Question about Brother IntelliFax-2820 Laser Fax
Where is the drum located on this model - Brother IntelliFax-2820 Laser Fax
    Scholar:
  • 48 Answers
When you open the front cover you should see a handle facing you. Pull it and out comes the drum unit with the toner cartridge in it. On the left side of the drum there should be a green or blue tab that you push down to release the toner and separate the two. Swap out whichever one you need to and just push it back in until it clicks.
Hope this helps. Good luck!
Posted on Aug 23, 2010
Have an old hotpointdryer model no 9321w the drum will not spin when door is closed i have to move drum by hand to make it spin, is there a capacitor on this model or somthing else that starts the drum...
Yes there is a start capacitor on this model, it is usually located at the rear right of the inside of the cabinet, so you will need to gain access to the inside of the dryer.
Feb 19, 2011 | Hotpoint Dryers
We have a MMDE9206AYM model dryer that makes a low humming sound but will not start. Last night it also produced a burning smell. I assume either the belt is gone or the motor is overheating although it...
Sounds like drum is locked and motor is running and burned the belt. Try to spin drum by hand, Might check drum ends felt seals, Teflon bearing strips located on the bottom lip of front drum end for wear causing drag. Also check 2 drum support wheels to see if they spin freely, take the belt off motor pulley and spin drum by hand, if easier & motor runs drum is dragging. How is the spring on tensioner, does tensioner pulley spin free? Hope this helps locate the problem.
Feb 13, 2011 | Maytag Dryers
Where is the Kenmore element located ?
depending on the model number as in "Kenmore" 110.xxxxxxxx which the 110 means it was produced by Whirlpool corporation the element is located either in the lower part below the drum,on certain models its located behind the drum the 3 numbers tell who manufactured it for Kenmore because Kenmore is just the name for sears as they produce none of their appliances
Dec 18, 2010 | Kenmore Dryers
Loud clunking sound during the spin cycle, washer is balanced and on 2nd floor
If you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Frigidaire GLTR1670A Front Load Washer
Sounds like a Harley when it spins, still spins though.
If you get a very loud noise coming from the machine, and this noise is louder when it spins faster, then it is not a Harley inside your washer, it is the drum bearing.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Where are the fuses located on model #LE3000XSWO
The main thermal fuse is located by unpluging and raising the top and locating it in rear of drum area and top part of duct where the air flow enters the drum, Sea Breeze
Oct 21, 2009 | Whirlpool Dryers
Replaced the heating element what ever its called. and still not heating up' its politless
Disclaimer: I don't know this particular model, but in general, tumble dryers have 2 or 3 interlock switches that need to be checked:
1. Door interlock: this allows the drum motor and fan to energise and the heating element to be turned on: Does drum turn and fan come on? If so, it is not this.
2. Overheat switch: located in exhaust path of fan: usually re-settable - have you located this and reset it?
3. Humidity sensor (some models have this, some work on time only) - this can fail open circuit and the drum and fan won't come on. (Same check as number 1)
Jul 29, 2009 | Kenmore Dryers
What is the drum capacity size on the orig maytag neptune washer?
Drum size or capacity for the Neptune Model Number MAH4000AWW is 3.4
Jan 03, 2009 | Maytag Neptune Washer
Replacement drum for a fax image model 1670F.
hello
did you take the cartridge out?
if so you must separate the two things drum and toner.
Oct 21, 2008 | Canon ImageRUNNER 1670F Copier
Dryer is making rumbling noise,was told it was the blower,in checking the model #LNC7757A71 can not locate the proper part .
If you take the front panel off only 3 things will give you a rumble the blower is 1, should be located at the bottom left corner of your dryer, the glides are 2 should be located on the front panel or on the front shroud that the front of the dryer drum rest on up front or the bearing in the rear of the dryer drum, and possibly rear drum rollers if equiped.
Aug 05, 2008 | Dryers
Brother IntelliFax-2820 Laser Fax Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
