Question about Car Audio & Video
I need to replace the factory speakers in a 2000 eclipes and i dont know how to remove the door panels or how get to the rear speakers at all. could you please help?
    Problem Solver:
  • 30 Answers
Okay u can down load that info from crutchfieid..website they great pics to show u how
Posted on May 05, 2008
I have a 09 pontiac g6 the speakers cut in/out regularly and someone told me to check the factory amp in the trunk but i cant seem to find it i dont think my car has one or is located elsewhere help
What is your G6 coupe or sedan or convertible ?
Radio Speaker Amplifier Replacement (Coupe and Sedan)
Remove the rear compartment trim panel. Refer to Rear Compartment Side Trim Replacement - Right Side.
If it isn't there you don't have one . Check connections at the radio ! Connections OK replace the radio .
Radio Speaker Amplifier Replacement (Convertible)
Remove the rear compartment trim panel. Refer to Rear Compartment Front Trim Panel Replacement.
Jul 01, 2016 | Pontiac Cars & Trucks
Plugged in a Kenwood stereo in a 2000 tahoe. Have all power but no sound. Radio is not defective. When plugging the same stereo into a 99 express van, it works just fine. My question... What is the wiring...
Hi, your factory wire colors are below. Please let me know if you have more questions.
2000 Chevrolet Tahoe Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Feb 10, 2011 | 2000 Chevrolet Tahoe
I need to replace a speaker in my buick cetury how
ok before i start if one factory speaker blew and your planing on replacing them all with a after marker speaker this is what you do.
remove the door panel then with that gone you should see a speaker just take it out the factory speakers may have a clip just cut it off and figure out witch one is positive and witch one is negative and if you hook it up wrong it wont hurt the speaker
its the same way with replacing the factory one just DONT cut off the clip
Apr 03, 2010 | Car Audio & Video
How do you replace factory speakers on an 02 Liberty?
No too hard to do. The rear speakers, need to remove the trim panels
and the fronts need to remove the door panels.You can just remove any
door handles or holders having phillips screws, then just pull or ply the panels
off with maybe a large flat head screwdriver if necessary.
Mar 21, 2010 | 2002 Jeep Liberty
I need to know the color codes for the radio rear sub.
2000 Ford Expedition Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Purple
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Blue/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Audio Front Speakers Size: 6′ x 8′
Left Front Speaker Positive Wire (+): White/Red
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: 6′ x 8′
Left Rear Speaker Positive Wire (+): Light Blue/Black
Right Rear Speaker Positive Wire (+): Purple/White
Dec 24, 2009 | 2000 Ford Expedition
I need to know how to get to the door speakers before i break anything. i dont know if you can take the speaker cover off or if yoy have to take off the door panel.
If you want to replace the speakers, you will have to remove the door panel. Removing the cover will only allow you to clean the cover or remove any foreign matter from the speaker cone.
Apr 06, 2009 | 1998 Honda Accord
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
I need to know how to remove rear door panel so that i can replace factory speaker on a 2004 trailblazer. Also what size speaker will replace it.
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. I don't know what speaker you'll actually need.
Mar 16, 2009 | 2004 Chevrolet TrailBlazer
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
