487 HRM
You are probably using too much soap and softner. You only need about 1 Tablespoon of each for a full load with a front load machine. Run it with nothing it in except bleach. If you see bubbles inside that means there's left over soap in the tub. Keep running it empty (with bleach) until you don't see bubbles anymore then start using less soap and softner.
Jul 31, 2008 | LG WD-14124RD Front Load Washer / Dryer
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Water in soap holder after washing.
my washer is about 1 year old. It started leaving water in all the the compartments,soap,bleach and softner. I tried everything also. Nothing seemed to work. I finally took the hoses off the back of the machine, and the cold water hose screen was clogged up going into the machine. I cleaned all the screens and haven't had that problem again. I think there wasn't enough water pressure to flush out the containers. I dont think its gravity or suction, its water pressure. unless you get a blast of water into these compartments, there will always be water left in these containers.
Oct 27, 2007 | LG WM-2277HW Front Load Washer
LG WM2233H Washer
Most likely the small electric motor that moves the water injection pipe on to the various outlet mainifolds has stripped its plastic gears, afraid the only solution is a new soap dispsener assembly
Oct 01, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
82 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
