Question about Ruud Heating & Cooling
On Ruud condenser mod.# UAFD-036JAS, I am looking for the matching furnace and coil information, specifically dimensional data and opening sizes. Can you help me?
3 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: I have a Ruud Model UAFD-036JAS Air Achiever 9
You have a blown or two blown fuses that will need to be replaced on the emergency shut off next to your condensor outside.
Posted on Jun 07, 2010
shastalaker7
  • 1515 Answers
SOURCE: I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Posted on Jun 28, 2010
I have RUUD furnace with build in coil for air conditioner and Weather King compressor outside of my condo. ALL EQUIPMENT IS 4 YEARS OLD I didn't have any problem with heat at winter, but in summe
When you remove the panel to the unit it turns off the power to it. The reinstalling the panel will reconnect power and allow the unit to reset. So the cheapest and easiest thing you can try is to replace the thermostat. Make sure you see how many wires you have connected to your existing tstat and buy near the same thing. It's possible that the tstat is acting up, not allowing the unit to cool when the temp demands. And turning off power is resetting the tstat as well as the unit. It will be hard to troubleshoot with the info provided so a new tstat will be worth a shot. Hope this helps!
Apr 07, 2017 | Ruud Matching Split Air Conditioner
Model Number: UACC-036JAS The unit works fine. The problem is it doesn't shut down after the specified temperature has been reached. The furnace blower shuts down, but the ac unit keeps on running....
Hello, usually a stuck contactor coil will cause this on the outside unit. When the outdoor unit runs continously and the indoor blower does not run no heat is being absoebed by the evaporator coil and thus the line freezes. Replaceing the contactor will fix the problem.
Aug 30, 2011 | Ruud Heating & Cooling
Sincerely,
Shastalaker7
Jun 28, 2010 | Ruud Handler Air Conditioner
I have a Ruud Model UAFD-036JAS Air Achiever 9 split system. Does the outside unit have a reset button?The breakers are on yet no action from fan. Please help.
Jun 07, 2010 | Heating & Cooling
Need a Coil for Air Handler
You can use any 2 ton coil that is setup for whatever refrigerant you are using in the condenser.... just match the tonnage, the refrigerant, and the size and you are good to go...
heatman101
Apr 22, 2010 | Ruud UAPA024 Air Conditioner
Going to replace hvac system. Don't know what
According to the model number it is a 2 ton or 24,000 BTU unit. It is very important that you change the indoor coil as well as the outdoor section, due to it being a 10 SEER unit, and the new basic systems are 13 SEER, the old coil cannot handle the higher SEER ratings.
Rheem and Ruud are the same equipment, just 1 number different on the model number.
I hope this has helped, please rate the new guy :)
Please contact me if I can be of any further help to you.
Have a great day!
Sincerely,
Paul Gibson
Apr 04, 2010 | Ruud Matching Split Air Conditioner
Ruud UAFD 03 JAS AIR CONDITIONER
THE MFD SHOULD BE ON THE SIDE OF THE OLD CAPACITOR IF NOT THE MOTOR IS RATED FOR 3 MFD THATS WHAT YOU NEED
Aug 18, 2009 | Heating & Cooling
Need info for RUDD upflow oil furnaces
Contact your nearest Ruud DISTRIBUTOR, usually The Noland Company, and ask them if they could go into the historical documents and print out or send you the files for the wiring, spec's and parts breakdown. From the model number, that unit is rated for 3 tons of a/c. You can find a 3 ton coil that will fit in the space and get a straight cool condenser of 3 tons cooling and swap thermostats so it brings on the furnace and fan in heat and the condenser and fan in cooling. Or just add a simple White - Rogers model 444 for the cooling. Ron
May 06, 2009 | Ruud UBHC Air Conditioner
Evaporator coil
Follow the copper line set from the condenser. Yhat will be the yellow brick road to tne evap coil.
Aug 16, 2007 | Ruud UAKA030 Air Conditioner
Heating & Cooling Logo
313 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
