Question about Ryobi 9 in. Benchtop Band Saw
How to I heat the tire for installation on the upper wheel?
  • 2,176 Answers
Find a microwaveable bowl and put enough water in to cover the tire :MAKE SURE COVERED" usually 1 minute is good, use something to remove it and install
Posted on Aug 26, 2010
Replace tire
I suggest you to check the manual of the saw. One of the easiest technique I applied on installing a tire on my bandsaw
is I lay the band wheels on a wooden table or any wooden surface. Outside the wheel, I buried 6 nails around it , like a
half inch away from the wheel. Then, I strecth over the urethane tires outside the nails then afterwards I pulled the nails
one by one. When you re-install the wheel, make sure the wheels are in balance. To check this , you need to spin the
wheel freely by hand and observe any high and low points for the new tires. Also , before removing the wheels, I advise
to mark the front site of the upper/lower wheels. This ensures the wheels will be placed with the correct side facing out.
Jul 18, 2013 | Shop Fox W1770 Vertical 21" Bandsaw 5 Hp
Tire comes off of wheel
This could be a big wild guess on how the tire comes off on the wheel. But I'll try to help you this thing. I don't know if your bandsaw has adjustment bolt above the upper wheel and below the lower wheel, but in case there is , use these bolts to center the band saw. Well, this could also be blade tension adjustment. Tires should be a very tight fit and a struggle to get on.
Wait, was tired glued on? If not, reglue.
Is that an old tire? If yes, tire must be well worn out and time to invest new ones.
I recommend you to use this time urethane tires rather than rubber tires.
Rubber tires works fine but urethane tires last longer and doesn't need gluing. When you purchase a new tire, make sure that it is a couple of inches smaller than the wheel to stretch the tire. It is a good advice to slightly tilt the top of the drive wheels towards you. I've been purchasing urethane tire with www.bandsawparts.com. Got one from them and still up running. Piece of advise also,Before installing the new tires, you double-check the surfaces of the pulleys to make sure the surfaces are clean and true.
Nov 03, 2012 | Saws
How to change rear ball joints on 2002 dodge stratus
Instructions
  1. Remove the Upper Control Arm
    • 1Disconnect the ground battery cable using a wrench.
    • Loosen the front wheel lugs located on the same side of the upper ball joint you need to replace. Use a lug wrench.
    • Raise that same front wheel off the ground using a floor jack and support the vehicle on a jack stand.
    • Finish removing the tire.
    • Take the cotter pin off the upper ball joint stud holding the steering knuckle arm. Use a pair of nose pliers.
    • Remove the castle nut from the upper ball joint stud using a wrench or ratchet, ratchet extension and deep socket.
    • Loosen the two bolts securing the back of the upper control arm to the mounting bracket. Use a wrench to hold the bolt head as you loosen the retaining nut with a ratchet and socket.
    • Pull the control-arm ball joint off the steering knuckle arm. You may need to use a Pitman arm puller to free the ball joint.
    • Finish removing the two bolts from the back of the upper control arm and lift the upper control arm off the vehicle.
    Install the New Upper Control Arm
    • Set the new upper control arm in place and install the two bolts and retaining nuts to secure the back of the upper control arm to the mounting bracket. Remember the bolt heads should point inward toward the shock absorber with the retaining nuts on the outside of the mounting bracket. Do not tighten the bolts yet.
    • 11Insert the control-arm ball joint on the steering knuckle arm and start the castle nut with your hand over the ball joint stud. Do not tighten the nut yet.
    • Tighten the two bolts on the mounting bracket to 67-foot lbs. (91 Nm) using a torque wrench. Hold the bolts with a backup wrench as you tighten the retaining nuts with the torque wrench.
    • Tighten the ball-joint castle nut to 45-foot lbs. (61 Nm) using the torque wrench, ratchet extension and deep socket.
    • Install a new cotter pin through the joint-ball stud hole using the nose pliers. If necessary, tighten the castle nut just a few degrees to clear the stud hole through one of the castle nut slots.
