Question about Samsung 710N V2 17" LCD Monitor
When you turn on tracing, has black screen with a rectangle walk from corner to corner that says "Not Optimum Mode. Recommended mode 1024x768 60Hz" I walk about 5 to 10 seconds on the screen then closes that one rectangle of monitor everything, even the current show is not. If you start tracing with another monitor and bag while Samsung's is already in Win, I no longer looks anything. Full black screen.
ronenfe
  • 91 Answers
SOURCE: not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Posted on Mar 03, 2008
SOURCE: not optimum mode recommended mode 1024 x 768 60hz
change frequency to 85hz
Hook up a different monitor and set resolution to no higher than 1024 x 768. Samsung monitor will then work fine. It appears that something fails in the monitor and it will no longer support anything higher than this.
Posted on Sep 29, 2008
SOURCE: not optimum mode 510v 17" LCD Monitor
Samsung have a lot of liquid crystal display there. The solution is simple: the replacement of an MCU will be able to repair.
Samsung LCD MCU sales:
http://www.dgdw.cn/lcd%20mcu/SAMSUNG%20MCU%20English.htm
SKYPE: cqrising
Posted on Dec 07, 2008
SOURCE: syncmaster 913v not optimum mode
I just resolved this problem for my SyncMaster 913N.
It seems to be a known issue, however it can take quite some time for the problem to occur. In my case about 3,5 years, so well out of warranty.
Short term solution: unplug your monitor from power. The switch on the front is not good enough. Pull the plug and leave it for an hour or so (all night if you can). Good chance the monitor will work next time you power it up.
The problem will is likely to come back..
Permant fix requires some basic soldering as per this video:
I just managed it and it has been ages since I soldered a resistor so you may very well be able to do it. I spent $25 on tool and part and saved me from buying a new monitor.
Posted on May 01, 2010
SAMSUNG SYNCMASTER 226BW WHEN TURNING ON MONITOR, IT SHOWS BLACK AND WHITE LINES THEN IT SHOWES A BOX THAT SAYS "NOT OPTIMUM MODE, RECOMMENDED MODE 1680 x1050 60HZ " AND IT IS STUCK ON THIS...
hi dear
start your computer on safe mode and go to the display property change to as per mentioned rresolution on your screen.
best of luck
regards
raj
Sep 06, 2011 | Samsung Computers & Internet
Inspiron 1520-before finishes loading desktop screen goes black..
As it works ok in safe mode, I suggest you check that your graphics drivers are up to date.
You should be able to download the latest from the Dell website.
Mar 20, 2010 | Dell Inspiron 1520 Motherboard
Samsung syncmaster713bm not optimum mode
try to adjust resolution you monitor may not support higher resolution change it in the display properties
Mar 13, 2010 | Computers & Internet
Screen goes black with a floating sign the says Not Optimum Mode Recommended Mode: 1280x1024 60Hz Took in for repair and work ok there
befor loding windows press F8 then choose vga mode
inside vga mode change the resolution to the recommended mode and restart your pc
then i think it will works
bye
dont forget to rate my solution
Jan 23, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Geen beeld opmerking :not optimum mode
comes on and screen says optimized mode 1280x1024 60hz i put it on and get no video
Jan 23, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
Floating box non optimum mode recommended mode
You need to adjust the Display screen resolution.
  1. Control Pannel
  2. Display
  3. Settings
  4. Screen Resolution
Sep 22, 2009 | Samsung Computers & Internet
Half of the screen is black - Samsung SynchMaster 710N
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Sep 05, 2009 | Samsung SyncMaster 710N 17" LCD Monitor
Samsung 713N screen goes black
OK. IN XP GO TO DEVICE MANAGER AND CLICK ON THE MONITER AND UPDATE THE DRIVERS.IF IT TELLS YOU IT CAN NOT FIND A BETTER DRIVER UNINSTALL..REBOOT AND DOWNLOAD NEW DRIVERS FROM CO. WEB SITE.RICHARDM69
Aug 31, 2009 | Samsung SyncMaster 713N 17" LCD Monitor
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Not optimum mode
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
Samsung 710N V2 17" LCD Monitor Logo
42 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
