Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Siginal is lost and can't turn the system when I want to. The only light on the system that will turn on is the TV 1 green light. And it occasionally blinks every few seconds from time to time. Nothing comes on period. I checked the cables, reset the system, unplugged it etc etc, but to no avail. It simply appears to be broke
  • 748 Answers
Hi
First get ahold of Dish Network and have your dish realigned. Sometimes excessive wind or birds can move the dish away from it's optimum recption. At this point also, the repair person can tell you if the equipment is bad.
Posted on Aug 23, 2010
65 inch mitsubishi model# 65736 green light blinking
If the TV does not stay on, press the POWER button on the control panel for at least eight seconds to perform System Reset. The TV will turn off. Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost. If this happens frequently, obtain an AC line power conditioner/surge protector.
An unusual digital signal may have been received, triggering a protection circuit. Wait for the light to stop flashing and turn TV on.
Momentary power fluctuation caused the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again
Sep 29, 2016 | Mitsubishi Televison & Video
I have a Mitsubishi WD 60738 and the stand by light on the front of the tv was staying on and was orange. I removed the power supply and blew out all the dust and reinstalled the power supply and now the...
Hello Jeff;
If the TV does not turn on or off, does not respond to the remote
control or the control panel buttons, or has audio but no video:
1.) Press and hold the POWER button on the control panel for ten seconds. The TV will turn off.
2.) Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost.
If the TV does not respond to the remote control or to the control-panel buttons and TV will not power on or off.
• Unplug the AC power cord for 10 seconds.
• Press and hold the POWER button on the control panel for 10
seconds to perform a system reset.
If the TV turned itself off and the light on the front panel started to flash:
• Momentary power fluctuation can cause the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again.
• If the TV does not stay on, press the POWER button on the
control panel for ten seconds to perform a System Reset. If this happens frequently, obtain an AC line power conditioner/surge protector.
• An unusual digital signal may have been received, triggering a
on.
If the TV will not power off, press the POWER button on the control panel for ten seconds to perform a System Reset.
Should you still have problems, call for assistance at 1(800) 332-2119
I would not recommend using compressed air or any other method that would blow dust around- since the dust could make its way into the set's circuitry via the grille or vents and cause problems. Use a vacuum cleaner with a brush attachment instead.
Mar 12, 2015 | Mitsubishi Televison & Video
The satellite will not turn on
Hello, my name is Tommy Faust with DISH Network Customer Service. I understand how frustrating this problem can get.
If you're still having the issue, what it's doing is called Boot Recovery. It needs to finish the recovery process and should power back on fine.
I hope this helped! Feel free to get back to me here if you have any further questions.
Jul 10, 2010 | DISH Network DVR-625 DTV Receiver /...
Tv fades to black very low sound or or goes to blue & says lost siginal then goes toblank turn off set & waite a few min.& turn back on will only stay on for a few min. have to repeat.
This is not a "digital" problem that can be addressed in your setup or fixed at home. This sounds like a fading power supply. Often electronics fail slowly or partially.
You will need to consult a TV repairman.
I hope this helps!
Jun 15, 2010 | Olevia 237T 37 in. LCD TV
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Mitsubishi WS-65613 tv green power light keeps blinking tv will not turn on
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Sep 11, 2009 | Mitsubishi WS-65613 65" Rear Projection...
MIT WD-62525 DLP TV blinking green light on front won't stop
Hi!
It means your TV needs to reset. Although you have reset it previously, now again reset the TV as per procedure given below:
Please press the SYSTEM RESET button on the front panel with a pointed item such as the point of a ball point pen or end tip of a paperclip.
The TV will turn off and the green LED will flash quickly for about one minute. After the green LED stops flashing, turn on the TV again. The changes you made while the TV was most recently on, before you used the SYSTEM RESET button, may be lost; the changes you made previously, however, are not lost. Only those changes since the last power on may be lost when the system reset button is pressed. All other settings are retained.
TV Reset Menu
Read on-screen warnings before proceeding, as some user data or settings may be erased.
1. Press TV MENU and then 1, 2, 3 to see the RESET SERVICE MENU to reset the TV.
2. Select Reset System Defaults (CAUTION: All settings, except V-Chip, will be reset to the original factory defaults.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV Green
satellite box send out siginal in the same frequency, so the tv tuner doesnt have to work on it, but all siginal coming to the Tv goes through the turner.
Jun 25, 2008 | Televison & Video
Remote
the intruction are at the back of the battery .
1 turn on tv
2 press and hold Code Search untill all device bottons light( they will all turn green)
3 press tv button. tv botton will stay on
4 press power repeatedly untill tv turns off
5 press enter and you are all set
repeat 1-5 for vcr , ect
Apr 01, 2008 | RCA RCR350 Remote Control
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
128 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