    • Mount the tire on the wheel assembly and install the wheel lugs using the lug wrench.
    • Lower the vehicle and finish tightening the wheel lugs.
May 31, 2012 | Dodge Stratus Cars & Trucks
How to replace the upper control arm
  1. Loosen the wheel nuts slightly. Raise the front of the vehicle, and make sure it is securely supported.
  2. Remove the front wheel and tire from front hub. CAUTION: Be careful not to damage the hub bolts when removing the front wheel and tire.
  3. Remove the upper arm ball joint self-locking nut(A) and the split pin(B).
  4. Using the special tools, disconnect the upper arm ball joint from the knuckle. Remove the front strut assembly
  5. Remove the two upper arm mounting bolts(A) from the body.
Apr 25, 2012 | 2006 Hyundai Sonata
Need pictures and procedure 91 Ford pickup F250 twin I beam ball joint replacement.
Wheel Spindle, F-150, F-250, F-350
Removal
  1. Raise the front of the vehicle and install safety stands.
  1. Remove the wheel and tire assembly. Refer to Section 04-04 .
  1. Remove the disc brake caliper (2B120) from the rotor and wire it out of the way. Refer to Section 06-03 .
  1. Remove the dust cap, cotter pin, nut retainer, nut, washer and front wheel bearing (1216).
  1. Remove the rotor from the front wheel spindle (3105).
    Item Part Number Description 1 606085 Clamp Bolt 2 3B404 Camber Adjuster 3 800895 Nut 4 800937 Nut 5 3049 Front Suspension Upper Ball Joint 6 3050 Front Suspension Lower Arm Ball Joint 7 3105 Front Wheel Spindle 8 642569 Cotter Pin 9 3304 Steering Sector Shaft Arm Drag Link 10 383489 Nut 11 3001 Front Axle Assembly 12 388727 Bolt A - Tighten to 77-103 Nm
    (57-75 Lb-Ft) B - Tighten to 68-92 Nm
    (50-67 Lb-Ft) C - Tighten to 113-153 Nm (83-112 Lb-Ft) D - Tighten to 340-460 Nm (250-339 Lb-Ft)
  1. Remove bearing cone and roller (1201) and wheel hub grease seal (1190). Discard the seal.
  1. Remove front disc brake rotor shield (2K004). Refer to Section 06-03 .
  1. Disconnect the steering linkage from the integral front wheel spindle and spindle arm by removing the cotter pin and nut and then removing the front wheel spindle tie rod from the spindle arm with Tie Rod End Remover TOOL-3290-D or equivalent.
  1. Remove the cotter pin and castellated nut from the lower ball joint stud.
  1. Remove the nut from the axle clamp bolt and remove the bolt from the axle.
  1. Remove the camber adjuster from the upper ball joint stud and axle beam. If required, use Ball Joint Removing Tool D81T-3010-B or equivalent to remove adjuster.
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use a pickle fork to separate the ball joint from the axle as this will damage the seal and the ball joint socket.
    Strike the inside area of the axle as shown to pop lower ball joints loose from the axle beam.
  1. Remove the front wheel spindle and ball joint from the axle.
Ball Joint, F-150, F-250, F-350 SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number U-Joint Tool T74P-4635-C Ball Joint Remover T94T-3010-AH
Removal
  1. Remove the front wheel spindle (3105) and ball joint assembly from the axle. Refer to Wheel Spindle, F-150, F-250, F-350 in the Removal and Installation portion of this section.
  1. NOTE: Lower ball joint must be removed first.
    Install the front wheel spindle in a vise and remove the snap ring from the lower ball joint.
  1. Remove the lower ball joint from the front wheel spindle using U-Joint Tool T74P-4635-C and Receiver Cup D81T-3010-A5 or equivalent for F-150. Use Ball Joint Remover T94T-3010-AH for F-250 and F-350.
  1. Turn the forcing screw clockwise until the ball joint is removed from the front wheel spindle.
  2. CAUTION: Do not heat the ball joint or the front wheel spindle to aid in removal.
    Assemble U-joint tool and cup on the upper ball joint, and turn forcing screw clockwise until ball joint is removed from the front wheel spindle.
