Question about Brother LS-2220 Mechanical Sewing Machine
I'm not sure how to put the thread in the sewing machine
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Brother Expert
  • 300 Answers
Go to the Brother website and download a free instruction manual.
http://www.brother-usa.com/support/default.aspx?PGID=3&R3ModelID=ls2020
Posted on Sep 11, 2012
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
  • 12 Answers
SOURCE: Bobbin thread breaks
Things to check for thread breakage (top or bottom)
1. Good thread in the machine - not hand thread, cheap thread, quilting thread.
2. A burr on the hook - a small nick on the hook can grab and tear threads, however this usually causes the top thread to tear, not the bottom
3. Make sure a new needle is in the machine - one made for the material you are sewing
4. The bobbin must be installed to rotate in the correct direction in your bobbin case
5. And I'll say it anyway - tensions - the primary cause of thread breaking - Remember, there are TWO tensions in a sewing machine, top and bottom. Also, the thread you see on the bottom of the stitch is the top thread, and vice-versa.
Posted on Dec 04, 2007
  • 106 Answers
SOURCE: Singer Sewing Machine 1425N
look at this website on the threading page if your machine is not listed email them and they will help. If you want to buy one they should have a manual.
www.sewusa.com
Posted on Apr 24, 2008
  • 323 Answers
SOURCE: Sewing Machine (brother XL 3200)
Your machine is out of time and needs to be serviced by a technician.
sewman7
Posted on Jul 19, 2008
Michaelle
  • 65 Answers
SOURCE: need help to thread our sewing machine.
you really must get a manual for this machine.
You can find manuals online for a small price.
At one time some sites had them for free, but I haven't been able to find many recently. sewusa.com has some older ones for free. but not many. you could try the kenmore site as well, if not I'd try to search on dogpile.com (sewing machine manuals)
Just so you know, your manual is the MOST important tool for any sewing machine, and its worth a couple of bucks to get it.
Posted on Jan 24, 2009
Bobbin thread cluming up
Make sure you have a tight wind on the bobbin, and it is free and clear of any lose threads. Also if replacement bobbin make sure the size is right for machine model. To thin of one causes them to bounce up and down putting tension on thread as it is sewing.
May 22, 2015 | Brother XL-5340 Mechanical Sewing Machine
I can't get the bobbin to thread.
This video may help. Probably not your model, but machines tend to thread and operate similarly.
How to Thread Janome Sewing Machine
Feb 17, 2018 | Janome Magnolia 7330 Sewing Machine
Bobbin shuttle
1. Clean shuttle with your sewing machine brush to remove old broken threads, lint, and sweep out the feed dogs carefully. 2. Rethread making sure you have the handwheel turned toward you, all the way up. 3. Lift presser foot up BEFORE you put thread front to back in eye needle. 4. Set machine on straight stitch sewing. Attach straight stitch foot if necessary. 5. Make sure 5-6 inches of thread are pulled toward you from threaded needle. 6. Pull up bobbin thread. 7. Pull 5-6 inches of bobbin thread and put it, along with needle thread under presser foot. 8. Put fabric scrap under presser presser foot and LOWER it now. Make sure, too, that the needle is correct size for fabric you're sewing. 9. Do a test. You may need to set tension at 4, stitch length at about 4 and width at 6. Just test it and adjust tension in very, very short turns. Another tip: Put one drop of good quality sewing machine oil on the hook, lower left-hand side. Make sure when you thread bobbin in the bobbin case to hold bobbin between thumb and forefinger and pull out about 4 inches of thread after you make sure thread unwinds top left (if you are right-handed!). Guide the thread into the slot in edge of bobbin case (screw sits on top of this "edge". Pull thread under tension spring and then into the delivery eye. Never panic, my friend! Try this and see if this helps. You should probably insert new needle too--just in case "old" one bent. Jimmy
Mar 31, 2012 | Brother LS-2125 Mechanical Sewing Machine
My consew 230 sewing machine is not holding the thred on the needle. every time i thred the needle and step on the paddle to sew, the needle comes back out unthred, please help.
before starting to sew
1.make sure the top thread & bobbin thread have a thread tail of 3 to 6 inches
2.make sure the thread tails are pulled behind the needle toward the back of the machine
then put the fabric under the presser foot to sew
when your finished with the seam, after the thread is cut from the fabric,, leave the thread tail the same as above before starting to sew again
Jan 22, 2011 | Consew Sewing Machines
Hi I have threaded the machine several times and the thread keeps snapping as soon as I start sewing. I've re-threaded the bobbin and replaced the needle and it still continues to go wrong. Help!
You may still be threading the machine wrong.
Do you have the manual to look at. If you still think that everything is threaded right. Try looking at the spool of thread, on every spool there is a small slice to hold the thread when not in use. Make sure when you put the thread on the spool holder, put the slice side on first so that it is torward the back, Also when you put the spool cover on make sure it is not to big or small for the spool.
After all this;
After threading the machine and ready, before you begin to sew, lift the foot up with the lever and pull the threads from under the needle they should pull freely, if either the top or bottom thread feel tight you can tell which thread is getting caught on something. Re-check the threads.
Also make sure that the thread is going through the tension disks correctly, they go between the dsks not behind, if this machine has the down and around the tension make sure it is done right.
Hope this helps
moni
Sep 22, 2009 | Brother LS-2125 Mechanical Sewing Machine
Upper thread winding around shuttle hook of sewing machine
rethread the needle as the thread has no tension
Aug 30, 2017 | Euro-Pro Sewing Machines
How do i thread the handy stitch sewing machine
Its easier to use the included threader from Japan its the key shaped thing, put the thin wire loop in at the front of the needle then put the thread through the loop at the back and then pull thorugh you will need to make sure at least 2 inches of thread is flying.
N.B.. Make sure that the thread is through the tensioner otherwise your stitches will be loose.
LOL
Aug 29, 2009 | As Seen On TV Handy Stitch Mechanical...
I have a singer cg 550 sewing machine and I am not sure which slot to put the bobbin thread in first
If you put the bobbin in the case with the thread coming off in a clockwise direction, the thread should just fall into a slot and gently tug on the thread and it will slide through the tensions. Lay it across the bobbin case and then pick up the thread with the needle.
Dec 20, 2008 | Singer 5050 Mechanical Sewing Machine
My sewing machine doesn't catch the bottom thread
Make sure that the bobbin thread is correctly threaded. If you have taken the shuttlecock out to clean make sure that it has been put back in correctly check manual to make sure it has been installed correctly. Next if neither one of those items are the problem, watch the needle and see if it is going down far enough to catch the bobbin thread.
Jun 20, 2008 | Brother CS-8150 Computerized Sewing...
Brother XL-5340 sewing machine
Try a new needle, making sure it is put in properly. A bent needle can break thread. Make sure top tension is set properly.
Dec 01, 2007 | Brother XL-5340 Mechanical Sewing Machine
Brother LS-2220 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
