Question about Brother MFC790cw All-In-One InkJet Printer
I have a Brother MFC 790cw that does not print black all the other colors work, I have updated the driver bought a new ink cartrige and used the the clean option for the black ink. I know it is recieving data, the printer says ink is full and any documentthat needs black doesnt work. the printer recieves data and acts like it printing with the moving the heads. Help would be greatly acceppted
  • Brother Master
  • 4,166 Answers
Try printing a rest page and if that doesn't print in black ink the printhead is probably blocked.
With some printers the printhead is part of the ink cartridge and such problems tend to disappear when the cartridge is replaced, unless the cartridge is faulty. Other printers use cartridges that are ink and nothing more and those are prone to the printheads drying out and becoming blocked unless they are never allowed to become completely empty of ink and are kept in frequent use.
Cleaning/replacing such a printhead usually needs special tools and experience and in the case of many cheap domestic printers the cost of service far outweighs the cost of replacement.
Posted on Aug 13, 2017
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC-665CW
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
Posted on Feb 21, 2008
  • 320 Answers
SOURCE: Brother MFC-235C print head removal
there are no instructions that you would understand and once the print head is clogged up, you can noy mannually clean it , it has to be replaced! sounds like you are using generic ink!
Posted on Jan 17, 2009
  • 133 Answers
SOURCE: Brother mfc-7420n fax not recieving faxes, disconnecting
Please double check all cords and besure you are in the right plug.
Posted on May 22, 2009
the kowalski
  • 86 Answers
SOURCE: Brother MFC 5840 won't print red. ink is full. printer head clean
If the regular cleaning does not work, you can try the power purge. Perform it by doing the following:
  • Press Menu, 2, 8, 6, 4 quickly (within about 1-2 seconds from the menu-press, all five buttons should been placed, in order).
  • The display and some buttons should start flashing, and it should say "Maintenance".
  • Press 7, 6.
  • It should say "CLEANING ALL", press right arrow key until you get "CLEANING MAGENTA" or similar.
  • Press 3, it should now change to POWER_P or P_PURGE. Press Mono/Black Start.
  • The display should say "Cleaning", when it's done, it will say Maintenance again.
  • Press 99 and you will leave Maintenance mode, you can now try and see if magenta works again.
If it doesn't work, you'd probably need chemicals to clean the ink tubes. But, this power purge should work.
Posted on Jun 05, 2009
KingDWS
  • 1606 Answers
SOURCE: MFC-790CW; will not print the black color..
You probably have a plugged print head or the black ink feed is plugged.
Depending on how bad it is you may find it easier or even cheaper to replace the printer.
If this is a ink caused problem you stand a chance of fixing it if you are patient but you might go through half an ink cartridge to get it working, If it is stubborn it can take 20 or 30 cleaning cycles before you see any black. You can try using household vinegar (dissolves the dried ink) on a qtip or lint free paper towel to try to clean the print head. To do this you remove the ink cartridge and very gently rub the towel with the vinegar on the print head. This might require you to move the print head to one side so you can see the actual print area (where the ink comes out). Keep doing this until the towel starts to come clean ie not as much ink coming off. Then run a few print cycles and if this works your printer will print as good as the first day you had it.
The next stage would require filling a old clean ink cartridge with vinegar and running cleaning cycles. Usually can be pretty messy and you should rethink buying a new printer but will really clean things out.
It is also possible that the print head has picked up clay or paper lint from the paper and this has hardened like a cement. That means replacement.
Posted on Aug 17, 2009
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
IMPRESSION IMPOSSIBLE .4F
change your print head, and the printer will work perfectly.
when changing print head don't use chineese ink, use brother original ink, to save your head,
Hot Sell Printhead For Brother Mfc J825 Print Head Buy New And Original... Printhead Mfc j220 Mfc j615w Mfc j410 Dcp j125 Printer Head Buy Print Head...
Oct 05, 2012 | Brother MFC-J220 All-in-One Color Inkjet...
Brother MFC prints blank pages
Try disconnecting power completely, not just turning off. Wait a few minutes and reconnect to power
Also, your print queue may be full with failed attempts at printing. The printer becomes confused and does not know what to print next. You should be able to flush the queue at the computer, but the complete disconnect and reconnect may accomplish this
Sep 04, 2012 | Brother MFC-790CW Multifunction Printer
I installed new ink in my MFC-790CW but the printer prints blank
on the printer then go to menu then by pressing the up & down arrow select the cleaning then press ok cleaning will start after that it will ask to print sample page press start either black or color then check if the color that appear after printing is complete if not try cleaning again follow the instruction on the lcd that appear
Aug 07, 2011 | Brother MFC790cw All-In-One InkJet Printer
I have a Brother MFC-6490. The printer can not print in black. The black cartridge is new. There is no problem with color printing. Thanks for your help.
Hi
Remove the black ink cartrige and rub the print head into a plain paper with rubbing alcohol until ink flows. If not rubbing alcohol, no problem. Just rub the printhead into a plain paper.
Then try to print again. I hope it helps you. Please post comments if you need more help. Regards
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
Black ink does not work
A, Did u use a refilled one or a new one
B, Did u check that the black cartrige is touching the plate
C, Did u check that after putting in the cartrige the lock is put on
Nov 14, 2010 | Brother MFC-990CW COLOR INK-JET MFC Ink...
No print
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 18, 2010 | Brother MFC 490cw Color Inkjet...
MFC 790cw will not print in black.
garetg,
Your issue with the black ink only is because the print head my be dried up. Witch me that the ink cant flow to the "paper" fast enough. So by time to rollers eject the paper, the ink cant print on the paper. I had the same problem with my Kodak EasyShare 5300 All-In-One. So I contacted Kodak and they are sending me a new one. Try doing the same. Contact your manufacture and ask them..... :)
Much Regards,
Kyle
Sep 16, 2009 | Brother Multi-Function Center MFC-240C...
My brother mfc 420cn printer won't print
i reset the printer to the original factory settings, and now it works. thanks for your concern and help, richard
Feb 20, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC790cw All-In-One InkJet Printer Logo
399 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
