Printers
Problem for Printers
Generic problem for all Printers
Error code 5100
By ccoolgranny7 on May 04, 2008
error code 5100
Same Problem
May 16, 2009
-   I cant use my printer, is stil error 5100. What i have to do?-   Guest
May 04, 2009
-   This is my last Canon printer. I went through a similar problem just over a year ago, and now this! Error of either 6A00 or 5100 depending on when/where the jam occurs. I have tried all fixes on these posts to no avail. I can already hear the conversation at the service centre."It'll cost $X.XX to check it out plus repairs which are probably more than just buying a new printer." And we wonder why we live in a consumer society?!?!?? Printers must be one of the biggest scams of our generation as is obvious by the number of people experiencing the same problems over an over again. -   Guest
Apr 30, 2009
-   same problem - no solutions-   Guest
Apr 12, 2009
-   Same as everyone else
-   Guest
Mar 30, 2009
-   Just keeps saying 5100 with no real erro message other than turn printer off-   nixon2u
Best Solution
posted on Feb 20, 2009
Helpful)
keadla
Rank: Apprentice
Rating: 85%, 13 votes
Here's what worked for me in solving this error code 5100 problem. Not only was I unable to print anything because I kept getting that code, but there was a thunking sound when the carriage stopped moving, and every time I turned the machine on it was feeding through one sheet of blank paper. I was about to go out and buy a new printer of a different brand because the Canon was unusable.
Then, fooling around with the machine's menu and settings buttons, I came across an option, I think it was in the Maintenance menu, to Restore Factory Settings. I chose that option and it asked me again if I wanted to restore the original factory settings, Yes or No. I said Yes, and immediately the printer started behaving itself. No more 5100, no more funny noises, no more blanks sheets of paper. It is back to its old self again.
That still doesn't solve the problem of spending a fortune to buy ink cartridges, but I just hooked up my old Panasonic 24-pin dot matrix printer to the printer port of my CPU (a ribbon lasts me a year and costs less than $15), and the Canon to another port, so now I can print the day-to-day stuff on the cheap dot matrix and use the Canon for the important stuff.
I don't know if restoring the factory settings will work for you, but it was the solution in my case. Hope it helps you out.
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
MP 620 printer is it a good buy
Answer
konika minolta 1600 magicolor
Answer
When I turn my hp officejet 5510 all in one ink cartridge it says the print cartridge error see the ... (More)
Answer
my 2ooo pixma does not turn on as if there is no electricity. Checked out power supply and it seems... (More)
Answer
sharp al 1540cs scanner lock will not release
15 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Mar 14, 2009
I can see the paper jammed inside, whenever i turn my printer on it just jams it more and gives me error code 5100
Comment by shawna40ish, posted on Mar 09, 2009
I have the same problem? What kind of error is it? How to fix it?
Comment by Bedford03, posted on Mar 07, 2009
have just bought the printer and i get the same problem :(
Comment by Guest, posted on Feb 23, 2009
i have the same problem how do we fix it
same error 5100 unsolvable for me
Comment by lucyb12, posted on Jan 11, 2009
I get the same error code and I cannot fix it. Has anyone figured it out?
Comment by jay50000, posted on Nov 25, 2008
i am trying to use my printer and it is telling me error 5100
Comment by TRENTIN1207, posted on Nov 25, 2008
I'M TRYING TO SCAN A PIC FROM MY PRINTER AND AS SOON AS TURN IT ON IT SAYS ERROR 5100 ERROR CODE I HAVE TRIED EVERYTHING WHAT DO I DO?
Comment by BrianDSLR, posted on Nov 24, 2008
My Canon MP970 does exactly the same. No solution found yet.
Comment by Guest, posted on Nov 20, 2008
the printer keeps giving the error code 5100. We cannot solve it. Please help
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Printers:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