    Installation
    1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not heat the ball joint or axle to aid in installation.
      NOTE: Upper ball joint must be installed into the front wheel spindle first.
      NOTE: Individual ball joint tools are included in Ball Joint Adapter Set D81T-3010-A or equivalent.
      To install the upper ball joint, assemble C-frame assembly, Ball Joint Receiver Cup D81T-3010-A5 and Installation Cup D81T-3010-A1 and D81T-3010-A3 or equivalents inside cup D81T-3010-A4 or equivalent in position on the front wheel spindle.
    1. Turn forcing screw clockwise until ball joint is seated.
Mar 25, 2011 | Ford F-250 Cars & Trucks
How to replace lower left front ball joint ?
Removal & Installation NOTE This procedure requires the use of the following special tools: J 9519-E Lower Ball Joint Remover and Installer, J 34874 Booster Seal Remover/Installer, J 41435 Ball Joint Installer, J 45105-1 Ball Joint Flaring Adapter and J 45105-2 Receiver.
  1. On 4WD vehicles, remove the wheel center cap and drive axle nut.
  2. Raise and support the vehicle.
  3. Remove or disconnect the following:
    • Tire and wheel
    • Wheel hub and bearing, if necessary
    • Outer tie rod retaining nut
    • Out tie rod from the steering knuckle using a suitable puller
    • Brake hose bracket retaining bolts and bracket
    • Upper control arm-to-steering knuckle pinch bolt and nut
    • Upper control arm from the steering knuckle
    • Lower ball joint retaining nut
    • Steering knuckle from the lower control arm using a suitable ball joint removal tool
    • Steering knuckle from the vehicle
    • Lower ball joint flange with a chisel
  4. Install tools J 9519-E and J 34874 to the lower ball joint, then use those tools to remove the lower ball joint from the lower control arm.
To install:
  1. Install or connect the following:
    • Lower ball joint to the lower control arm, using tools J 9519-E, J 41435 and J 45105-2
  2. Remove the tools from the lower control arm.
    • Tools J 9519-E and J 45105-1 to the lower ball joint
  3. Flare the lower ball joint flange with J 9519-E and J 45105-1, then remove the tools from the lower ball joint.
    • Steering knuckle to the lower control arm
    • Lower ball joint retaining nut and tighten to 81 ft. lbs. (110 Nm)
    • Upper control arm to the steering knuckle
    • Upper control arm pinch bolt and nut and tighten to 30 ft. lbs. (41 Nm)
    • Brake hose bracket to the steering knuckle
    • Brake hose bracket retaining nuts and tighten to 7 ft. lbs. (10 Nm)
    • Outer tie rod to the steering knuckle
    • Outer tie rod retaining nut and tighten to 33 ft. lbs. (45 Nm)
    • Wheel hub and bearing, if removed
    • Tire and wheel
  4. Lower the vehicle
    • Drive axle nut, if 4WD, and tighten to 103 ft. lbs. (140 Nm)
    • Wheel center cap, if removed
  5. Check the front wheel alignment.
Nov 30, 2009 | 2002 Oldsmobile Bravada
My 20001 f350 2 wheel drive front tires lean in at
On the 01 there is a camber bushing that goes in the knuckle with the upper ball joint( the factory ones wear out), take it to a alignment shop, specify you want the camber set, and they will be able to provide a shim and install it for you,it only take a couple secs to install, you can turn the aftermarket shim to achieve correct camber.
Jul 18, 2009 | 1996 Ford F350 Crew Cab
How do I replace the upper ball joints in my 2002 Ford Explorer?
The upper ball joints are replaceable without replacing the control arms. Use Moog K80008 ball joints and a ball joint press.
Jun 25, 2009 | 2002 Ford Explorer
Ryobi 9 in. Benchtop Band Saw Logo
71 people viewed this question
Top Ryobi Saws Experts
JOHN LAPIER
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
